Polisy Stuck in Bootloop after upgrade
I upgraded Polisy using:
sudo pkg update && sudo pkg upgrade
sudo reboot
Now it's stuck in a constant bootloop.  It stays up for about 10 seconds before it auto reboots itself.  Any suggestions on how to proceed from here to get it to stay up?
I managed to pull the log off the box.  Here is the pertinent info that shows the manual reboot and then shows that root is rebooting by itself:
Aug  2 16:13:25 polisy reboot[6626]: rebooted by admin
Aug  2 16:13:25 polisy syslogd: exiting on signal 15
Aug  2 16:14:22 polisy syslogd: kernel boot file is /boot/kernel/kernel
Aug  2 16:14:22 polisy kernel: ---<<BOOT>>---
Aug  2 16:14:22 polisy kernel: Copyright (c) 1992-2019 The FreeBSD Project.
Aug  2 16:14:22 polisy kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Aug  2 16:14:22 polisy kernel: 	The Regents of the University of California. All rights reserved.
Aug  2 16:14:22 polisy kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Aug  2 16:14:22 polisy kernel: FreeBSD 12.1-RELEASE-p1 r355229 POLISY amd64
Aug  2 16:14:22 polisy kernel: FreeBSD clang version 8.0.1 (tags/RELEASE_801/final 366581) (based on LLVM 8.0.1)
Aug  2 16:14:22 polisy kernel: CPU: AMD GX-412TC SOC                                (998.15-MHz K8-class CPU)
Aug  2 16:14:22 polisy kernel:   Origin="AuthenticAMD"  Id=0x730f01  Family=0x16  Model=0x30  Stepping=1
Aug  2 16:14:22 polisy kernel:   Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Aug  2 16:14:22 polisy kernel:   Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
Aug  2 16:14:22 polisy kernel:   AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
Aug  2 16:14:22 polisy kernel:   AMD Features2=0x1d4037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PTSC,PL2I>
Aug  2 16:14:22 polisy kernel:   Structured Extended Features=0x8<BMI1>
Aug  2 16:14:22 polisy kernel:   XSAVE Features=0x1<XSAVEOPT>
Aug  2 16:14:22 polisy kernel:   SVM: NP,NRIP,AFlush,DAssist,NAsids=8
Aug  2 16:14:22 polisy kernel:   TSC: P-state invariant, performance statistics
Aug  2 16:14:22 polisy kernel: real memory  = 4294967296 (4096 MB)
Aug  2 16:14:22 polisy kernel: avail memory = 4102766592 (3912 MB)
Aug  2 16:14:22 polisy kernel: Event timer "LAPIC" quality 600
Aug  2 16:14:22 polisy kernel: ACPI APIC Table: <COREv4 COREBOOT>
Aug  2 16:14:22 polisy kernel: FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Aug  2 16:14:22 polisy kernel: FreeBSD/SMP: 1 package(s) x 4 core(s)
Aug  2 16:14:22 polisy kernel: random: unblocking device.
Aug  2 16:14:22 polisy kernel: ioapic1: Changing APIC ID to 5
Aug  2 16:14:22 polisy kernel: ioapic0 <Version 2.1> irqs 0-23 on motherboard
Aug  2 16:14:22 polisy kernel: ioapic1 <Version 2.1> irqs 24-55 on motherboard
Aug  2 16:14:22 polisy kernel: Launching APs: 2 1 3
Aug  2 16:14:22 polisy kernel: Timecounter "TSC" frequency 998149026 Hz quality 1000
Aug  2 16:14:22 polisy kernel: random: entropy device external interface
Aug  2 16:14:22 polisy kernel: [ath_hal] loaded
Aug  2 16:14:22 polisy kernel: 000.000042 [4335] netmap_init               netmap: loaded module
Aug  2 16:14:22 polisy kernel: nexus0
Aug  2 16:14:22 polisy kernel: aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS> on motherboard
Aug  2 16:14:22 polisy kernel: cryptosoft0: <software crypto> on motherboard
Aug  2 16:14:22 polisy kernel: acpi0: <COREv4 COREBOOT> on motherboard
Aug  2 16:14:22 polisy kernel: acpi0: Power Button (fixed)
Aug  2 16:14:22 polisy kernel: cpu0: <ACPI CPU> on acpi0
Aug  2 16:14:22 polisy kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Aug  2 16:14:22 polisy kernel: atrtc0: registered as a time-of-day clock, resolution 1.000000s
Aug  2 16:14:22 polisy kernel: Event timer "RTC" frequency 32768 Hz quality 0
Aug  2 16:14:22 polisy kernel: attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Aug  2 16:14:22 polisy kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Aug  2 16:14:22 polisy kernel: Event timer "i8254" frequency 1193182 Hz quality 100
