simplextech Posted October 16, 2020 Author Share Posted October 16, 2020 Just now, Bumbershoot said: Thanks so much for your work on this. Restarted, and I'll keep watching it. Thanks to you and everyone else for testing and having patience on these issues. I know they are annoying those of you using the NS. Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 16, 2020 Share Posted October 16, 2020 13 hours ago, simplextech said: Thanks to you and everyone else for testing and having patience on these issues. I know they are annoying those of you using the NS. Well it's not like the nodeserver is overpriced Happy to help iron out the kinks. This nodeserver will be hugely popular. Incidentally, I just received a new SOnos component (a Sonos Port). At some point this weekend, I'm going to add it to my system AND upgrade from S1 to S2. I'm sure I restart will be in order but, if there's anything special you want me to track or observe, let me know. Link to comment Share on other sites More sharing options...
simplextech Posted October 16, 2020 Author Share Posted October 16, 2020 4 hours ago, bcdavis75 said: I just received a new SOnos component (a Sonos Port) I don't have one of those so I've not doing any testing around it. It currently (likely) won't show up as a node for anything but I'm wondering if it's possible. I'll have to look at the API again and see if there's anything available. Link to comment Share on other sites More sharing options...
glarsen Posted October 16, 2020 Share Posted October 16, 2020 4 minutes ago, simplextech said: I don't have one of those so I've not doing any testing around it. It currently (likely) won't show up as a node for anything but I'm wondering if it's possible. I'll have to look at the API again and see if there's anything available. I have one and it works fine. Link to comment Share on other sites More sharing options...
simplextech Posted October 16, 2020 Author Share Posted October 16, 2020 9 minutes ago, glarsen said: I have one and it works fine. "works"? As in how? I didn't code anything specific for the port so I don't know if/how it shows up as nodes or anything. Link to comment Share on other sites More sharing options...
glarsen Posted October 16, 2020 Share Posted October 16, 2020 2 minutes ago, simplextech said: "works"? As in how? I didn't code anything specific for the port so I don't know if/how it shows up as nodes or anything. It appears as a player in the nodeserver: and like this in the AC: It is part of a group and behaves just as the old ZonePlayer did. Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 16, 2020 Share Posted October 16, 2020 Yeah. Adding was no problem for me. I did a rediscover and Update Profile from the admin console and a few seconds later, the new node appeared. I didn't even have to restart the nodeserver. Link to comment Share on other sites More sharing options...
carealtor Posted October 16, 2020 Share Posted October 16, 2020 I don't have a Port, but I do have several Connects. In fact, that's all I have. They are just another Sonos device. Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 17, 2020 Share Posted October 17, 2020 Well, this should make everyone happy. I replaced my router today. Upgraded from a Unifi USG to a Dream Machine Pro. Doesn't get to. much more disruptive then that BUT... the nodeserver was still working just fine when I finally had a network again. No restart required. Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 18, 2020 Share Posted October 18, 2020 Hi @simplextech, I thought you might be interested to know that the nodeserver survived this string of errors. I was able to successfully play, change volume, etc., after the errors occurred. Thanks again! 2020-10-18 20:44:05,669 [MQTT ] [DEBUG] Recieved Message: config 2020-10-18 20:44:05,732 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': 'roZHbM9lq6', 'development': False, 'userId': '569cdd4a92cbdbfb2ce7da16', 'isyVersion': '5.2.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1NjljZGQ0YTkyY2JkYmZiMmNlN2RhMTYiLCJpZCI6IjAwOjIxOmI5OjAyOjJhOmZhIiwicHJvZmlsZU51bSI6MTQsInBhc3N3b3JkIjoicm9aSGJNOWxxNiJ9', 'timeAdded': 1598755682280, 'id': '00:21:b9:02:2a:fa', 'shortPoll': '60', 'timeStarted': 1602953045157, 'version': '0.2.00', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1598755697416, 'timeStarted': 0}, 'g347e5cd1c390': {'address': 'g347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '326.875398ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'g48a6b845abe8': {'address': 'g48a6b845abe8', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'value': '30', 'uom': '51'}}, 'elapsed': '525.788069ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Master Bedroom', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953061020, 'timeStarted': 0}, 'g949f3e1ec6c0': {'address': 'g949f3e1ec6c0', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '70.330043ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953068258, 'timeStarted': 0}, 'g949f3e1ed682': {'address': 'g949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '422.555539ms', 'timeAdded': 1602953061020, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'gb8e93778812a': {'address': 'gb8e93778812a', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '223.301972ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953055615, 'timeStarted': 0}, 'groups': {'address': 'groups', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '123.184499ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': True, 'name': 'Sonos Groups', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'p347e5cd1c390': {'address': 'p347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '528.814ms', 'timeAdded': 1602953068259, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p48a6b845abe8': {'address': 'p48a6b845abe8', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '329.056957ms', 'timeAdded': 1602953075744, 'success': False, 'isPrimary': False, 'name': 'Sonos Master Bedroom', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '30', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p949f3e1ec6c0': {'address': 