Do I need the ISY Portal
I just saw the notice that all future connections will be via ISY Portal.  Will I need to switch from MobiLinc to ISY Portal to continue access to this forum?  Does ISY Portal offer any features not already available through MobiLinc?  I'm not resistant to change, but would like to know the pros / cons before changing.  I do have POLISY.
You dont necessarily need the portal if you have mobilinc and mobilinc connect. Personally, I would rather have everything run through my isy as it would allow me to use different services whenever I want vs having to reconfigure things should I ever decide to leave a particular service.
I think @ronvond is refering to this notice:
which does make me wonder what people without a UDI portal account are supposed to do....
Hopefully we will get more information on the ISY Portal needed to participate here and to do any other accesses to other ISY sites.
I am one of the ones with out it.  I have no need  any of its functions and features.
They're just using the portal for single signon. I believe you can create a portal account without associating an ISY (and associated charges). If not, I'm sure that'll be the case when this thing goes full production.
Sent from my SM-N9500 using Tapatalk
Thank you for the information.
I was under the impression. You had to purchase a two year subscription to use Portal.
Hopefully when it is required. We will get further information from UDI.