Aug  2 16:14:22 polisy kernel: hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Aug  2 16:14:22 polisy kernel: Timecounter "HPET" frequency 14318180 Hz quality 950
Aug  2 16:14:22 polisy kernel: Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
Aug  2 16:14:22 polisy kernel: acpi_timer0: <32-bit timer at 3.579545MHz> port 0x818-0x81b on acpi0
Aug  2 16:14:22 polisy kernel: acpi_button0: <Power Button> on acpi0
Aug  2 16:14:22 polisy kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Aug  2 16:14:22 polisy kernel: pci0: <ACPI PCI bus> on pcib0
Aug  2 16:14:22 polisy kernel: pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
Aug  2 16:14:22 polisy kernel: pcib1: <ACPI PCI-PCI bridge> irq 24 at device 2.1 on pci0
Aug  2 16:14:22 polisy kernel: pci1: <ACPI PCI bus> on pcib1
Aug  2 16:14:22 polisy kernel: ath0: <Atheros AR946x/AR948x> mem 0xf7900000-0xf797ffff irq 24 at device 0.0 on pci1
Aug  2 16:14:22 polisy kernel: ar9300_flash_map: unimplemented for now
Aug  2 16:14:22 polisy kernel: Restoring Cal data from DRAM
Aug  2 16:14:22 polisy kernel: Restoring Cal data from EEPROM
Aug  2 16:14:22 polisy kernel: Restoring Cal data from Flash
Aug  2 16:14:22 polisy syslogd: last message repeated 1 times
Aug  2 16:14:22 polisy kernel: Restoring Cal data from OTP
Aug  2 16:14:22 polisy kernel: ar9300_hw_attach: ar9300_eeprom_attach returned 0
Aug  2 16:14:22 polisy kernel: ath0: Enabling WB222 BTCOEX
Aug  2 16:14:22 polisy kernel: ath0: [HT] enabling HT modes
Aug  2 16:14:22 polisy kernel: ath0: [HT] enabling short-GI in 20MHz mode
Aug  2 16:14:22 polisy kernel: ath0: [HT] 1 stream STBC receive enabled
Aug  2 16:14:22 polisy kernel: ath0: [HT] 1 stream STBC transmit enabled
Aug  2 16:14:22 polisy kernel: ath0: [HT] LDPC transmit/receive enabled
Aug  2 16:14:22 polisy kernel: ath0: [HT] 2 RX streams; 2 TX streams
Aug  2 16:14:22 polisy kernel: ath0: AR9460 mac 640.2 RF5110 phy 817.0
Aug  2 16:14:22 polisy kernel: ath0: 2GHz radio: 0x0000; 5GHz radio: 0x0000
Aug  2 16:14:22 polisy kernel: pcib2: <ACPI PCI-PCI bridge> irq 25 at device 2.2 on pci0
Aug  2 16:14:22 polisy kernel: pcib2: failed to allocate initial I/O port window: 0x1000-0x1fff
Aug  2 16:14:22 polisy kernel: pci2: <ACPI PCI bus> on pcib2
Aug  2 16:14:22 polisy kernel: igb0: <Intel(R) PRO/1000 PCI-Express Network Driver> mem 0xf7a00000-0xf7a1ffff,0xf7a20000-0xf7a23fff irq 28 at device 0.0 on pci2
Aug  2 16:14:22 polisy kernel: igb0: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:14:22 polisy kernel: igb0: Using 4 RX queues 4 TX queues
Aug  2 16:14:22 polisy kernel: igb0: Using MSI-X interrupts with 5 vectors
Aug  2 16:14:22 polisy kernel: igb0: Ethernet address: 00:0d:b9:53:c7:c8
Aug  2 16:14:22 polisy kernel: igb0: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:14:22 polisy kernel: pcib3: <ACPI PCI-PCI bridge> irq 26 at device 2.3 on pci0
Aug  2 16:14:22 polisy kernel: pci3: <ACPI PCI bus> on pcib3
Aug  2 16:14:22 polisy kernel: igb1: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x2000-0x201f mem 0xf7b00000-0xf7b1ffff,0xf7b20000-0xf7b23fff irq 32 at device 0.0 on pci3
Aug  2 16:14:22 polisy kernel: igb1: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:14:22 polisy kernel: igb1: Using 4 RX queues 4 TX queues
Aug  2 16:14:22 polisy kernel: igb1: Using MSI-X interrupts with 5 vectors
Aug  2 16:14:22 polisy kernel: igb1: Ethernet address: 00:0d:b9:53:c7:c9
Aug  2 16:14:22 polisy kernel: igb1: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:14:22 polisy kernel: pcib4: <ACPI PCI-PCI bridge> irq 27 at device 2.4 on pci0
Aug  2 16:14:22 polisy kernel: pci4: <ACPI PCI bus> on pcib4
Aug  2 16:14:22 polisy kernel: igb2: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x3000-0x301f mem 0xf7c00000-0xf7c1ffff,0xf7c20000-0xf7c23fff irq 36 at device 0.0 on pci4
Aug  2 16:14:22 polisy kernel: igb2: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:14:22 polisy kernel: igb2: Using 4 RX queues 4 TX queues
Aug  2 16:14:22 polisy kernel: igb2: Using MSI-X interrupts with 5 vectors
Aug  2 16:14:22 polisy kernel: igb2: Ethernet address: 00:0d:b9:53:c7:ca
