December 31, 200916 yr Hi, A proud new owner of an ISY99 and have figured out just about everything except integration with my EZRAIN v.FF. The ISY discovered the EZRAIN unit and added the zones however, will not operate the zones individually. Additionally, I have a keypad linc with buttons linked to the zones (works fine) and the ISY shows all EZRAIN zones (1- on each keypad linc button. If I operate the scene, all scenes will activate only zone one. Any help would be appreciated! Thank you!
December 31, 200916 yr Do you know what revision software you are using with your ISY? In the Help Tab About sections. Will give the firmware version. This may help if this was corrected in one of the Beta versions, many of us use.
December 31, 200916 yr Hi pacificsloop, We are working with SHN to figure out what changed between their version 24 (which works perfectly) and their latest firmware. It's now evident that the latest version of EZFlora do not work with ISY. I do apologize for the inconvenience. With kind regards, Michel
