Add to ISY to Polisy
dinostop
I have searched and searched for an answer and can't seem to find it.  Probably missing it somewhere.
I would like to put ISY on my Polisy.  I go into the portal and add the ip address as the instructions say, however when it takes me into the ISY screen I have to create a user name and password.  I do that and it asks if I would like to save it which I do, but then nothing happens.  I close out and then go back in and same thing.  I see some information on the commands to use to do an update of the software for ISY but I am not sure how to get to the command prompt to do that.  I am using a Mac Book Pro
@ase
Thank you, I do SSH all the time into my raspberry pi's so I am aware on how to do that.  I finally was able to ssh into the Polisy.  I was using my Polisy password and didn't know that was not the correct password to use.
Edited by dinostop
I have done my best to follow the directions to upgrade the ISY on the Polisy.  The ISY launcher does not automatically find the ISY on the Polisy.  I attempted to add it using the local web address of 192.168.200.212:8080/desc and it then shows up in the launcher.  When I open that up all I can do is set initial user name and password.  When I attempt to do that it asks if I want to make that the new user name and password.  I say yes and then nothing happens.  The change user name password box does not go away either.  When I close it out and open it again same thing happens.
I must be missing something.
Prior to now I have not attempted to run ISY on the Polisy.
4 minutes ago, kzboray said:
@dinostop You might want to double check that you  have checked the Insteon Support on your Polisy.
2021-11-02_11-29-43.jpg.45db89194738bbc342ee5be804c675b7.jpg.d4d968419e6219657b9cfbe010fba469.jpg
Where would I find that screen?  If it is in the ISY system itself, the only option I have is File / Set user name and password.  I think there is something I am missing before that since it is not auto finding it in the ISY finder either.
@MrBill
I am not able to do that because ISY only has a blue screen.  I can't log into it nor get it to create and new admin user name and password.
I believe I am missing a step with the update or something else prior to me trying to log into the ISY on the Polisy.
27 minutes ago, dinostop said:
@MrBill
Ahh... i just answered the last question without reviewing the entire thread.
I suspect that your polisy is on an earlier version of the OS.... and thus doesn't install the ISY on Polisy pkg.
Your fastest method to get up and running with ISY on Polisy might be to open a ticket by email support@universal-devices.com  Also ssh to your Polisy and run the command
uname -a
and copy and paste the output into your ticket.
      378.5k
