UD Mobile Issues
Hi Jim,
Thanks, Looks as if this issue was fixed in a greater firmware version.
UD Mobile has only been approved to work with firmware 5.0.16 and greater. Please upgrade to at least 5.0.16. Note that firmware 5.2.0 and greater require the 500 series Z-Wave board.
All firmware options and upgrade instructions can be found here:
https://forum.universal-devices.com/forum/15-current-release-betas-and-bug-reports/
10 minutes ago, Javi said:
"The 300 series will have an LED protruding out of the rear of ISY and may have an antenna mount as well" (1)
(1) https://wiki.universal-devices.com/index.php?title=Z-Wave:_Ordering/Assembly_Instructions#What_does_it_look_like.3F
@JimTurnerThe blue LED is hard to identify if it is unlit without using the flashlight on your phone.
A better method:
If your ISY has a z-wave board, you will have a z-wave menu at the top of the Admin Console.  Check the Z-Wave Version:
4.55.00 = 300 series, the last firmware version compatible is 5.0.16C
6.81.00 =  500 Series, proceed directly to firmware v5.3.4
Edited by MrBill
Thanks. I have a 500 board (6.81 firmware). Appreciate all the help on this. While I am a techy, I have not dug into this platform other than to get it up and running. :)
