2474DWH as On Off for exhaust fan
ThisIsTheWay
The 2474DWH is a two wire switch that steals power through the load and need no Neutral power connection. Designed to only be used with Incandescent loads. So it will not work.
Since it is a dimmer type and it will be incompatible with a inductive fan motor. Possible damage to the fans motor,  the 2474DWK or both. Inductive loads should be controlled by a On/Off relay type switch.
      38.2k
      381.2k
