Energy Monitoring with Honeywell T6 Pro Thermostat
Hi, having some difficulty here. This is not working anything like my GE 240V Outdoor Smart Switch for the pool pump (which provides a lot of data right out of the box). All I see in the ISY Admin screen for the Energy Monitor is the attached and it is not dynamic. Is there some manual setup required? Thanks much.
2125861458_ScreenShot2021-04-07at1_57_01PM.thumb.png.81005d16a6637a76af27edcfae34f402.png
Some extensive Google-Fu did not yield any manual covering this topic. I called Honeywell and since this is a "Pro" item I was referred to my contractor/installer for support. Well he is a complete idiot, unfortunately... There must be some Pro documentation for this unit somewhere.
Bump. Someone has to have figured this out... Thanks.
in a single google attempt, second link clicked I found this manual.   On page 20 it says:
Quote
Z-Wave configuration parameters
If your gateway/hub/controller supports configuration function, you may remotely
configure or change the default thermostat configuration parameters. For detailed
table with all available Z-Wave configuration parameters go to
http://customer.honeywell.com
 or search for
T6 Pro Z-Wave Thermostat
in the
Z-Wave certified products section on
http://Z-Wavealliance.org
Read more: https://www.alarmgrid.com/documents/honeywell-t6-pro-z-wave-thermostat-installation-manual
I wouldn't necessarily assume someone from this community has that thermostat either.
Thanks. Both complete dead ends. Absolutely nothing shows up at Z-Wavealliance.org and there are hits for this model from Honeywell but no manuals or documentation that help.
hmmmm, i didn't have trouble....
https://products.z-wavealliance.org/regions/2/categories/10/products?company=731
https://products.z-wavealliance.org/products/2893
https://products.z-wavealliance.org/products/2583?selectedFrequencyId=2
8 hours ago, MrBill said:
Thanks much. I missed the Products>Catalog of Certified Products links needed before doing a search. Absolutely nil in those manuals, list, links on monitoring power consumption. I dug through all lines for the "Command Classes" and "Configuration Parameters". I'm beginning to think that even though when I linked to this thermostat and a separate "energy meter" Z-wave "device" showed up in my ISY menu, that this is not actually available.
