Motion Program
! have three switchlink relays controlling a light, I have set up programs to turn the light on with a motion sensor. The motion sensor turns the lights on fine and turns them off fine. However when i press fast on it does not inactivate the timer. I unfortunatelly have trouble understanding programs. Any suggestions or help would be kindly appreciated. If
Control 'Mudroom Sensor' is switched On
And Status 'Mud Room' is not On
And Status 'Mud Room Slave' is not On
Set Scene 'Mud Room' On
Status 'Mudroom Sensor' is Off
Wait 2 minutes
Set Scene 'Mud Room' Off
Control 'Mud Room' is switched Fast On
Or Control 'Mud Room Slave' is switched Fast On
Disable Program 'Mudroom Timer'
Control 'Mud Room' is switched Off
Or Control 'Mud Room Slave' is switched Off
Enable Program 'Mudroom Timer'
I now have no trouble disabling the motion timer with:
I have no difficulty enabelling program with:
What I have difficulty with enabling or disabling the program with using either of the two other switchlinc relays. Do I write four other programs as above? Will that work? Is there a better way. I read Darrell Peters excellent article on the wiki and also the Scope, Precedence and Execution Order which I didn't understand. I never had any programming experience and feel like I'm struggling. Any help would be appreciated.
Hi wacvmd,
I do apologize for not seeing your original post.
You can use the OR to include other devices in your conditions. But, perhaps, I am not understanding what you are trying to accomplish. You are always welcome to call our tech support line to schedule a call so that we can walk you through some of these difficulties.