Aug  2 16:14:22 polisy kernel: igb2: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:14:22 polisy kernel: pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
Aug  2 16:14:22 polisy kernel: xhci0: <AMD FCH USB 3.0 controller> mem 0xf7fa2000-0xf7fa3fff irq 18 at device 16.0 on pci0
Aug  2 16:14:22 polisy kernel: xhci0: 32 bytes context size, 64-bit DMA
Aug  2 16:14:22 polisy kernel: xhci0: Unable to map MSI-X table
Aug  2 16:14:22 polisy kernel: usbus0 on xhci0
Aug  2 16:14:22 polisy kernel: usbus0: 5.0Gbps Super Speed USB v3.0
Aug  2 16:14:22 polisy kernel: ahci0: <AMD Hudson-2 AHCI SATA controller> port 0x4010-0x4017,0x4020-0x4023,0x4018-0x401f,0x4024-0x4027,0x4000-0x400f mem 0xf7fa5000-0xf7fa53ff at device 17.0 on pci0
Aug  2 16:14:22 polisy kernel: ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported with FBS
Aug  2 16:14:22 polisy kernel: ahcich0: <AHCI channel> at channel 0 on ahci0
Aug  2 16:14:22 polisy kernel: ahcich1: <AHCI channel> at channel 1 on ahci0
Aug  2 16:14:22 polisy kernel: ehci0: <AMD FCH USB 2.0 controller> mem 0xf7fa6000-0xf7fa60ff irq 18 at device 19.0 on pci0
Aug  2 16:14:22 polisy kernel: usbus1: EHCI version 1.0
Aug  2 16:14:22 polisy kernel: usbus1 on ehci0
Aug  2 16:14:22 polisy kernel: usbus1: 480Mbps High Speed USB v2.0
Aug  2 16:14:22 polisy kernel: intsmb0: <AMD FCH SMBus Controller> at device 20.0 on pci0
Aug  2 16:14:22 polisy kernel: smbus0: <System Management Bus> on intsmb0
Aug  2 16:14:22 polisy kernel: smb0: <SMBus generic I/O> on smbus0
Aug  2 16:14:22 polisy kernel: isab0: <PCI-ISA bridge> at device 20.3 on pci0
Aug  2 16:14:22 polisy kernel: isa0: <ISA bus> on isab0
Aug  2 16:14:22 polisy kernel: sdhci_pci0: <Generic SD HCI> mem 0xf7fa7000-0xf7fa70ff at device 20.7 on pci0
Aug  2 16:14:22 polisy kernel: sdhci_pci0: 1 slot(s) allocated
Aug  2 16:14:22 polisy kernel: amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb5
Aug  2 16:14:22 polisy kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 on acpi0
Aug  2 16:14:22 polisy kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 flags 0x10 on acpi0
Aug  2 16:14:22 polisy kernel: uart1: console (115200,n,8,1)
Aug  2 16:14:22 polisy kernel: tpm0: <Trusted Platform Module> port 0xc31-0xc32 iomem 0xfed40000-0xfed44fff on acpi0
Aug  2 16:14:22 polisy kernel: tpm: device 0x001a15d1 rev 0x10
Aug  2 16:14:22 polisy kernel: gpio0: <Nuvoton NCT5104D (PC-Engines APU3)> at port 0x2e-0x2f on isa0
Aug  2 16:14:22 polisy kernel: gpiobus0: <GPIO bus> on gpio0
Aug  2 16:14:22 polisy kernel: gpioc0: <GPIO controller> on gpio0
Aug  2 16:14:22 polisy kernel: orm0: <ISA Option ROM> at iomem 0xee800-0xeffff pnpid ORM0000 on isa0
Aug  2 16:14:22 polisy kernel: hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Aug  2 16:14:22 polisy kernel: ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
Aug  2 16:14:22 polisy kernel:             to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Aug  2 16:14:22 polisy kernel: ZFS filesystem version: 5
Aug  2 16:14:22 polisy kernel: ZFS storage pool version: features support (5000)
Aug  2 16:14:22 polisy kernel: Timecounters tick every 1.000 msec
Aug  2 16:14:22 polisy kernel: ugen1.1: <AMD EHCI root HUB> at usbus1
Aug  2 16:14:22 polisy kernel: ugen0.1: <0x1022 XHCI root HUB> at usbus0
Aug  2 16:14:22 polisy kernel: uhub0: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Aug  2 16:14:22 polisy kernel: uhub1: <0x1022 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Aug  2 16:14:22 polisy kernel: uhub1: 4 ports with 4 removable, self powered
Aug  2 16:14:22 polisy kernel: ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Aug  2 16:14:22 polisy kernel: ada0: <SATA SSD SBFM61.2> ACS-4 ATA SATA 3.x device
Aug  2 16:14:22 polisy kernel: ada0: Serial Number B5950797063401318965
Aug  2 16:14:22 polisy kernel: ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Aug  2 16:14:22 polisy kernel: ada0: Command Queueing enabled
Aug  2 16:14:22 polisy kernel: ada0: 30533MB (62533296 512 byte sectors)
Aug  2 16:14:22 polisy kernel: Trying to mount root from zfs:zudi/ROOT/default []...
