Did a search but didn't find the answer I was looking for.
Have a pretty extensive Insteon network with the portal and Alexa and run everything through ISY. Have the Z-Wave module with my ISY but don't have a single Z-Wave device. What I'm wondering is, is there a way to link my security system using the Total Connect option and my automation system?
Vista 20P panel with (32) zones and two partitions. Need to swap my prom chip and add the 7547i internet communicator to my network to utilize Total Connect 2.0.
Also have five WiFi cameras, plus a Ring camera an other than the Echo Show accessing the Ring camera, none of these work together.
Any help?
there is a polyglot nodeserver for Total Connect, (I don't have it, so can't comment further)  https://github.com/dbarentine/udi-totalconnect-poly  There is also a forum Section for it: https://forum.universal-devices.com/forum/141-honeywell-total-connect-v2/
to use, you need Polisy... (currently you can still us it on a Pi, but as things are moving forward, Polisy is the answer as it can run the nodesever and replace your ISY... it's UDI's new all-in-one box... it's been around awhile for nodeservers, but it's just become possible weeks ago to run ISY on it, so therefor that portion is still being actively developed.)
Have you looked in the EnvisaLink™ EVL-4EZR For DSC & Honeywell Systems. This works with the ISY via node server.
Learning all sorts of new stuff today.
Doesn't look like the EnvisaLink does what I'm looking for. The Polisy looks like a good fit bit a bit of a budget bite after replacing my ISA last summer after my original died. Haven't made the add-ons to my Visa system yet and still paying for the monitoring company. Doing my research before sending the money and changing companies for the remote access. Have ADT Pulse for my small business and Protection One for home but now not much difference as ADT bought Protection One.
I'll have to look into the Polisy some more and figure out how it works to tie security, remote access, cameras and automation together.
