Has anyone written a network resource that can shutdown a Windows PC on a local network?
The network resource WOL works perfectly ... but I was wondering if anyone had cobbled together an ISY network resource plus something running on a local Windows PC that could initiate a Windows shutdown?
TIA for any suggestions! Broyd.
If your PC has eventghost running on it, you can use an ISY network command to trigger a macro on eventghost and that can run a python script that executes a shutdown.  I would suggest having the PC on the same LAN as ISY to avoid any port forwarding/security concerns.
Thanks apostolakisl, I'll check eventghost out. Appreciate the suggestion.
Initially I was looking for a method to shutdown a Windows PC
by sending a 'something' to the PC using a network resource.
This involved setting up a task on the Windows PC that could listen
on a port and respond to a shutdown command set from the ISY.
This task would have to be loaded when the PC was booted.
When I had a closer look at this, I realized that I also wanted
a task that would play an alarm after the PC was fully booted up.
So in the end, I set up 3 python scripts to accomplish this;
I am including them here in the event that someone else might find
them useful.
The first python script's purpose is to start the two other scripts
independently and asynchronously. That is these two scripts run
as if they were started one at a time with no dependencies
associated between either script. They run and terminate
independently of each other.
So ... here are the three python scripts
# First, RunProcesses.py
import os
from multiprocessing import Pool
from time import sleep
processes = ('C:\PythonScripts\PIII-10G-ShutDown.py', 'C:\PythonScripts\Pythonplaysound.py')
def run_process(process):
    print('\nRunning process: ' + process)
    os.system('python {}'.format(process))
def main() :
    pool = Pool(processes=2)
    pool.map_async(run_process, processes)
if __name__ == '__main__':
    print('Starting  MAIN')
    main()
    print('Finishing MAIN')
    sleep(2)
---=== End of Script ===---
# Second, PIII-10G-ShutDown.py
# I give credit to larryllix for the core of this script; I grabbed it from the forum many moons ago.
import os
import sys
import time
import datetime
from http.server import BaseHTTPRequestHandler, HTTPServer
# HTTPRequestHandler class (HTTP requests, either from a browser or the ISY994i are handled using this class.
class myHTTPServer_RequestHandler(BaseHTTPRequestHandler):
    def do_GET(self):
        self.send_response_only(200)
        words = self.requestline.split()
        params = words[1].split("/",2)
        #debug stuff
        #print("\n\nNumber of parmameters in input string:", str(len(params)))
        #print("\nInput string passed into Python:", words)
        #print("\nParameters received: ", params)
        Arg1 = params[1]
        if Arg1 == "Shutdown" :
           print("\nShutdown received.")
           os.system('"C:\ShutDown.bat"')
        elif Arg1 == "StartXYZ" :
           print("\nStarting Program XYZ.")
           os.system('"C:\XYZ.bat"')
        else :
           print("\nUnanticipated command received: " + str(Arg1))
# Server settings
def run():
    #print('\nStarting server...')
    server_address = ('192.168.1.4', 10738)
    httpd = HTTPServer(server_address, myHTTPServer_RequestHandler)
    print('\n' * 2)
    print('Running server...')
    print('\n' * 2)
    httpd.serve_forever()
run()
A quick note on the shutdown script above. I set up and used English words in my
Network Resource PATH item. You could use variable substitution (numbers)
instead which allow any number of functions (for the python script) to use
one Network Resource.
# Third, Pythonplaysound.py
from playsound import playsound
print('\nBig Ben initiated.')
sleep(210)
# Note:- use of the FORWARD slash in the filename for playsound
playsound('C:/PythonScripts/BigBenClockCV3.mp3')
# print('\nBig Ben completed.')
And finally, the ISY network resource:
Protocol Information:
http GET   Host: 192.168.1.4   Port: 10,738  Path: /Shutdown  Timeout: 500
