Mini Remote Linc 2 won't update
Kentinada
7 minutes ago, Kentinada said:
I have a Mini Remote Linc 2 that won't update. See the screenshot.  How do I debug this?  Thanks.
Is this device in a folder? If so, remove it and try to right mouse click and write updates. Bring it close to the 2413S PLM while in linking mode.
@Teken They are not in a folder.  The Kitchen Motion-Sensor above is a folder of sorts.  I tried moving the RL2 to within a few feet of the PLM and it still won't update.  Should I try deleting the device and re-adding?
Just now, Kentinada said:
Sorry, operator error.  It's been so long since I've changed the buttons on this RL2, that I forgot about pressing the Set Button first.  All working fine.
Rock On . . . ?
It shouldn't need to be removed just to write updates. Remote only needs to be in linking mode
I’m having a brain **** here. There was a specific reason a switch needed to be outside of a folder?!? It was some kind of setting that wasn’t visible unless outside of the folder??
I don’t recall what it was I’m thinking Replace With??
Old age is a PIA. Lol. Yeah, it's the replace function
Older - Wiser - Faster!
it was....  when you right click an Insteon device in the tree the "replace with" context menu does not appear if the device located in a folder.  It must be moved to the root level to use the function.
      378.6k