Aug  2 16:14:22 polisy kernel: uhub0: 2 ports with 2 removable, self powered
Aug  2 16:14:22 polisy kernel: Root mount waiting for: usbus1
Aug  2 16:14:22 polisy kernel: ugen1.2: <vendor 0x0438 product 0x7900> at usbus1
Aug  2 16:14:22 polisy kernel: uhub2 on uhub0
Aug  2 16:14:22 polisy kernel: uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
Aug  2 16:14:22 polisy kernel: uhub2: 4 ports with 4 removable, self powered
Aug  2 16:14:22 polisy kernel: ugen1.3: <vendor 0x0cf3 product 0xe003> at usbus1
Aug  2 16:14:22 polisy kernel: apuled0: <APU2> at iomem 0xfed81610-0xfed8161b,0xfed81664-0xfed81667 on isa0
Aug  2 16:14:22 polisy kernel: resetsw0: <UDXRSW-2> at iomem 0xfed81664-0xfed81667 on isa0
Aug  2 16:14:22 polisy kernel: lo0: link state changed to UP
Aug  2 16:14:22 polisy kernel: ubt0 on uhub2
Aug  2 16:14:22 polisy kernel: ubt0: <vendor 0x0cf3 product 0xe003, class 224/1, rev 1.10/0.02, addr 3> on usbus1
Aug  2 16:14:22 polisy kernel: igb0: link state changed to UP
Aug  2 16:14:22 polisy kernel: WARNING: attempt to domain_add(bluetooth) after domainfinalize()
Aug  2 16:14:22 polisy kernel: WARNING: attempt to domain_add(netgraph) after domainfinalize()
Aug  2 16:14:23 polisy kernel: Security policy loaded: MAC/ntpd (mac_ntpd)
Aug  2 16:14:23 polisy ntpd[981]: ntpd 4.2.8p12-a (1): Starting
Aug  2 16:14:23 polisy ntpd[982]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): good hash signature
Aug  2 16:14:23 polisy ntpd[982]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): loaded, expire=2019-12-28T00:00:00Z last=2017-01-01T00:00:00Z ofs=37
Aug  2 16:14:23 polisy ntpd[982]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): expired less than 219 days ago
Aug  2 16:14:31 polisy pkg[1105]: libwebsockets-2.4.2_1 deinstalled
Aug  2 16:14:31 polisy pkg[1125]: flashrom-1.2 deinstalled
Aug  2 16:14:41 polisy pkg[1183]: py37-multidict-4.7.6 installed
Aug  2 16:14:41 polisy pkg[1183]: py37-typing-extensions-3.7.4.2 installed
Aug  2 16:14:41 polisy pkg[1183]: py37-yarl-1.5.0 installed
Aug  2 16:14:41 polisy pkg[1183]: py37-attrs-19.3.0 installed
Aug  2 16:14:41 polisy pkg[1183]: py37-async_timeout-3.0.1 installed
Aug  2 16:14:42 polisy pkg[1183]: py37-aiohttp-3.5.4 installed
Aug  2 16:14:46 polisy reboot[1191]: rebooted by root
Aug  2 16:14:46 polisy syslogd: exiting on signal 15
Aug  2 16:15:40 polisy syslogd: kernel boot file is /boot/kernel/kernel
Aug  2 16:15:40 polisy kernel: ---<<BOOT>>---
Aug  2 16:15:40 polisy kernel: Copyright (c) 1992-2019 The FreeBSD Project.
Aug  2 16:15:40 polisy kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Aug  2 16:15:40 polisy kernel: 	The Regents of the University of California. All rights reserved.
Aug  2 16:15:40 polisy kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Aug  2 16:15:40 polisy kernel: FreeBSD 12.1-RELEASE-p1 r355229 POLISY amd64
Aug  2 16:15:40 polisy kernel: FreeBSD clang version 8.0.1 (tags/RELEASE_801/final 366581) (based on LLVM 8.0.1)
Aug  2 16:15:40 polisy kernel: CPU: AMD GX-412TC SOC                                (998.15-MHz K8-class CPU)
Aug  2 16:15:40 polisy kernel:   Origin="AuthenticAMD"  Id=0x730f01  Family=0x16  Model=0x30  Stepping=1
Aug  2 16:15:40 polisy kernel:   Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Aug  2 16:15:40 polisy kernel:   Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
Aug  2 16:15:40 polisy kernel:   AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
Aug  2 16:15:40 polisy kernel:   AMD Features2=0x1d4037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PTSC,PL2I>
Aug  2 16:15:40 polisy kernel:   Structured Extended Features=0x8<BMI1>
Aug  2 16:15:40 polisy kernel:   XSAVE Features=0x1<XSAVEOPT>
Aug  2 16:15:40 polisy kernel:   SVM: NP,NRIP,AFlush,DAssist,NAsids=8
Aug  2 16:15:40 polisy kernel:   TSC: P-state invariant, performance statistics
Aug  2 16:15:40 polisy kernel: real memory  = 4294967296 (4096 MB)
Aug  2 16:15:40 polisy kernel: avail memory = 4102766592 (3912 MB)
Aug  2 16:15:40 polisy kernel: Event timer "LAPIC" quality 600
Aug  2 16:15:40 polisy kernel: ACPI APIC Table: <COREv4 COREBOOT>
Aug  2 16:15:40 polisy kernel: FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Aug  2 16:15:40 polisy kernel: FreeBSD/SMP: 1 package(s) x 4 core(s)
Aug  2 16:15:40 polisy kernel: random: unblocking device.
