I was Experimenting with the Z-Uno and found it to to work perfectly with Raspberry Pi Home Assistant but when testing it to the ISY 944i I was a little short in their implementation . I was reading a 2018 thread that said it was fully implemented I must be missing something cause it only picks up one of each the defined element.
Am I missing something here?
if someone could point me in the right direction it would be appreciated.
300 or 500 board?
Firmware  AND UI of your ISY
I upgraded the Z wave module to the the 500  when I upgraded to the 5.x.x.firmware. Been running a polglot node for my raspberry to bring  information in but it presents it poorly in the ISY device and doesn't work with mobilink
Well no Joy,, Matter of fact I lost all my Z wave devices and it will not  let me install them. I think it might be time to can the ISY Products I had a isy-26 then upgraded to the 99i then the 994i been in this for 10+ years getting a little disappointed in the advancement.
@DDavidson,
I suspect you didn't read the instructions for migrating to 5.3.4 (backup 300 Z-Wave and restore to 500). So, perhaps it is time to can 994 since, most probably, you are not aware of all the other advancements (such as Polisy and node servers) either.
Good luck.
With this statement, I assume you do not plan on ever buying another car, computer, phone, tv, house, etc? Everything in life gets upgraded at some point. 3 controllers in 10+ years is still less than a grand.
Ok  re-Formatted the sim car reinstalled the firmware and installed the configuration. It all seems to work to at least to where I was. The Z -Uno still is not reporting all the I/O thought it does with Home Assistant. Just for reference I had installed the new Zwave Card and had an old back up  I would not have been running Version 5.3.0 firmware if I had not replaced the card.  I am also aware of polglot being I have a node Running on a Raspberry Pi.  If you look at the statement that it is supported  in a previous thread on the forum.
