missing scenes
I have noticed that about half of my scenes are missing.  There is nothing special about the missing scenes.  For example, "party" and "patio lights" are two scene names that aren't there while "patio fans" is there.  I have 48 scenes and only 23 are showing up in UD mobile.  I tried syncing and they still aren't there.
Hi @apostolakisl,
Have you been able to access these scenes before, or has this always been the case?
If this has always been the case, your files may have an issue created by a bug in an older firmware version, assuming no errors were presented during sync.   In rest/nodes can you check if the missing scenes have a parent tag containing a  parent address. If they do can you search for the parent address,  is this folder defined?
If the parent address is not defined can you add the scenes to a new folder, at least temporarily,  in the Admin console? This should remove the link to the non-existent parent.
@Javi
Below is the rest/nodes for one of the missing scenes.  It is not in a folder.  I actually don't have any of my scenes in folders.
<group flag="4" nodeDefId="InsteonDimmer">
<address>18871</address>
<name>Patio Coach Lts S</name>
<family>6</family>
<deviceGroup>26</deviceGroup>
<ELK_ID>E11</ELK_ID>
<members>
<link type="16">49 B7 B5 1</link>
<link type="16">49 B6 D5 1</link>
<link type="16">4C 77 2F 1</link>
</members>
EDIT:  I just tried deleting the profile and re-adding.  Still no scenes.  The UD mobile app is the current release.
Edited by apostolakisl
Hi @apostolakisl,
Thanks for posting the node xml.
I think I see the problem, The app is only adding <group flag = "132"... not <group flag = "4".  This was done to exclude the ISY scene, but I'll change this to only exclude if flag="12" instead.   Please let me know if version 0.51 fixes the issue, should be available later today or early tomorrow.
