" TCP client resource moved"
Im getting this error message when I am trying to install the MobiLinc module after I have just installed the ISY portal mod in an ISY994i pro
Any clues?
You can't have mobilinc connect and the Isy portal. You must decide which you want to use. Once you do that, you'll need to connect the other to cancel and switch over