Aug  2 16:15:40 polisy kernel: ioapic1: Changing APIC ID to 5
Aug  2 16:15:40 polisy kernel: ioapic0 <Version 2.1> irqs 0-23 on motherboard
Aug  2 16:15:40 polisy kernel: ioapic1 <Version 2.1> irqs 24-55 on motherboard
Aug  2 16:15:40 polisy kernel: Launching APs: 2 1 3
Aug  2 16:15:40 polisy kernel: Timecounter "TSC" frequency 998149468 Hz quality 1000
Aug  2 16:15:40 polisy kernel: random: entropy device external interface
Aug  2 16:15:40 polisy kernel: [ath_hal] loaded
Aug  2 16:15:40 polisy kernel: 000.000042 [4335] netmap_init               netmap: loaded module
Aug  2 16:15:40 polisy kernel: nexus0
Aug  2 16:15:40 polisy kernel: aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS> on motherboard
Aug  2 16:15:40 polisy kernel: cryptosoft0: <software crypto> on motherboard
Aug  2 16:15:40 polisy kernel: acpi0: <COREv4 COREBOOT> on motherboard
Aug  2 16:15:40 polisy kernel: acpi0: Power Button (fixed)
Aug  2 16:15:40 polisy kernel: cpu0: <ACPI CPU> on acpi0
Aug  2 16:15:40 polisy kernel: atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Aug  2 16:15:40 polisy kernel: atrtc0: registered as a time-of-day clock, resolution 1.000000s
Aug  2 16:15:40 polisy kernel: Event timer "RTC" frequency 32768 Hz quality 0
Aug  2 16:15:40 polisy kernel: attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Aug  2 16:15:40 polisy kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Aug  2 16:15:40 polisy kernel: Event timer "i8254" frequency 1193182 Hz quality 100
Aug  2 16:15:40 polisy kernel: hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Aug  2 16:15:40 polisy kernel: Timecounter "HPET" frequency 14318180 Hz quality 950
Aug  2 16:15:40 polisy kernel: Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
Aug  2 16:15:40 polisy kernel: acpi_timer0: <32-bit timer at 3.579545MHz> port 0x818-0x81b on acpi0
Aug  2 16:15:40 polisy kernel: acpi_button0: <Power Button> on acpi0
Aug  2 16:15:40 polisy kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Aug  2 16:15:40 polisy kernel: pci0: <ACPI PCI bus> on pcib0
Aug  2 16:15:40 polisy kernel: pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
Aug  2 16:15:40 polisy kernel: pcib1: <ACPI PCI-PCI bridge> irq 24 at device 2.1 on pci0
Aug  2 16:15:40 polisy kernel: pci1: <ACPI PCI bus> on pcib1
Aug  2 16:15:40 polisy kernel: ath0: <Atheros AR946x/AR948x> mem 0xf7900000-0xf797ffff irq 24 at device 0.0 on pci1
Aug  2 16:15:40 polisy kernel: ar9300_flash_map: unimplemented for now
Aug  2 16:15:40 polisy kernel: Restoring Cal data from DRAM
Aug  2 16:15:40 polisy kernel: Restoring Cal data from EEPROM
Aug  2 16:15:40 polisy kernel: Restoring Cal data from Flash
Aug  2 16:15:40 polisy syslogd: last message repeated 1 times
Aug  2 16:15:40 polisy kernel: Restoring Cal data from OTP
Aug  2 16:15:40 polisy kernel: ar9300_hw_attach: ar9300_eeprom_attach returned 0
Aug  2 16:15:40 polisy kernel: ath0: Enabling WB222 BTCOEX
Aug  2 16:15:40 polisy kernel: ath0: [HT] enabling HT modes
Aug  2 16:15:40 polisy kernel: ath0: [HT] enabling short-GI in 20MHz mode
Aug  2 16:15:40 polisy kernel: ath0: [HT] 1 stream STBC receive enabled
Aug  2 16:15:40 polisy kernel: ath0: [HT] 1 stream STBC transmit enabled
Aug  2 16:15:40 polisy kernel: ath0: [HT] LDPC transmit/receive enabled
Aug  2 16:15:40 polisy kernel: ath0: [HT] 2 RX streams; 2 TX streams
Aug  2 16:15:40 polisy kernel: ath0: AR9460 mac 640.2 RF5110 phy 817.0
Aug  2 16:15:40 polisy kernel: ath0: 2GHz radio: 0x0000; 5GHz radio: 0x0000
Aug  2 16:15:40 polisy kernel: pcib2: <ACPI PCI-PCI bridge> irq 25 at device 2.2 on pci0
Aug  2 16:15:40 polisy kernel: pcib2: failed to allocate initial I/O port window: 0x1000-0x1fff
Aug  2 16:15:40 polisy kernel: pci2: <ACPI PCI bus> on pcib2
Aug  2 16:15:40 polisy kernel: igb0: <Intel(R) PRO/1000 PCI-Express Network Driver> mem 0xf7a00000-0xf7a1ffff,0xf7a20000-0xf7a23fff irq 28 at device 0.0 on pci2
