X10 Support for ISY on Polisy?
I have a number of legacy devices from the old X10 days that I used to control via my ISY994i.  Mainly things like a chime that would go off if one of my Insteon leak sensors detected a leak.  I did a quick search through the forums, so my apologies if I missed this in prior posts, but will ISY on Polisy support X10 devices via an add-on module like the ISY994i did?  I did not see that module as one of the ones that was migrated when I did the backup/restore from my ISY994i to ISY on Polisy.
Have run into the same issue. The module appears to not be supported. My devices, while they still appear in My Lighting, they are all "dead links". Clicking on them doesn't even bring up anything at all. The screen stays on whatever it was last on. They have become invisible.
Furthermore, I am finding that I cant get the ISY to recognize x10 command received. It will send them fine, using the X10 command line, but not receive them.
I will wait and see who else comments here, then open a ticket if needed.
Basically the same here. However I only have one X10 module left and I only monitor and turn it off with the middle of the night complete shutdown every night. It's connected to a heavy duty contactor that runs my shop dust collector, always run from an X10 remote pushbutton that sits on the chop saw.
Michel told me X10 was working so I assumed it was my USB PLM on my polisy that doesn't support X10, anymore.
ok. thanks for the validation. I will open a ticket on this.
I have a couple of x10 devices as well.  They are motion sensors, which I have directly linked to Insteon switches, so I'm thinking it really won't matter if ISY no longer supports x10.
