Energy Monitoring with Honeywell T6 Pro Thermostat
swamp2
Hi, having some difficulty here. This is not working anything like my GE 240V Outdoor Smart Switch for the pool pump (which provides a lot of data right out of the box). All I see in the ISY Admin screen for the Energy Monitor is the attached and it is not dynamic. Is there some manual setup required? Thanks much.
2125861458_ScreenShot2021-04-07at1_57_01PM.thumb.png.81005d16a6637a76af27edcfae34f402.png
Some extensive Google-Fu did not yield any manual covering this topic. I called Honeywell and since this is a "Pro" item I was referred to my contractor/installer for support. Well he is a complete idiot, unfortunately... There must be some Pro documentation for this unit somewhere.
in a single google attempt, second link clicked I found this manual.   On page 20 it says:
Quote
Z-Wave configuration parameters
If your gateway/hub/controller supports configuration function, you may remotely
configure or change the default thermostat configuration parameters. For detailed
table with all available Z-Wave configuration parameters go to
http://customer.honeywell.com
 or search for
T6 Pro Z-Wave Thermostat
in the
Z-Wave certified products section on
http://Z-Wavealliance.org
Read more: https://www.alarmgrid.com/documents/honeywell-t6-pro-z-wave-thermostat-installation-manual
I wouldn't necessarily assume someone from this community has that thermostat either.
Thanks. Both complete dead ends. Absolutely nothing shows up at Z-Wavealliance.org and there are hits for this model from Honeywell but no manuals or documentation that help.
hmmmm, i didn't have trouble....
https://products.z-wavealliance.org/regions/2/categories/10/products?company=731
https://products.z-wavealliance.org/products/2893
https://products.z-wavealliance.org/products/2583?selectedFrequencyId=2
8 hours ago, MrBill said:
Thanks much. I missed the Products>Catalog of Certified Products links needed before doing a search. Absolutely nil in those manuals, list, links on monitoring power consumption. I dug through all lines for the "Command Classes" and "Configuration Parameters". I'm beginning to think that even though when I linked to this thermostat and a separate "energy meter" Z-wave "device" showed up in my ISY menu, that this is not actually available.
      37k
      371.4k