'p949f3e1ec6c0', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '231.961929ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953075744, 'timeStarted': 0}, 'p949f3e1ed682': {'address': 'p949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '284.250971ms', 'timeAdded': 1602953070977, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'pb8e93778812a': {'address': 'pb8e93778812a', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '513.485641ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953070977, 'timeStarted': 0}, 'players': {'address': 'players', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '313.925124ms', 'timeAdded': 1602953068258, 'success': False, 'isPrimary': True, 'name': 'Sonos Players', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'zRnLdjeQtPOnToghhtDkqQpxFx5Z', 'refresh_token': 'IAYegHqnO14cmLOFVvL3HKceA1TKgdus', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'SAY_TTS-10': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-1': 'Someone is at the front door', 'language': 'en-us', 'SAY_TTS-4': 'Someone is at the side door by the garage', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'Brad is arriving', 'SAY_TTS-3': 'Someone is on the deck', 'codec': 'mp3', 'api_key': '79d231a856ed4e37b3d17d9ff39524a5'}, 'profileNum': '14', 'notices': {}, 'worker': 'sonoscontroller-0021b9022afa-14', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-18 20:44:05,733 [MQTT ] [DEBUG] Recieved Message: config 2020-10-18 21:19:05,588 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'command': {'address': 'p347e5cd1c390', 'cmd': 'SAYTTS', 'value': '2', 'uom': '25', 'query': {}}} 2020-10-18 21:19:05,589 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'p347e5cd1c390', 'cmd': 'SAYTTS', 'value': '2', 'uom': '25', 'query': {}}} 2020-10-18 21:19:05,590 [Controller] [INFO ] Sending to VoiceRSS for Player: RINCON_347E5CD1C39001400 2020-10-18 21:19:05,599 [Controller] [DEBUG] VoiceRSS Payload: {'name': 'Sonos TTS', 'appId': 'net.simplextech', 'streamUrl': 'http://api.voicerss.org/?key=79d231a856ed4e37b3d17d9ff39524a5&hl=en-us&c=mp3&f=24khz_16bit_stereo&src=Brad%20is%20arriving', 'clipType': 'CUSTOM', 'priority': 'high'} 2020-10-18 21:19:06,010 [Controller] [DEBUG] Success: b'{"id":"ea41a4ce-41c4-4a4a-9c2b-f1931ca21a98","name":"Sonos TTS","appId":"net.simplextech","priority":"HIGH","clipType":"CUSTOM","status":"INACTIVE"}' 2020-10-18 21:19:06,010 [Controller] [INFO ] send_say_tts: True 2020-10-18 21:47:17,897 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:47:17,898 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:47:28,358 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:47:28,359 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:48:18,005 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:48:18,006 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:48:21,848 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:48:21,849 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:49:17,982 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:49:17,982 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:49:28,363 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:49:28,364 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:50:18,015 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:50:18,015 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:50:21,771 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:50:21,772 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:51:10,796 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:51:10,796 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:51:14,081 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:51:14,082 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:52:10,839 [Controller] [ERROR] Error sonos_control.get_groups 2020-10-18 21:52:10,840 [Controller] [ERROR] shortPoll:sonos_groups: Sonos Groups is None 2020-10-18 21:52:14,162 [Controller] [ERROR] Error sonos_control.get_players 2020-10-18 21:52:14,180 [Controller] [ERROR] shortPoll: SonosControl.get_players is None 2020-10-18 21:53:11,316 [Controller] [ERROR] shortPoll:group_volume: None 2020-10-18 21:53:11,530 [Controller] [ERROR] shortPoll:group_volume: None 2020-10-18 21:53:19,746 [Controller] [ERROR] shortPoll: SonosControl.get_player_volume is None 2020-10-18 21:53:23,421 [Controller] [ERROR] shortPoll: SonosControl.get_player_volume is None 2020-10-18 21:54:08,449 [Controller] [ERROR] shortPoll:group_volume: None 2020-10-18 21:54:12,392 [Controller] [ERROR] shortPoll:group_volume: None 2020-10-18 21:57:08,465 [Controller] [ERROR] shortPoll:group_volume: None 2020-10-18 22:44:06,419 [Controller] [INFO ] Sending customData to Polyglot. 2020-10-18 22:44:06,419 [Controller] [DEBUG] Sent Message: [prod/ns] : {"customdata": {"access_token": "3Aueb15H6XOUI0KGVmaKHUvr9BRy", "refresh_token": "IAYegHqnO14cmLOFVvL3HKceA1TKgdus", "expires_in": 86399}, "userId": "569cdd4a92cbdbfb2ce7da16", "topic": "prod/ns/sonoscontroller-0021b9022afa-14", "profileNum": "14", "id": "00:21:b9:02:2a:fa"} 2020-10-18 22:44:06,420 [Controller] [INFO ] Sending notices to Polyglot. 2020-10-18 22:44:06,420 [Controller] [DEBUG] Sent Message: [prod/ns] : {"notices": {}, "userId": "569cdd4a92cbdbfb2ce7da16", "topic": "prod/ns/sonoscontroller-0021b9022afa-14", "profileNum": "14", "id": "00:21:b9:02:2a:fa"} 2020-10-18 22:44:06,712 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': 'roZHbM9lq6', 'development': False, 'userId': '569cdd4a92cbdbfb2ce7da16', 'isyVersion': '5.2.