Polyglot errors
SSamuels
Restart the node server involved. If that doesn't solve it, you'll need to open a ticket so that they can see what's wrong with your cloud instance.  support@universal-devices.com
Edited by MrBill
  • 4 months later...
Ultimately something interacted with one of the node servers in my Polyglot - TotalConnect2. I was unable to remove the node server from Polyglot so Michael had to do this from his end. I removed TotalConnect2 from my ISY. Once Michael removed this node server from Polyglot, I was able to log into Polyglot again. I re-added TotalConnect to Polyglot AND turned-off my 'Security' package on my Orbi 850Router (Armor security) - Armor had been causing another 'login' problem with using PLEX media app through Sonos. So.. I would start by asking Michael to removes what you believe to be the offending node server from Polyglot, you removing the node from your ISY and  make sure your 'security' app/firewall is working correctly with Polyglot and re-adding the node server to Polyglot.
Good Luck!
      38.2k
      381.2k
