Stuck on UI ver 4.6.2
RayV
No matter what I try I an stuck on UI 4.6.2.  It doesn't matter if I change firmware to an older version or a newer version.  This became a problem after trying to install one of the very early 5.x betas many months ago.  I've reformatted the SD card.  I've tried the 30 second full reset.  What do I need to do to fix it?  I'm OK with a complete wipe if that's what it takes
You can find the instructions here: https://wiki.universal-devices.com/index.php?title=Main_Page#Quick_Start_Guides
If you are on Windows this should help:
Installing the Admin Console Icon on Your Desktop
It's always best to use the Admin Console application which is browser independent. To do this:
  1. Clear your java cache
  2. Use the ISY Launcher to launch the Admin Console. This should put an icon on your desktop once you run the downloaded start.jnlp file.
If on Mac, read thru the first link.
      38k
      379.3k