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1NjljZGQ0YTkyY2JkYmZiMmNlN2RhMTYiLCJpZCI6IjAwOjIxOmI5OjAyOjJhOmZhIiwicHJvZmlsZU51bSI6MTQsInBhc3N3b3JkIjoicm9aSGJNOWxxNiJ9', 'timeAdded': 1598755682280, 'id': '00:21:b9:02:2a:fa', 'shortPoll': '60', 'timeStarted': 1602953045157, 'version': '0.2.00', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1598755697416, 'timeStarted': 0}, 'g347e5cd1c390': {'address': 'g347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '326.875398ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'g48a6b845abe8': {'address': 'g48a6b845abe8', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'value': '30', 'uom': '51'}}, 'elapsed': '525.788069ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Master Bedroom', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953061020, 'timeStarted': 0}, 'g949f3e1ec6c0': {'address': 'g949f3e1ec6c0', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '70.330043ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953068258, 'timeStarted': 0}, 'g949f3e1ed682': {'address': 'g949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '422.555539ms', 'timeAdded': 1602953061020, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'gb8e93778812a': {'address': 'gb8e93778812a', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '223.301972ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953055615, 'timeStarted': 0}, 'groups': {'address': 'groups', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '123.184499ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': True, 'name': 'Sonos Groups', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'p347e5cd1c390': {'address': 'p347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '528.814ms', 'timeAdded': 1602953068259, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p48a6b845abe8': {'address': 'p48a6b845abe8', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '329.056957ms', 'timeAdded': 1602953075744, 'success': False, 'isPrimary': False, 'name': 'Sonos Master Bedroom', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '30', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p949f3e1ec6c0': {'address': 'p949f3e1ec6c0', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '231.961929ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953075744, 'timeStarted': 0}, 'p949f3e1ed682': {'address': 'p949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '284.250971ms', 'timeAdded': 1602953070977, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'pb8e93778812a': {'address': 'pb8e93778812a', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '513.485641ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953070977, 'timeStarted': 0}, 'players': {'address': 'players', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '313.925124ms', 'timeAdded': 1602953068258, 'success': False, 'isPrimary': True, 'name': 'Sonos Players', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': '3Aueb15H6XOUI0KGVmaKHUvr9BRy', 'refresh_token': 'IAYegHqnO14cmLOFVvL3HKceA1TKgdus', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'SAY_TTS-10': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-1': 'Someone is at the front door', 'language': 'en-us', 'SAY_TTS-4': 'Someone is at the side door by the garage', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'Brad is arriving', 'SAY_TTS-3': 'Someone is on the deck', 'codec': 'mp3', 'api_key': '79d231a856ed4e37b3d17d9ff39524a5'}, 'profileNum': '14', 'notices': {}, 'worker': 'sonoscontroller-0021b9022afa-14', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-18 22:44:06,713 [MQTT ] [DEBUG] Recieved Message: config 2020-10-18 22:44:06,758 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': 'roZHbM9lq6', 'development': False, 'userId': '569cdd4a92cbdbfb2ce7da16', 'isyVersion': '5.2.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1NjljZGQ0YTkyY2JkYmZiMmNlN2RhMTYiLCJpZCI6IjAwOjIxOmI5OjAyOjJhOmZhIiwicHJvZmlsZU51bSI6MTQsInBhc3N3b3JkIjoicm9aSGJNOWxxNiJ9', 'timeAdded': 1598755682280, 'id': '00:21:b9:02:2a:fa', 'shortPoll': '60', 'timeStarted': 1602953045157, 'version': '0.2.00', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1598755697416, 'timeStarted': 0}, 'g347e5cd1c390': {'address': 'g347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '326.875398ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'g48a6b845abe8': {'address': 'g48a6b845abe8', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'value': '30', 'uom': '51'}}, 'elapsed': '525.788069ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Master Bedroom', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953061020, 'timeStarted': 0}, 'g949f3e1ec6c0': {'address': 'g949f3e1ec6c0', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '70.330043ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953068258, 'timeStarted': 0}, 'g949f3e1ed682': {'address': 'g949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '422.555539ms', 'timeAdded': 1602953061020, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'gb8e93778812a': {'address': 'gb8e93778812a', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '223.301972ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953055615, 'timeStarted': 0}, 'groups': {'address': 'groups', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '123.184499ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': True, 'name': 'Sonos Groups', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'p347e5cd1c390': {'address': 'p347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '528.814ms', 'timeAdded': 1602953068259, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p48a6b845abe8': {'address': 'p48a6b845abe8', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '329.056957ms', 'timeAdded': 1602953075744, 'success': False, 'isPrimary': False, 'name': 'Sonos Master Bedroom', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '30', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p949f3e1ec6c0': {'address': 'p949f3e1ec6c0', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '231.961929ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953075744, 'timeStarted': 0}, 'p949f3e1ed682': {'address': 'p949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '284.250971ms', 'timeAdded': 1602953070977, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'pb8e93778812a': {'address': 'pb8e93778812a', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '513.485641ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953070977, 'timeStarted': 0}, 'players': {'address': 'players', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '313.925124ms', 'timeAdded': 1602953068258, 'success': False, 'isPrimary': True, 'name': 'Sonos Players', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': '3Aueb15H6XOUI0KGVmaKHUvr9BRy', 'refresh_token': 'IAYegHqnO14cmLOFVvL3HKceA1TKgdus', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'SAY_TTS-10': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-1': 