What are each of the 3 LEDs used for?
The right most LED is continually flashing. I think it started after I initiated a Polisy Update. It's been 20 minutes, still flashing.
It continued to flash for a couple hours. I did a Polisy reboot but that didn't help. So I did a Polisy shutdown and then pulled the plug. Everything started up okay and now the light is out. Just the left most LED is on. So I guess everything is normal again.
Sounds like you just did a major upgrade.
I have seen my RPis take 5 to 6 hours for a major upgrade, including most packages and an OS upgrade.
I hope I didn’t ruin something by pulling the plug. Seems okay. BTW, I don’t see how to backup Polisy, just a restore. Can it be backed up to a network drive?
Under Settings > Polisy Configuration, click the [Download] button right above and save the file wherever you want.
Duh? I saw that and thought Download to Polisy. Does it backup the whole system or just Polygot node server installs? Thanks. Phil
17 minutes ago, DaveStLou said:
It's just the node servers.
Okay thanks. One last question. Any idea what the LEDs indicate?
I doubt it but with linux (RPi) and freeBSD (polisy) you can run the update/upgrade lines again and it will sort out what isn't up to date.
17 hours ago, lilyoyo1 said:
I can't find this in the WiKi.
UDI Support gave me this information.
Quote
Left = Power
Middle = Tx
Right = Rx
Left + Middle + Right blinking = error
Middle and/or Right blinking = upgrading (this may take a while depending on the number of packages)
  • Thanks 1
I'm glad you asked them.  I've been wondering since you asked the question.  My Polisy's are located in a place where I never see them unless I specifically go there to add/change or unpower/repower something.  After you asked I looked at the same wiki page expecting the answer to be there, but it really isn't.  Other than power tho, I'm not sure I would be confident reading the meaning... if I needed to know because a specific problem was attracting my eye towards them I'd probably email support anyway.
      379.6k
