ISY99 locking up...
kevincol
I have been on 2.7.6 FW for my ISY 99 for some time now. However, over the last couple weeks, it has stopped working (i.e. lights won't turn on, i can't see it on the network). I unplug it and plug it back in and then it starts working again. It's to the point that I have to reboot it every two days to keep it working.
Any ideas on what could be going on as I haven't changed anything in the last two weeks and I rarely had this behavior over the 1.5 yrs that I have been using it.
When you reset are you unplugging the PLM? If so would you try by disconnecting the cable between the PLM and the ISY? That will tell us if it is the PLM of the ISY locking up.
Rand
I am currently unplugging the PLM and nothing else. I will also try disconnecting the cable between the two.
Rand
Hi kevincol,
Please let me know what version of PLM you have + please send your log file to support@universal-devices.com
Rand
I tried disconnecting the cable between the PLM and the ISY also. It still is locked up.
Rand
Hello kevincol,
Is it now locked up all the time (not every 2 days)? If so, can you tell me the status of the LED lights on the front panel?
Would you be kind enough to contact our tech support to schedule a tech support call? We can login remotely and diagnose the problems.
Rand
Hi Joe,
Got it and responded to you ... please do make sure you have 2.7.6 installed.
Very similar problem, AND not showing status correctly most of the time. Have sent log file and info to support at universal-devices.com. Thanks.
Joe