'Someone is at the front door', 'language': 'en-us', 'SAY_TTS-4': 'Someone is at the side door by the garage', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'Brad is arriving', 'SAY_TTS-3': 'Someone is on the deck', 'codec': 'mp3', 'api_key': '79d231a856ed4e37b3d17d9ff39524a5'}, 'profileNum': '14', 'notices': {}, 'worker': 'sonoscontroller-0021b9022afa-14', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-18 22:44:06,758 [MQTT ] [DEBUG] Recieved Message: config 2020-10-18 23:30:54,772 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'command': {'address': 'g949f3e1ec6c0', 'cmd': 'PLAY', 'query': {}}} 2020-10-18 23:30:54,774 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g949f3e1ec6c0', 'cmd': 'PLAY', 'query': {}}} 2020-10-18 23:30:57,630 [Controller] [INFO ] Updating Driver g949f3e1ec6c0 - ST: 1 uom: 25 2020-10-18 23:30:59,262 [Drivers ] [DEBUG] Sent Message: [prod/ns] : {"batch": {"status": [{"address": "g949f3e1ec6c0", "driver": "ST", "value": "1", "uom": "25"}]}, "userId": "569cdd4a92cbdbfb2ce7da16", "topic": "prod/ns/sonoscontroller-0021b9022afa-14", "profileNum": "14", "id": "00:21:b9:02:2a:fa"} , 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '223.301972ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953055615, 'timeStarted': 0}, 'groups': {'address': 'groups', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '123.184499ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': True, 'name': 'Sonos Groups', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'p347e5cd1c390': {'address': 'p347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '528.814ms', 'timeAdded': 1602953068259, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p48a6b845abe8': {'address': 'p48a6b845abe8', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '329.056957ms', 'timeAdded': 1602953075744, 'success': False, 'isPrimary': False, 'name': 'Sonos Master Bedroom', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '30', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'p949f3e1ec6c0': {'address': 'p949f3e1ec6c0', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '231.961929ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953075744, 'timeStarted': 0}, 'p949f3e1ed682': {'address': 'p949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '284.250971ms', 'timeAdded': 1602953070977, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PLAYER', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}, 'SAYTTS': {'value': '0', 'uom': '25'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}, 'pb8e93778812a': {'address': 'pb8e93778812a', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '12'}}, 'elapsed': '513.485641ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Media Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953070977, 'timeStarted': 0}, 'players': {'address': 'players', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '313.925124ms', 'timeAdded': 1602953068258, 'success': False, 'isPrimary': True, 'name': 'Sonos Players', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'PARENT', 'drivers': {'ST': {'value': '1', 'uom': '2'}}, 'seq': False, 'primary': 'players', 'statusCode': 400}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': '3Aueb15H6XOUI0KGVmaKHUvr9BRy', 'refresh_token': 'IAYegHqnO14cmLOFVvL3HKceA1TKgdus', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'SAY_TTS-10': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-1': 'Someone is at the front door', 'language': 'en-us', 'SAY_TTS-4': 'Someone is at the side door by the garage', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'Brad is arriving', 'SAY_TTS-3': 'Someone is on the deck', 'codec': 'mp3', 'api_key': '79d231a856ed4e37b3d17d9ff39524a5'}, 'profileNum': '14', 'notices': {}, 'worker': 'sonoscontroller-0021b9022afa-14', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-18 23:31:00,073 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': 'roZHbM9lq6', 'development': False, 'userId': '569cdd4a92cbdbfb2ce7da16', 'isyVersion': '5.2.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1NjljZGQ0YTkyY2JkYmZiMmNlN2RhMTYiLCJpZCI6IjAwOjIxOmI5OjAyOjJhOmZhIiwicHJvZmlsZU51bSI6MTQsInBhc3N3b3JkIjoicm9aSGJNOWxxNiJ9', 'timeAdded': 1598755682280, 'id': '00:21:b9:02:2a:fa', 'shortPoll': '60', 'timeStarted': 1602953045157, 'version': '0.2.00', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1598755697416, 'timeStarted': 0}, 'g347e5cd1c390': {'address': 'g347e5cd1c390', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '326.875398ms', 'timeAdded': 1602953055615, 'success': False, 'isPrimary': False, 'name': 'Sonos Livivg Room', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '40', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'g48a6b845abe8': {'address': 'g48a6b845abe8', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '4'}, 'SVOL': {'value': '30', 'uom': '51'}}, 'elapsed': '525.788069ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Master Bedroom', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953061020, 'timeStarted': 0}, 'g949f3e1ec6c0': {'address': 'g949f3e1ec6c0', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '70.330043ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Office', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1602953068258, 'timeStarted': 0}, 'g949f3e1ed682': {'address': 'g949f3e1ed682', 'timeStarted': 0, 'error': False, 'isController': False, 'elapsed': '422.555539ms', 'timeAdded': 1602953061020, 'success': False, 'isPrimary': False, 'name': 'Sonos Kitchen', 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'nodedefid': 'GROUP', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'ST': {'value': '3', 'uom': '25'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'FAV': {'value': '0', 'uom': '25'}, 'GV1': {'value': '0', 'uom': '2'}, 'SVOL': {'value': '34', 'uom': '51'}}, 'seq': False, 'primary': 'groups', 'statusCode': 400}, 'gb8e93778812a': {'address': 'gb8e93778812a', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'value': '0', 'uom': '2'}, 'GV1': {'value': '0', 'uom': '2'} 2020-10-18 23:31:00,073 [MQTT ] [DEBUG] Recieved Message: config Link to comment Share on other sites More sharing options...
