Tag queries or turn light on/off
@Jimbo I have noticed a few discrepancies with some of the Tag parameters that doesn't follow the WEB sight. If a query or set light on/off is done the 'Seconds Since Update' always goes to 3600 until its regular update.
If going out of range  'Seconds Since Update' will restart at 0 when 'Out Of Range' goes True. On the WEB site the count continues with no reset.
Also the 'Signal dbm' doesn't reflect properly.
I was thinking of using the 'Seconds Since Update' parameter in some programs but it is not consistent.
Just a little feedback.
Thanks Gary
Hey @garybixler, I've been working on this, check the issue link above.  I've not been able to get a tag to report as out-of-range yet.  I've configured the notifications and reporting time as instructed here https://wirelesstag.net/webapp.html#step4 in the logging section, then removed the battery and waited, but no report.  Is there another trick?
@JimboNot sure if removing the battery will result in out of range. What I do is wrap the tag tightly in aluminum foil for testing. Usually the tag is in my car for determining if it is home or away. I set the tag to record every 30 seconds to give the fastest response and if out of range to search every 5 minutes. I query the tag from a driveway sensor so it would never need to wait the 5 minutes. As the out of range may take 5 minutes or more I tried using the 'seconds since update' but was to inconsistent. Hopefully the update will work better.
Thanks gary
That's odd, I have just tested the 'Seconds Since Updates' and all seems to be working perfectly.  I Covered the tag with foil and after 5 mins or so it went out of range. There may be up to a 30 second delay until the NS server gets the out of range. I assume that is the polling interval and out of range doesn't trigger an immediate update.
Thanks Gary
8 hours ago, Jimbo said:
ok, will try that, but how does it know the difference of out-of-rang or if the battery is removed/dead?
Don't know if this helps, but the only time I have seen out of range is when the battery has died and the time exceeds the reporting window.
Thanks Gary
I can confirm seconds since update going to 3600 after a query. Saw it happen today.
2 minutes ago, Jimbo said:
Should be fixed in latest version 3.0.14 and beyond.
I installed v 3.0.13 this morning. I will check it out tomorrow.
