Timezone setting and location for sunrise/sunset
MWareman
My Polisy is set to Chicago:
However - the dashboard on ISY running on Polisy is using LA as my location for the timezone and sunrise/sunset calculation:
The actual timezone settings of the clock are not available in the java UI for ISY on Polisy (unlike native ISY where there are options on this screen for setting the timezone). Isn't it supposed to inherit the timezone of the Polisy it's running on?
Michael.
@MWareman,
It should use whatever is the system time zone as set by Polyglot. This information comes from another service called udx (which is an abstraction layer for OS and used by both Polyglot and ISY). I suspect udx is back leveled. Please:
sudo pkg upgrade udx
sudo pkg upgrade isy
sudo service udx restart
sudo service isy restart
@Michel Kohanim
Fantastic - that resolved the timezone issue. Thank you so much!
One minor issue does still remain.
On physical ISY - we had the ability to set a custom location. In my case - I am ~50 miles west of Chicago and the sunrise and set times are ever so slightly different.
Physical ISY:
ISY on PolISY:
ISY on Polisy is now learning the timezone from the underlying OS - but we appear to have lost the ability to put in a latitude and longitude for the sunrise/sunset calculation. Is this no longer possible (if not, can it be added back?)
Thank you!
Edited by MWareman
@Michel Kohanim Here's a second vote for hoping it's added back.  (actually I said the same in a different thread months ago too).  While the differences between custom and the nearest timezone city are not often great, they are still different... and there is a nerd factor here...
that said I guess there are two nodeservers... Sun and TimeData that would do the job.
@MWareman,
They shall be resurrected. The main issue is that, as you can see, we are trying to move things out of the Java Admin Console + want to make sure we use existing OS functionality as much as possible. For instance, we no longer manage DST calculations, months, days of the week, etc.
In the meantime, if you have specific lat/long, please send to support@universal-devices.com and we'll include it in the list in Polyglot.
@MrBill, yes, thank YOU very much.
On 10/13/2021 at 9:00 AM, Michel Kohanim said:
@MWareman,
Thank you so much! An email has been sent. I appreciate it.
Michael.
  • 4 weeks later...
I was having the same issue. I'm on ISY v5.1.1
Tried a polisy update via the UI. Last reboot it changed to match the Polyglot settings, then reverted back after a few minutes to pacific time.
Tried comandline update options without effect. Manually called to update udx and polisy as above, and it worked despite the output not saying anything was updated. But again, simply restarting the system worked for a while- so I'll keep an eye on it.
However, while the current date/time are correct, the sunrise/sunset are off by an our (stating today that sunset is at 15:51:53) when it should be 16:52 according to reality. Today was the switch to standard time. Wonder if it will fix itself tomorrow- Not sure when those values are updated.
While there's a checkbox for Daylight Savings in the ISY UI, it's greyed out- and currently checked (incorrectly).
Date and time is hard.
Edited by Scott Korvek
Update: time just flipped to Pacific (LA) while hitting submit on the last reply.
I'll also note I'm running the TimeData node server.  From it's logs, the time/date information on polisy is correct, including DST status and my manually-input lat/long:
2021-11-07 16:35:13,534 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver timedata - GV1: 35, uom: 0
2021-11-07 16:35:13,537 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver timedata - GV9: 447395, uom: 0
2021-11-07 16:35:13,539 Controller polyinterface DEBUG timedata:season: dd: 7 md: 1107
2021-11-07 16:35:13,540 Controller polyinterface DEBUG timedata:getNodeUpdates: UTC offset: -5.0
2021-11-07 16:35:13,543 Controller polyinterface DEBUG timedata:getNodeUpdates: Old epoch days: 18938.89945601852
2021-11-07 16:35:13,544 Controller polyinterface DEBUG timedata:getNodeUpdates: Stripped date string is 2021-11-7 16:35, weekday 6, days since epoch: 18938.89945601852, hours this year: 7456
2021-11-07 16:35:13,544 Controller polyinterface DEBUG timedata:getNodeUpdates: Day of week 6, Week number 46, Day of Year 311
2021-11-07 16:35:13,545 Controller polyinterface DEBUG timedata:getNodeUpdates: Minutes in year to now 447395, hemisphere north, season 2, leap year 0, isDST 0
On 10/13/2021 at 10:00 AM, Michel Kohanim said:
@MWareman,
After finding sunset light programs not working correctly I found my polisy admin console displaying LA, California. My polyglot settings were for Toronto. Since the settings rejected any update (no change) I had to change the location to Ottawa and then back to Toronto to get it to change.