glarsen Posted October 19, 2020 Share Posted October 19, 2020 Mine showed some strange behavior this morning too. It seems to have cleared without intervention and everything functions normally. Don't you love a good mystery? Edit: Oops, try this file Didn't notice I had 2 stored. sonoscontroller-0021b900ee84-8 (1).txt Link to comment Share on other sites More sharing options...
simplextech Posted October 19, 2020 Author Share Posted October 19, 2020 35 minutes ago, glarsen said: Mine showed some strange behavior this morning too. It seems to have cleared without intervention and everything functions normally. Don't you love a good mystery? sonoscontroller-0021b900ee84-8.txt 356.88 kB · 0 downloads Funny... your log time stamp shows a date of October 7th..... ??? Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 20, 2020 Share Posted October 20, 2020 It ran for over 48 hours, but it didn't survive this one... 2020-10-20 02:44:05,981 [MQTT ] [DEBUG] Recieved Message: config 2020-10-20 02:49:27,424 [Controller] [ERROR] Exception in thread Controller: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 371, in connect ssl_context=context, File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 384, in ssl_wrap_socket return context.wrap_socket(sock, server_hostname=server_hostname) File "/usr/local/lib/python3.7/ssl.py", line 412, in wrap_socket session=session File "/usr/local/lib/python3.7/ssl.py", line 853, in _create self.do_handshake() File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() ConnectionResetError: [Errno 104] Connection reset by peer During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 403, in increment raise six.reraise(type(error), error, _stacktrace) File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 734, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 371, in connect ssl_context=context, File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 384, in ssl_wrap_socket return context.wrap_socket(sock, server_hostname=server_hostname) File "/usr/local/lib/python3.7/ssl.py", line 412, in wrap_socket session=session File "/usr/local/lib/python3.7/ssl.py", line 853, in _create self.do_handshake() File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 917, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 865, in run self._target(*self._args, **self._kwargs) File "/usr/local/lib/python3.7/site-packages/pgc_interface/pgc_interface.py", line 795, in _parseInput self.shortPoll() File "./SonosController.py", line 193, in shortPoll sonos_groups = self.SonosControl.get_groups(household) File "/app/nodeserver/sonos/sonos_control.py", line 107, in get_groups r_json = self.sonos_get_api(groups_url) File "/app/nodeserver/sonos/sonos_control.py", line 46, in sonos_get_api req = requests.get(url, headers=self.headers) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 76, in get return request('get', url, params=params, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 61, in request return session.request(method=method, url=url, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request resp = self.send(prep, **send_kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send r = adapter.send(request, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 498, in send raise ConnectionError(err, request=request) requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) 2020-10-20 11:52:18,227 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b9022afa-14: {'command': {'address': 'g949f3e1ec6c0', 'cmd': 'PLAY', 'query': {}}} 2020-10-20 11:52:18,228 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g949f3e1ec6c0', 'cmd': 'PLAY', 'query': {}}} Link to comment Share on other sites More sharing options...
simplextech Posted October 20, 2020 Author Share Posted October 20, 2020 1 hour ago, Bumbershoot said: self._sslobj.do_handshake() ConnectionResetError: [Errno 104] Connection reset by peer again looks like an SSL issue from that error message. Link to comment Share on other sites More sharing options...
