Sunset if/then help
here is what i got:
       Time is Sunset  -  1 hour  and 15 minutes
        Set 'BEDRM LAMP' 20%
        Set 'BDRM BACK' 12%
        Wait  30 minutes
        Set 'BDRM.Back Porch Light' On
this program has been running great, what I would like to add is if 'BDRM BACK' is already on, to leave it at the present level and not change it to the 12% setting.
thanks!
Create a second program, I'll call it "Set_BDRM_BACK_To_12":
Set_BDRM_BACK_To_12 - [ID xxxx][Parent xxxx][Not Enabled]
        'BDRM BACK' Status is Off
        Set 'BDRM BACK' On 12%
After creating this program, right-click on it and choose "Disable".  This is important because it tells the ISY not to automatically evaluate the IF whenever the status of "BDRM BACK" changes.  If you don't do this, then whenever you turn OFF "BDRM BACK" it will automatically come back on at 12%.
Now replace the "Set 'BDRM BACK' 12%" line in your program with "Run Program 'Set_BDRM_BACK_To_12' (IF)".
Edited by kclenden
so when you disable a program it's not totally disabled.
thanks i'll see if it works today.
The program is disabled in the sense it will not run by its own if statement but can still be called by another program.
It only disables the triggers of the program.
  • 3 weeks later...
So this is what I had to do, I had to 'run' 2 times with a "Wait 1 minutes" in between, for it to work, it was intermittent otherwise.
        Run Program 'Set_BDRM_BACK12' (If)
        Wait  1 minutes
        Wait  30 minutes
