Copy 8 button keypad
pooderbill
I'm adding a new 8 button keypad that needs to duplicate the settings in the current one.
The current keypad is programmed for push-on, push-off for each button but also I need to turn on/off the keypad lights.
Specifically, push button A turns on the scene, turns on button A light and turns off any other button lights.
It was setup years ago and requires going into some advanced tabs but I don't know where they are.
Is the a way to simply clone the setting in ISY for the new keypad?
Or a way to show all the settings on the original keypad?
Edited by pooderbill
spelling
2 minutes ago, pooderbill said:
I'm adding a new 8 button keypad that needs to duplicate the settings inrent one.
If you're replacing the kpl with a new one you would do a swap
https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Replacing_a_Device
23 minutes ago, pooderbill said:
This appears to delete the old keypad. How do I copy the old keypad settings into the additional keypad?
That depends on what firmware you're on. 4.0 there's a copy button in 5.0 there is none.
      378.5k