glarsen Posted October 20, 2020 Share Posted October 20, 2020 2020-10-20 03:01:05,605 [MQTT ] [DEBUG] Recieved Message: config 2020-10-20 03:28:15,571 [Controller] [ERROR] Exception in thread Controller: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 371, in connect ssl_context=context, File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 384, in ssl_wrap_socket return context.wrap_socket(sock, server_hostname=server_hostname) File "/usr/local/lib/python3.7/ssl.py", line 412, in wrap_socket session=session File "/usr/local/lib/python3.7/ssl.py", line 853, in _create self.do_handshake() File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() ConnectionResetError: [Errno 104] Connection reset by peer During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 403, in increment raise six.reraise(type(error), error, _stacktrace) File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 734, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request self._validate_conn(conn) File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 371, in connect ssl_context=context, File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 384, in ssl_wrap_socket return context.wrap_socket(sock, server_hostname=server_hostname) File "/usr/local/lib/python3.7/ssl.py", line 412, in wrap_socket session=session File "/usr/local/lib/python3.7/ssl.py", line 853, in _create self.do_handshake() File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 917, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 865, in run self._target(*self._args, **self._kwargs) File "/usr/local/lib/python3.7/site-packages/pgc_interface/pgc_interface.py", line 795, in _parseInput self.shortPoll() File "./SonosController.py", line 241, in shortPoll player_volume = self.SonosControl.get_player_volume(player_id) File "/app/nodeserver/sonos/sonos_control.py", line 182, in get_player_volume r_json = self.sonos_get_api(player_volume_url) File "/app/nodeserver/sonos/sonos_control.py", line 46, in sonos_get_api req = requests.get(url, headers=self.headers) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 76, in get return request('get', url, params=params, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 61, in request return session.request(method=method, url=url, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request resp = self.send(prep, **send_kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send r = adapter.send(request, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 498, in send raise ConnectionError(err, request=request) requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) Same thing here, about 3/4 of an hour later. Link to comment Share on other sites More sharing options...
simplextech Posted October 20, 2020 Author Share Posted October 20, 2020 2 minutes ago, glarsen said: File "/usr/local/lib/python3.7/ssl.py", line 1117, in do_handshake self._sslobj.do_handshake() ConnectionResetError: [Errno 104] Connection reset by peer same... Link to comment Share on other sites More sharing options...
simplextech Posted October 20, 2020 Author Share Posted October 20, 2020 Just pushed an update that adds some additional error catches to the name_resolution check and moved the voice rss call to use the standardized sonos_api_post function. That's the last of the little things I can see currently where anything "might" be having issues and not being caught. Anything further and it's going to be deeper in the stack. Link to comment Share on other sites More sharing options...
glarsen Posted October 22, 2020 Share Posted October 22, 2020 This happened at the point of a program execution this evening, thus the programmed operation did not occur. Manually running the program later worked, so the nodeserver recovered. 2020-10-22 01:42:51,573 [Controller] [INFO ] Sending customData to Polyglot. 2020-10-22 01:42:51,575 [Controller] [DEBUG] Sent Message: [prod/ns] : {"customdata": {"access_token": "Z2V8XY7lDlQDvIlqoQA1fFiVQXIj", "refresh_token": "YUTsRba5XH0To1bo71J8xl40qyboHdw2", "expires_in": 86399}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 01:42:51,575 [Controller] [INFO ] Sending notices to Polyglot. 2020-10-22 01:42:51,576 [Controller] [DEBUG] Sent Message: [prod/ns] : {"notices": {}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 01:42:51,962 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '18'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '15'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 01:42:51,962 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 01:42:52,004 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '18'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '15'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'HEUNI4quMWGI8F1LCG0eWp4me2g1', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 01:42:52,005 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:00:15,293 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAYLST', 'value': '8', 'uom': '25', 'query': {}}} 2020-10-22 03:00:15,294 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAYLST', 'value': '8', 'uom': '25', 'query': {}}} 2020-10-22 03:00:15,882 [Controller] [ERROR] SonosControl.sonos_api: b'{"fault":{"faultstring":"Invalid Access Token","detail":{"errorcode":"keymanagement.service.invalid_access_token"}}}' 2020-10-22 03:00:15,883 [Controller] [ERROR] sonos_control.set_playlist 2020-10-22 03:00:15,883 [Controller] [ERROR] Error: False 2020-10-22 03:00:26,193 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAY', 'query': {}}} 2020-10-22 03:00:26,193 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAY', 'query': {}}} 2020-10-22 03:00:28,513 [Controller] [ERROR] SonosControl.sonos_api: b'{"fault":{"faultstring":"Invalid Access Token","detail":{"errorcode":"keymanagement.service.invalid_access_token"}}}' 2020-10-22 03:00:28,514 [Controller] [ERROR] sonos_control.set_play 