sunrise and sunset times are wrong?
in the configuration I'm setup to Montreal, Canada but it's showing me:
Jan/9th/2010
rise: 8:21:53AM
set: 5:05:54PM
but when i look it up on the web, it should be:
rise: 7:33AM
Set: 4:30PM
Hello richard|007,
Please try using your latitude and longitude directly instead of using the region. This will give you much more accurate sunrise/sunset times for your specific location.
To do so:
1. Go to Configuration Tab | System
2. Click on Change Location and enter your own latitude and longitude
Jan/9th/2010
rise: 8:21:53AM
set: 5:05:54PM
rise: 7:33AM
Set: 4:30PM
  • 1 year later...
Must add that Montreal, QC has wrong Lat/Long info in the configuration, the ones in there looked up on google brings you somewhere in Ontario.
Any plans to correct this data?
Any plans to add more cities?
Any way we can put in Custom Location Name?
JS
I used Google found my exact Lat/Long and entered as custom. As for Montreal, you could use 45.5, -73.583333 instead of what is in there now (47.14,-84.39)
  • 11 months later...
What is the correct format for entering the Lat. and Long in the custom config. settings on the isy. Mine is 42.5 and 80.16. I've tried entering these in a multitude of different ways. The only thing that has been acceptable is 42.5. I'm not sure of the format for entering both. Nothing has worked at this point.
Brad Miller
I have the Lat and Long, but whenever i try to put them in i get invalid Lat or invalid Long error I've tried the locate me button, but it doesn't respond.
My Lat is 42.83576 , Long -80.30684. I am able to put in 42.8 as an acceptable input, but anything else and i get errors. I'm sure it's just the format that i'm using to
put in the numbers. An example would be a great help. I've tried 42.83576, -80.30684 to no avail.
Thanks for the help.
Brad Miller
Tried that. I get invalid Latitude error. I then put in 42.8 only, and it's ok. For some reason it won't accept any additional input.
I know, weird. I can only get the lat. 42.8 to be accepted. It will not accept any Long. setting. It still seems to work ok. The sunset time is now 8:35.05 which seems close to the actual which is 8:39. When i click on any of the preset cities, only the lat. is displayed. Is this why it only accepts a Lat. setting? Maybe there is a bug in my software.
Brad
Run Help | About, verify that both the Firmware line and UI line show 3.2.6.
As Michel suggested opening a Ticket with UDI support is appropriate as the 3.2.6 code does not normally operate as you are experiencing.
Same with my 99i and 994i. Only accepts Lat not Lon. I was able to enter my Lat in decimal format as 42.9xxxxx but in now way shape or form would it accept Lon. Results were good enough with just the Lat value so I didn't bother to mention the issue.
-Xathros
This i what i've tried to put in. I've also tried -80.3 for longitude with no luck. 42.8 is acceptable. I guess i'll have to contact udi support.
Thanks Xathros.
The problem is that ISY validates the longitude against the timezone. I suspect you are in Central Time so, you must use -6 for Timezone offset BEFORE trying to set the longitude.
Also, in ISY, longitudes are positive.
I'm GMT-5 Eastern. I try to enter the Lat, Lon and get Invalid Lat as an error. I've tried but positive and negative Lon with the same result every time. I selected NYC from the list and only see the Lat in the field so I don't have an example to imitate with my data. Exactly how should the Lat/Lon pair be formatted for entry ?
-Xathros
I'm in the same boat. -5 GMT offset doesn't work with the 40 lat 80 long settings. There must be a lot of people with the same problem who are just using the closest city on the programmed list and not the custom setting.
