kevincol Posted April 3, 2022 Share Posted April 3, 2022 The launcher sees my ISY994i, but when the admin console launches, my U/P isn't valid. Any ideas how I can regain access to my ISY994i. I do have a backup. Link to comment
Techman Posted April 3, 2022 Share Posted April 3, 2022 After the update did you clear your java cache and its applications, and then download the ISY Launcher? Link to comment
kevincol Posted April 3, 2022 Author Share Posted April 3, 2022 Yes I did. I just did a factory reset and reloaded my backup file and then reset my P/U back to the original and all seems to be working now. Thanks! Link to comment
Geddy Posted April 3, 2022 Share Posted April 3, 2022 @kevincol Glad you got it working now. As part of the upgrade the password is reset to the default. So you should have been using admin/admin then could change it to anything you'd like. It's casually mentioned in the notes of the release. I think it sometimes depends on what you're upgrading from. Quote Important User/Password changes: - If your current version is 5.0.7 or earlier, then after installing 5.0.8 or later your userid and password will be reset back to the system default. - If you restore a backup created from 5.0.7 or earlier, your userid and password will be reset back to the system default. 2 Link to comment