2020-10-22 03:00:28,514 [Controller] [ERROR] Error: False 2020-10-22 03:01:02,432 [Controller] [INFO ] Updating Driver g48a6b862d396 - SVOL: 13 uom: 51 2020-10-22 03:01:03,539 [Drivers ] [DEBUG] Sent Message: [prod/ns] : {"batch": {"status": [{"address": "g48a6b862d396", "driver": "SVOL", "value": "13", "uom": "51"}]}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:01:05,110 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '20'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '15'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:01:05,110 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:01:09,086 [Controller] [INFO ] Updating Driver p48a6b862d396 - SVOL: 5 uom: 51 2020-10-22 03:01:12,430 [Controller] [INFO ] Updating Driver p48a6b81acf2e - SVOL: 1 uom: 51 2020-10-22 03:01:13,579 [Drivers ] [DEBUG] Sent Message: [prod/ns] : {"batch": {"status": [{"address": "p48a6b862d396", "driver": "SVOL", "value": "5", "uom": "51"}, {"address": "p48a6b81acf2e", "driver": "SVOL", "value": "1", "uom": "51"}]}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:01:14,214 [Controller] [INFO ] Updating Driver pb8e9375d0874 - SVOL: 2 uom: 51 2020-10-22 03:01:15,049 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '1'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '15'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:01:18,427 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:01:18,587 [Drivers ] [DEBUG] Sent Message: [prod/ns] : {"batch": {"status": [{"address": "pb8e9375d0874", "driver": "SVOL", "value": "2", "uom": "51"}]}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:01:19,498 [Controller] [INFO ] Updating Driver pb8e9375d11ea - SVOL: 10 uom: 51 2020-10-22 03:01:21,498 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '1'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '2'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '15'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:01:21,498 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:01:23,601 [Drivers ] [DEBUG] Sent Message: [prod/ns] : {"batch": {"status": [{"address": "pb8e9375d11ea", "driver": "SVOL", "value": "10", "uom": "51"}]}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:01:25,478 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '1'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '2'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '10'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:01:25,478 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:42:51,820 [Controller] [INFO ] Sending customData to Polyglot. 2020-10-22 03:42:51,823 [Controller] [DEBUG] Sent Message: [prod/ns] : {"customdata": {"access_token": "l8rkoQxQN8qARnYvUDXXjxv41vs9", "refresh_token": "YUTsRba5XH0To1bo71J8xl40qyboHdw2", "expires_in": 86399}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:42:51,826 [Controller] [INFO ] Sending notices to Polyglot. 2020-10-22 03:42:51,826 [Controller] [DEBUG] Sent Message: [prod/ns] : {"notices": {}, "userId": "5a1311c6fdbae12be43f38ab", "topic": "prod/ns/sonoscontroller-0021b900ee84-8", "profileNum": "8", "id": "00:21:b9:00:ee:84"} 2020-10-22 03:42:52,130 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '1'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '2'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '10'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'Z2V8XY7lDlQDvIlqoQA1fFiVQXIj', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:42:52,131 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:42:53,306 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'config': {'firstRun': False, 'longPoll': '7200', 'logBucket': 'pgc-prod-logbucket-38dmw97ou252', 'oauth': {'test': {'clientId': '36f2a232-1260-4faf-a0eb-1795921fb806', 'redirectUrl': 'https://pgtest.isy.io/api/oauth/callback', 'secret': 'ddbef0df-13e1-4ac0-825b-44526e970a54'}, 'prod': {'clientId': 'f3dd2b06-e498-462e-bd6a-abdb0fb8b7ef', 'redirectUrl': 'https://polyglot.isy.io/api/oauth/callback', 'secret': 'eb29be52-1cee-4534-9417-250c9190a509'}}, 'url': 'https://github.com/simplextech/udi-poly-sonoscontroller.git', 'name': 'SonosController', 'language': 'python3', 'isyPassword': '6HwGgmnSJB', 'development': False, 'userId': '5a1311c6fdbae12be43f38ab', 'isyVersion': '5.3.0', 'pgUrl': 'https://lgpz727w3j.execute-api.us-east-1.amazonaws.com/prod/api/sys/nsgetioturl?params=eyJ1c2VySWQiOiI1YTEzMTFjNmZkYmFlMTJiZTQzZjM4YWIiLCJpZCI6IjAwOjIxOmI5OjAwOmVlOjg0IiwicHJvZmlsZU51bSI6OCwicGFzc3dvcmQiOiI2SHdHZ21uU0pCIn0', 'timeAdded': 1602802570379, 'id': '00:21:b9:00:ee:84', 'shortPoll': '60', 'timeStarted': 1603232204011, 'version': '0.2.20', 'nodes': {'controller': {'address': 'controller', 'drivers': {'ST': {'uom': 2, 'value': '1'}}, 'isController': True, 'isPrimary': True, 'name': 'Sonos Controller', 'nodedefid': 'controller', 'primary': 'controller', 'timeAdded': 1602802587944, 'timeStarted': 0}, 'g48a6b862d396': {'address': 'g48a6b862d396', 'drivers': {'FAV': {'value': '0', 'uom': '25'}, 'GV0': {'uom': '2', 'value': '0'}, 'GV1': {'uom': '2', 'value': '0'}, 'PLAYLST': {'value': '0', 'uom': '25'}, 'ST': {'uom': '25', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '13'}}, 'elapsed': '245.690056ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room ', 'nodedefid': 'GROUP', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'groups': {'address': 'groups', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '138.78059ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Groups', 'nodedefid': 'PARENT', 'primary': 'groups', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}, 'p48a6b81acf2e': {'address': 'p48a6b81acf2e', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '1'}}, 'elapsed': '756.612304ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Master Bedroom', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'p48a6b822aeb2': {'address': 