Sonos Available Commands
The Sonos PG3 version doesn't have a parent node. All nodes should have a parent node for status.
I have program alerts set for all of my nodes, so if they go offline I get a notification.
  • Michel Kohanim is there any requirement for nodes to have a parent or node status?
Node servers are not required to have a node dedicated to providing node server status.  Nor are node servers required to report node server status to the ISY.
Node server status (as it has been typically done) doesn't even really make sense with PG3.  If the node server dies or crashes, there isn't a running node server to report that fact. PG3 will only change the status if someone actually presses the button to start/stop the node server so if you're changing the status, you shouldn't need a notification to tell you that you changed the status.
It is possible for a node server to configure PG3 to send connection status to one of it's node values. However, that is only tracking the connection status between the node server and PG3.  It is possible (and probably likely) that a node server can fail while still remaining connected to PG3.
That seems like a step backwards in PG3 to not have a mechanism as it is in PG2? This morning I work up to an alert for my HUE node (ISY Program configured to email when the node was not connected), so I looked at PG2 and needed to start the HUE node. Are you saying that wouldn't work if/when HUE gets migrated to PG3?
I'm not saying that nothing will work. It depends on the node server design and what the node server author does with it. But because node servers are multi-threaded, it is very possible that one thread will crash while the thread that has the connection to PG3 continues and you'll never know that the node server isn't working.
What we need is for something to independently monitor the process and report back to the ISY when a node server is not functioning, but the ISY doesn't have anyway to handle that yet.
Nodeservers are designed by different developers so what one chooses to do with theirs may not be the same way for another.
I've experienced what bpwwer with my ecobee and harmony nodeservers so I get his point.
53 minutes ago, Michel Kohanim said:
I think this should be a hard requirement: all node servers must report heartbeat.
Then the ISY needs a way to accept a heartbeat.
4 hours ago, Michel Kohanim said:
@bpwwer, is that any different than adding a ST property for a Heartbeat node?
If you want to make it a hard requirement, then yes.  This is mostly just my opinion, but it seems like nodes are a representation of a device.  If the device supports a heartbeat, then the node can also.
Having a node represent the node server itself doesn't seem right to me. In general the node server should be invisible.  In support of this, I look at how Insteon and z-wave are implemented and neither of those have "control" nodes that represent the controllers.   I think of a node server as similar to a PLM or z-wave dongle just implemented in software vs. hardware.  I know this isn't a perfect analogy but it seems pretty close.
I know a node can represent anything and if we really want to create nodes that represent the node servers, then I think it should have a standard node definition and standardized driver types/command types and UOM's that are designed to represent that.
One of the reasons I've been hesitant to create nodes for my node servers is because of nodes being a limited resource and using one just to report the status of my node server seemed like a waste of that resource.  If this is no longer the case with IoP then I'm less opposed to these types of nodes.
1 hour ago, Michel Kohanim said:
@bpwwer,
I totally agree with you. We do not have any resource constraints on Polisy. And, once we get rid of that monster, mongodb, we'll gain back another 800MB. This said, and based on your explanation, I am not so sure. Perhaps we can ask @Chris Jahn.
This is maybe not the best place to discuss some of this.  I've some similar discussions over slack.
If we want to create nodes that represent the node servers, I think we should make that mandatory and provide a well defined definition that lists what is required of those nodes.  Today we have a mix of things.  Some node servers have a node just for node server status, some mix the status in with the device nodes, some don't report status at all.
In many cases, I've moved to not reporting status at all because what we have as node server status today isn't as useful as many think.  It really only tracks the mqtt connection between the node server and PG3 (which is it's own thread in the node server) so everything else in the node server could be failing and your connection status would still be good.