Aug  2 16:15:40 polisy kernel: igb0: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:15:40 polisy kernel: igb0: Using 4 RX queues 4 TX queues
Aug  2 16:15:40 polisy kernel: igb0: Using MSI-X interrupts with 5 vectors
Aug  2 16:15:40 polisy kernel: igb0: Ethernet address: 00:0d:b9:53:c7:c8
Aug  2 16:15:40 polisy kernel: igb0: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:15:40 polisy kernel: pcib3: <ACPI PCI-PCI bridge> irq 26 at device 2.3 on pci0
Aug  2 16:15:40 polisy kernel: pci3: <ACPI PCI bus> on pcib3
Aug  2 16:15:40 polisy kernel: igb1: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x2000-0x201f mem 0xf7b00000-0xf7b1ffff,0xf7b20000-0xf7b23fff irq 32 at device 0.0 on pci3
Aug  2 16:15:40 polisy kernel: igb1: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:15:40 polisy kernel: igb1: Using 4 RX queues 4 TX queues
Aug  2 16:15:40 polisy kernel: igb1: Using MSI-X interrupts with 5 vectors
Aug  2 16:15:40 polisy kernel: igb1: Ethernet address: 00:0d:b9:53:c7:c9
Aug  2 16:15:40 polisy kernel: igb1: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:15:40 polisy kernel: pcib4: <ACPI PCI-PCI bridge> irq 27 at device 2.4 on pci0
Aug  2 16:15:40 polisy kernel: pci4: <ACPI PCI bus> on pcib4
Aug  2 16:15:40 polisy kernel: igb2: <Intel(R) PRO/1000 PCI-Express Network Driver> port 0x3000-0x301f mem 0xf7c00000-0xf7c1ffff,0xf7c20000-0xf7c23fff irq 36 at device 0.0 on pci4
Aug  2 16:15:40 polisy kernel: igb2: Using 1024 TX descriptors and 1024 RX descriptors
Aug  2 16:15:40 polisy kernel: igb2: Using 4 RX queues 4 TX queues
Aug  2 16:15:40 polisy kernel: igb2: Using MSI-X interrupts with 5 vectors
Aug  2 16:15:40 polisy kernel: igb2: Ethernet address: 00:0d:b9:53:c7:ca
Aug  2 16:15:40 polisy kernel: igb2: netmap queues/slots: TX 4/1024, RX 4/1024
Aug  2 16:15:40 polisy kernel: pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
Aug  2 16:15:40 polisy kernel: xhci0: <AMD FCH USB 3.0 controller> mem 0xf7fa2000-0xf7fa3fff irq 18 at device 16.0 on pci0
Aug  2 16:15:40 polisy kernel: xhci0: 32 bytes context size, 64-bit DMA
Aug  2 16:15:40 polisy kernel: xhci0: Unable to map MSI-X table
Aug  2 16:15:40 polisy kernel: usbus0 on xhci0
Aug  2 16:15:40 polisy kernel: usbus0: 5.0Gbps Super Speed USB v3.0
Aug  2 16:15:40 polisy kernel: ahci0: <AMD Hudson-2 AHCI SATA controller> port 0x4010-0x4017,0x4020-0x4023,0x4018-0x401f,0x4024-0x4027,0x4000-0x400f mem 0xf7fa5000-0xf7fa53ff at device 17.0 on pci0
Aug  2 16:15:40 polisy kernel: ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported with FBS
Aug  2 16:15:40 polisy kernel: ahcich0: <AHCI channel> at channel 0 on ahci0
Aug  2 16:15:40 polisy kernel: ahcich1: <AHCI channel> at channel 1 on ahci0
Aug  2 16:15:40 polisy kernel: ehci0: <AMD FCH USB 2.0 controller> mem 0xf7fa6000-0xf7fa60ff irq 18 at device 19.0 on pci0
Aug  2 16:15:40 polisy kernel: usbus1: EHCI version 1.0
Aug  2 16:15:40 polisy kernel: usbus1 on ehci0
Aug  2 16:15:40 polisy kernel: usbus1: 480Mbps High Speed USB v2.0
Aug  2 16:15:40 polisy kernel: intsmb0: <AMD FCH SMBus Controller> at device 20.0 on pci0
Aug  2 16:15:40 polisy kernel: smbus0: <System Management Bus> on intsmb0
Aug  2 16:15:40 polisy kernel: smb0: <SMBus generic I/O> on smbus0
Aug  2 16:15:40 polisy kernel: isab0: <PCI-ISA bridge> at device 20.3 on pci0
Aug  2 16:15:40 polisy kernel: isa0: <ISA bus> on isab0
Aug  2 16:15:40 polisy kernel: sdhci_pci0: <Generic SD HCI> mem 0xf7fa7000-0xf7fa70ff at device 20.7 on pci0
Aug  2 16:15:40 polisy kernel: sdhci_pci0: 1 slot(s) allocated
Aug  2 16:15:40 polisy kernel: amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb5
Aug  2 16:15:40 polisy kernel: uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 on acpi0
Aug  2 16:15:40 polisy kernel: uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 flags 0x10 on acpi0
Aug  2 16:15:40 polisy kernel: uart1: console (115200,n,8,1)
Aug  2 16:15:40 polisy kernel: tpm0: <Trusted Platform Module> port 0xc31-0xc32 iomem 0xfed40000-0xfed44fff on acpi0