'p48a6b822aeb2', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '55'}}, 'elapsed': '708.580152ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Garage', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201398686, 'timeStarted': 0}, 'p48a6b862d396': {'address': 'p48a6b862d396', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '5'}}, 'elapsed': '646.240252ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Living Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201387618, 'timeStarted': 0}, 'pb8e937587f00': {'address': 'pb8e937587f00', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '7'}}, 'elapsed': '475.735759ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Office', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d0874': {'address': 'pb8e9375d0874', 'drivers': {'GV0': {'uom': '2', 'value': '0'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'uom': '2', 'value': '1'}, 'SVOL': {'uom': '51', 'value': '2'}}, 'elapsed': '230.486919ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Powder Room', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'pb8e9375d11ea': {'address': 'pb8e9375d11ea', 'drivers': {'GV0': {'value': '0', 'uom': '2'}, 'SAYTTS': {'value': '0', 'uom': '25'}, 'ST': {'value': '1', 'uom': '2'}, 'SVOL': {'uom': '51', 'value': '10'}}, 'elapsed': '369.190838ms', 'error': False, 'isController': False, 'isPrimary': False, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Patio', 'nodedefid': 'PLAYER', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201392121, 'timeStarted': 0}, 'players': {'address': 'players', 'drivers': {'ST': {'uom': '2', 'value': '1'}}, 'elapsed': '357.595867ms', 'error': False, 'isController': False, 'isPrimary': True, 'json': {'RestResponse': {'reason': {'code': '5004'}, 'succeeded': 'false', 'status': '400'}}, 'name': 'Sonos Players', 'nodedefid': 'PARENT', 'primary': 'players', 'seq': False, 'statusCode': 400, 'success': False, 'timeAdded': 1603201382204, 'timeStarted': 0}}, 'netInfo': {'publicPort': 0, 'httpsIngress': False, 'publicIp': '3.89.244.35'}, 'customData': {'access_token': 'l8rkoQxQN8qARnYvUDXXjxv41vs9', 'refresh_token': 'YUTsRba5XH0To1bo71J8xl40qyboHdw2', 'expires_in': 86399}, 'connected': True, 'customParams': {'SAY_TTS-8': 'empty', 'SAY_TTS-9': 'empty', 'SAY_TTS-6': 'empty', 'SAY_TTS-7': 'empty', 'format': '24khz_16bit_stereo', 'SAY_TTS-10': 'empty', 'SAY_TTS-1': 'This is a test message', 'language': 'en-us', 'SAY_TTS-4': 'empty', 'SAY_TTS-5': 'empty', 'SAY_TTS-2': 'empty', 'SAY_TTS-3': 'empty', 'codec': 'mp3', 'api_key': '13a2708b10c34a03b2f68000ce401cc8'}, 'profileNum': '8', 'notices': {}, 'worker': 'sonoscontroller-0021b900ee84-8', 'lastDisconnect': 0, 'isyUsername': 'pgc', 'type': 'cloud'}} 2020-10-22 03:42:53,307 [MQTT ] [DEBUG] Recieved Message: config 2020-10-22 03:57:43,368 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAYLST', 'value': '8', 'uom': '25', 'query': {}}} 2020-10-22 03:57:43,368 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAYLST', 'value': '8', 'uom': '25', 'query': {}}} 2020-10-22 03:57:54,616 [MQTT ] [DEBUG] MQTT Received Message: prod/ns/sonoscontroller-0021b900ee84-8: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAY', 'query': {}}} 2020-10-22 03:57:54,616 [MQTT ] [DEBUG] Received Message: {'command': {'address': 'g48a6b862d396', 'cmd': 'PLAY', 'query': {}}} Link to comment Share on other sites More sharing options...
Bumbershoot Posted October 22, 2020 Share Posted October 22, 2020 FWIW, taking attempting to look at the log this morning produces this error, though the nodeserver was working. I gave it a restart, but the error persists. The nodeserver is otherwise operating. Link to comment Share on other sites More sharing options...
simplextech Posted October 22, 2020 Author Share Posted October 22, 2020 @glarsen, @Bumbershoot The log stream error I got nothing for you. That's polyglot and it retrieving the logs from the server instances running in the cluster. The other log looks like it was trying to do things but failing. Likely due to name resolution or network issues but they were caught and handled and the NS didn't crash. Link to comment Share on other sites More sharing options...
simplextech Posted October 22, 2020 Author Share Posted October 22, 2020 Just because I stopped my instance and trying to start it again and it won't start. No logs, nothing. I'm wondering if there's something going on with PGC? Link to comment Share on other sites More sharing options...
bcdavis75 Posted October 22, 2020 Share Posted October 22, 2020 2 minutes ago, simplextech said: Just because I stopped my instance and trying to start it again and it won't start. No logs, nothing. I'm wondering if there's something going on with PGC? This happened to me a while back. I opened a ticket and Michel was able to fix whatever got clogged on the back end. Link to comment Share on other sites More sharing options...
simplextech Posted October 22, 2020 Author Share Posted October 22, 2020 1 minute ago, bcdavis75 said: This happened to me a while back. I opened a ticket and Michel was able to fix whatever got clogged on the back end. I just removed the NS and am trying to install it again. Not working. It claims it's installed but it never starts. From the error that @Bumbershootposted it's from kubernetes which is outside of what I can do anything with. Link to comment Share on other sites More sharing options...
glarsen Posted October 22, 2020 Share Posted October 22, 2020 I've experienced this same a while back. It required intervention by UDI to correct. My SonosController appears to be working now, I just can't retrieve the log. The other PGC nodeserver I run is working fine including the log display. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted October 22, 2020 Share Posted October 22, 2020 All, looking into it. With kind regards, Michel Link to comment Share on other sites More sharing options...
