Just in case anyone is interested, the PLM manufacturer we are working with, has the following:
700 IOLincs
1000 SwitchLinc Relays
I told him that I would ask the community whether or not anyone is interested and let him know. Costwise, though, when you add shipping and customs, they will be around $50 to $55 each. Also, there's no warranty of any sort.
700 IOLincs
I would probably be interested in a couple of the IOLincs
1 hour ago, oskrypuch said:
Hmm, odd (to me) that it doesn't include a PS.
* Orest
Odd to me that if it doesn't include a power supply, it doesn't have a DIN rail option at least.  Would make total sense in a big DIN enclosure.
@Michel Kohanim - First off - just to parrot many others, it would be amazing if you were able to pick up the IP and continue to support the community.  I love my ISY and use it for much more complex scripting than what is easily achievable natively within HA or HS.
To your question above, I'd be interested in ~10 SwitchLincs.  And, I know not your job, but do you know if they (or any other manufacturers) have any other inventory - specifically Din Dimmers, Micro Dimmers, Dimmer Switches or KPLs of any type?
Finally, if you are able to acquire the IP, I know your ideal path forward other than PLMs would be licensing but would you consider a run of "existing" devices if the demand were there?
I'd be interested in 10 switchlinc wall dimmers 2477D if they are sealed and new in box from the factory.  But mainly if UD is able to get the IP and produce PLM's and keep the platform going. I still have about 15 switchlinc relays unopened from a guest house project that never materialized so I might just start swapping those in place of dimmers if all else fails over time.
Edited by Shawn gates
      379.8k