Aug  2 16:15:40 polisy kernel: tpm: device 0x001a15d1 rev 0x10
Aug  2 16:15:40 polisy kernel: gpio0: <Nuvoton NCT5104D (PC-Engines APU3)> at port 0x2e-0x2f on isa0
Aug  2 16:15:40 polisy kernel: gpiobus0: <GPIO bus> on gpio0
Aug  2 16:15:40 polisy kernel: gpioc0: <GPIO controller> on gpio0
Aug  2 16:15:40 polisy kernel: orm0: <ISA Option ROM> at iomem 0xee800-0xeffff pnpid ORM0000 on isa0
Aug  2 16:15:40 polisy kernel: hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Aug  2 16:15:40 polisy kernel: ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
Aug  2 16:15:40 polisy kernel:             to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Aug  2 16:15:40 polisy kernel: ZFS filesystem version: 5
Aug  2 16:15:40 polisy kernel: ZFS storage pool version: features support (5000)
Aug  2 16:15:40 polisy kernel: Timecounters tick every 1.000 msec
Aug  2 16:15:40 polisy kernel: ugen1.1: <AMD EHCI root HUB> at usbus1
Aug  2 16:15:40 polisy kernel: ugen0.1: <0x1022 XHCI root HUB> at usbus0
Aug  2 16:15:40 polisy kernel: uhub0: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Aug  2 16:15:40 polisy kernel: uhub1: <0x1022 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Aug  2 16:15:40 polisy kernel: uhub1: 4 ports with 4 removable, self powered
Aug  2 16:15:40 polisy kernel: ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
Aug  2 16:15:40 polisy kernel: ada0: <SATA SSD SBFM61.2> ACS-4 ATA SATA 3.x device
Aug  2 16:15:40 polisy kernel: ada0: Serial Number B5950797063401318965
Aug  2 16:15:40 polisy kernel: ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Aug  2 16:15:40 polisy kernel: ada0: Command Queueing enabled
Aug  2 16:15:40 polisy kernel: ada0: 30533MB (62533296 512 byte sectors)
Aug  2 16:15:40 polisy kernel: uhub0: 2 ports with 2 removable, self powered
Aug  2 16:15:40 polisy kernel: Trying to mount root from zfs:zudi/ROOT/default []...
Aug  2 16:15:40 polisy kernel: Root mount waiting for: usbus1
Aug  2 16:15:40 polisy kernel: ugen1.2: <vendor 0x0438 product 0x7900> at usbus1
Aug  2 16:15:40 polisy kernel: uhub2 on uhub0
Aug  2 16:15:40 polisy kernel: uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
Aug  2 16:15:40 polisy kernel: uhub2: 4 ports with 4 removable, self powered
Aug  2 16:15:40 polisy kernel: ugen1.3: <vendor 0x0cf3 product 0xe003> at usbus1
Aug  2 16:15:40 polisy kernel: apuled0: <APU2> at iomem 0xfed81610-0xfed8161b,0xfed81664-0xfed81667 on isa0
Aug  2 16:15:40 polisy kernel: resetsw0: <UDXRSW-2> at iomem 0xfed81664-0xfed81667 on isa0
Aug  2 16:15:40 polisy kernel: lo0: link state changed to UP
Aug  2 16:15:40 polisy kernel: ubt0 on uhub2
Aug  2 16:15:40 polisy kernel: ubt0: <vendor 0x0cf3 product 0xe003, class 224/1, rev 1.10/0.02, addr 3> on usbus1
Aug  2 16:15:40 polisy kernel: igb0: link state changed to UP
Aug  2 16:15:40 polisy kernel: WARNING: attempt to domain_add(bluetooth) after domainfinalize()
Aug  2 16:15:40 polisy kernel: WARNING: attempt to domain_add(netgraph) after domainfinalize()
Aug  2 16:15:40 polisy kernel: Security policy loaded: MAC/ntpd (mac_ntpd)
Aug  2 16:15:40 polisy ntpd[965]: ntpd 4.2.8p12-a (1): Starting
Aug  2 16:15:41 polisy ntpd[966]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): good hash signature
Aug  2 16:15:41 polisy ntpd[966]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): loaded, expire=2019-12-28T00:00:00Z last=2017-01-01T00:00:00Z ofs=37
Aug  2 16:15:41 polisy ntpd[966]: leapsecond file ('/var/db/ntpd.leap-seconds.list'): expired less than 219 days ago
Aug  2 16:15:54 polisy reboot[1147]: rebooted by root
Edited by Brad
5 hours ago, Michel Kohanim said:
@Brad,
How many times has it gone through this? Please note that udx process removes unnecessary packages and then installs necessary ones. This might cause the unit to reboot at least once and up to 3 times (if you have an older version).