Now my sunset and sunrise times are both 1 hour too early.
Owen Sound would be the nearest major community for this area.
Latitude: 44° 34' 1.81" N
Longitude: -80° 56' 36.56" W
Thanks!  Just to add a bit more information: here's a screenshot.  This AM I find it still thinks it's in CA, but is reporting the correct EST time. And sunrise/sunset makes no sense at all.
It's 9:11AM EST at the time of the screenshot and bright and beautifully sunny.
JPG vs PDF
Enter your Polyglot settings and change the location to a temporary location. Save and then set back. The automatic location grab at boot-up or install, apparently isn't working properly yet. Mine were set to locate Michel also. :)
My sunset and sunrise were off an hour (more than DST return to EST) but now seem to have corrected themselves (next day) somehow. Rebooting polisy didn't seem to help at the earlier point either.
Still need a lat/long tweak as the times are off by about ten minutes but that is minor.
Grrrrrrrrr.....
My timezone, along with sunset and sunrise times, and event times shown for programs and variables just reverted back to LA again.
1 hour ago, larryllix said:
Grrrrrrrrr.....
Maybe your ISY is telling you that for the winter it wants to move to sunny California.
  • Haha 3
2 hours ago, Michel Kohanim said:
@larryllix,
Just to be clear, this is only for programs and not the clock at the top of the Admin Console?
The time zone at the top of the admin console changes back to LA Cal. Then program events in the summary tab and variables all show last run / modified based on the LA times.
1 hour ago, Michel Kohanim said:
@larryllix,
Makes no sense. Please send me the following in an email to support@Universal-devices.com
1. Output of
uname -a
pkg info isy
df -h
2. ISY Error Log
3.  /var/isy/FILES/LOG/debug.log
3. /isy/ is locked permission. I cannot access this file or directory
When using sudo,  /FILES/ does not exist
yup. Making the temp change in Polisy config doesn't work.  A while (hour? went to put my kid to bed) after the change, my TZ was fixed, but my sunrise/sunset times are 3 hours off actual (Local sunset + 3 hrs) again. So any sunrise/sunset calculations in programs don't trigger correctly.
My current workaround is to use the sun position nodeserver and key off the elevation parameter so set dusk, sunset, and sunrise as state variables to trigger programs. (fits anyway- most everything I am doing is llke a mini-state machine).
Sent a support email.
So far after the removal of nodeservers, reboot, and re-adding each back one at a time my time settings remain correct. I'll probably never figure out what was calling that service.
All,
Definitely a bug. And, while crushing it, added time/lat/long configuration back to the Admin Console for Polisy. The only thing you won't be able to do is to set the Time Zone offset because the OS does not allow it: it has a list of time zone regions that you have to choose from.
So, let's say you want to have a different lat long that's not in the list. What you do is to pick the nearest city, then change the lat/long and save.
Other things that were fixed/enhanced:
- SNI support for network resources
- IPv6 web server
- SMTP issues truncating messages and sending them as attachments instead
- Z-Wave is very very very close
Should be out mid week.
  • Like 6
All,
- IPv6 web server
Awesome! Thank you @Michel Kohanim
Having the lat/long set separately from the timezone is most definitely a needed feature as some timezones are huge. I'm quite sure this is better than adding hundreds of locations just to account for sunrise/sunset times.
Looking forward to the SNI and Z-Wave support - these two will help me complete my own migration. Only one final bugfix to confirm - triggering device substitution for # in NRs.
      38.2k
      381.2k