Several dozen times.  I finally managed to ssh into it long enough to issue a shutdown and I now have it unplugged because I got tired of hearing it beeping.
Should the udx process show what it's doing in the log?
Edited by Brad
@Michel Kohanim It doesn't look like a disk space issue.
admin@polisy:~$ df -h
Filesystem           Size    Used   Avail Capacity  Mounted on
zudi/ROOT/default     25G    1.9G     23G     8%    /
devfs                1.0K    1.0K      0B   100%    /dev
procfs               4.0K    4.0K      0B   100%    /proc
zudi                  23G     23K     23G     0%    /zudi
zudi/tmp              23G     24K     23G     0%    /tmp
zudi/var/db           23G    202M     23G     1%    /var/db
zudi/var/run          23G     47K     23G     0%    /var/run
zudi/usr/home         23G    3.9M     23G     0%    /usr/home
zudi/var/log          23G    434K     23G     0%    /var/log
zudi/var/empty        23G     23K     23G     0%    /var/empty
zudi/var/crash        23G     23K     23G     0%    /var/crash
zudi/var/tmp          23G     23K     23G     0%    /var/tmp
zudi/var/db/pkg       23G    6.9M     23G     0%    /var/db/pkg
The udx logs show quite a few errors.
Is there a way to reset to factory setup?
Edited by Brad
19 minutes ago, Michel Kohanim said:
Hi @Brad,
Yes, but it's best to figure out what's causing it. Can you please send me the udx log to support@universal-devices.com?
Looks like it's a failure to install py37-zeep.
2020-08-02 16:28:09 [34373695744-   Package]  Info: processing py37-zeep
 for install (../src/Config/UDXPkgConfig.cpp@90:processPackage())
2020-08-02 16:28:09 [34373695744-   Package]  Info: installing py37-zeep
 (../src/Config/UDXPkgConfig.cpp@115:processPackage())
2020-08-02 16:28:12 [34373695744-   Package] Error: failed installing py37-zeep
 (../src/Config/UDXPkgConfig.cpp@119:processPackage())
2020-08-02 16:28:12 [34373695744-   Package]  Info: processing udx
2020-08-02 16:28:12 [34373695744-   Package]  Info: udx
 already installed (../src/Config/UDXPkgConfig.cpp@104:processPackage())
2020-08-02 16:28:12 [34373695744- SysConfig]  Info: publish to topic = spolisy/reboot. msg =
{"when":"now"} (../src/System/UDXSysConfig.cpp@655:udxPublishMessage())
2020-08-02 16:28:12 [34373695744-     MQTTc]  Info: MQTTLogEvent level=16, desc=Client mosq-PKCEiFHxgl81IonQAU sending PUBLISH (d0, q0, r0, m6, 'spolisy/reboot', ... (14 bytes)) (../src/System/UDXMQTTc.cpp@590:on_log())
2020-08-02 16:28:12 [34373695744-     Audio] Debug: writing "cc"-2 bytes to speaker (../src/Device/Audio/UDXSpeaker.cpp@35:set())
2020-08-02 16:28:12 [34373698304-     MQTTc]  Info: published 6 (../src/System/UDXMQTTc.cpp@547:on_publish())
2020-08-02 16:28:13 [34373695744-   ResetSW]  Info: reboot requested (../src/System/UDXResetHandler.cpp@140:reboot())
I'll send the entire log as requested
@Michel Kohanim -a is an invalid option
admin@polisy:~$ hostname -a
hostname: illegal option -- a
usage: hostname [-f] [-s | -d] [name-of-host]
Upon logging in via ssh, I get
Edited by Brad
FreeBSD polisy 12.1-RELEASE-p1 FreeBSD 12.1-RELEASE-p1 r355229 POLISY  amd64
admin@polisy:~$ sudo pkg install p37-zeep
Password:
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
pkg: No packages available to install matching 'p37-zeep' have been found in the repositories
admin@polisy:~$ Connection to polisy closed by remote host.
Connection to polisy closed.
oh wait.  typo in package name
Edited by Brad
Same thing
admin@polisy:~$ sudo pkg install py37-zeep
Password:
pkg: No packages available to install matching 'py37-zeep' have been found in the repositories
I don't believe so. Here's the conf file
admin@polisy:~$ sudo cat /etc/pkg/FreeBSD.conf
Password:
# $FreeBSD: releng/12.1/usr.sbin/pkg/FreeBSD.conf.quarterly 346780 2019-04-27 04:00:50Z cperciva $
# To disable this repository, instead of modifying or removing this file,
# create a /usr/local/etc/pkg/repos/FreeBSD.conf file:
#   mkdir -p /usr/local/etc/pkg/repos
#   echo "FreeBSD: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf
FreeBSD: {
  url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly",
  mirror_type: "srv",
  signature_type: "fingerprints",
  fingerprints: "/usr/share/keys/pkg",
  enabled: yes
