2 new feature requests for PG3, Emporia Vue2 and CAI WebControl 8 Node Servers
I can report using the emporia vue test version.  It is working quite well and filling all of my needs.  I do not, however, have any individual circuit monitoring and have no idea if the updates address any of that.  Basically, all I needed was real time wattage of the main bus, and the updated version does that along with showing other metrics of usage.
I am using the real time watt usage to regulate the speed that my Tesla charges.  I'm trying to cap my wattage at 15kw and am able to do this using Emporia Vue and the Tesla EV app.  A series of 4 programs and 1 variable allow me to ramp up or down the Tesla charging between 0 and 5kw in 1kw increments in response to my total usage.  If you changed the numbers in the equations, you could ramp in smaller or larger increments and up to higher wattages if so desired.
  • Like 1
Posted (edited)
@apostolakisl Great use case, thanks for sharing. I am sure that type of action will become more important as time goes on given the current state of the power grid.
@bpwwer I respect your time and appreciate the work you have put into this NS. I understand it will be a while probably before, if at all, you will have time to revisit it. In the small chance you do have time in the future, would having my log be of any use. I would be happy to send it, I would just need to know where to send it.
The log shows starting to retrieve all the sensors but stops at #6 and error with a traceback:
Log removed, Tim
I though perhaps it was my sensor naming convention as I had some long names but I shortened them all, restarted PG3 but still errored at the same spot.
This is the view of the nodes I get in ISY:
Anyway, I have wasted enough of your time. Thank you!
-Tim
Edited by TJF1960
I tried to attach my log file but the upload fails. I figured since I have the Vue charger it might be of some value to see how it is handled. Thanks for your hard work @bpwwer
2022-09-01 20:26:40,618 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-09-01 20:26:45,711 Thread-74  udi_interface      INFO     vue:getDeviceId: Device Info:  31548  A2040A04B48CAAB5BA76FC  VUE002  Vue2-159  Home  13.0
2022-09-01 20:26:46,031 Thread-74  udi_interface      INFO     vue:getDeviceId: Device Info:  31548  SXA2040A04B48CAAB5BA76FC  WAT001  None  Home  13.0
2022-09-01 20:26:46,340 Thread-74  udi_interface      INFO     vue:getDeviceId: Device Info:  81882  D2135A090198CDACB02678  VVDN01  EVCharger-145  Tesla  13.0
2022-09-01 20:26:47,074 Thread-78  udi_interface      INFO     vue:query: Query: get device usage for 1s
2022-09-01 20:26:47,431 Thread-78  udi_interface      INFO     vue:query: Getting usage for
2022-09-01 20:26:47,433 Thread-78  udi_interface      INFO     vue:query: Getting usage for
2022-09-01 20:26:47,454 Thread-5   udi_interface      INFO     vue:start: Node server configured, get device information
2022-09-01 20:26:47,456 Thread-5   udi_interface      INFO     vue:deviceinfo: Devices:
2022-09-01 20:26:47,563 MQTT       udi_interface.interface INFO     interface:_message: Successfully set controller :: CPW to 0.6396 UOM 30
2022-09-01 20:26:48,437 Thread-5   udi_interface      INFO     vue:deviceinfo: GID:         31548
2022-09-01 20:26:48,438 Thread-5   udi_interface      INFO     vue:deviceinfo: Manufacturer:A2040A04B48CAAB5BA76FC
2022-09-01 20:26:48,439 Thread-5   udi_interface      INFO     vue:deviceinfo: Model:       VUE002
2022-09-01 20:26:48,440 Thread-5   udi_interface      INFO     vue:deviceinfo: Firmware:    Vue2-159
2022-09-01 20:26:48,440 Thread-5   udi_interface      INFO     vue:deviceinfo: Name:        Home
2022-09-01 20:26:48,441 Thread-5   udi_interface      INFO     vue:deviceinfo: Price/kwh:   13.0
2022-09-01 20:26:48,442 Thread-5   udi_interface      INFO     vue:deviceinfo: --------------------------------------------
2022-09-01 20:26:48,742 Thread-5   udi_interface      INFO     vue:deviceinfo: GID:         31548
2022-09-01 20:26:48,743 Thread-5   udi_interface      INFO     vue:deviceinfo: Manufacturer:SXA2040A04B48CAAB5BA76FC
2022-09-01 20:26:48,744 Thread-5   udi_interface      INFO     vue:deviceinfo: Model:       WAT001
2022-09-01 20:26:48,745 Thread-5   udi_interface      INFO     vue:deviceinfo: Firmware:    None
2022-09-01 20:26:48,746 Thread-5   udi_interface      INFO     vue:deviceinfo: Name:        Home
2022-09-01 20:26:48,747 Thread-5   udi_interface      INFO     vue:deviceinfo: Price/kwh:   13.0
2022-09-01 20:26:48,748 Thread-5   udi_interface      INFO     vue:deviceinfo: --------------------------------------------
2022-09-01 20:26:49,059 Thread-5   udi_interface      INFO     vue:deviceinfo: GID:         81882
2022-09-01 20:26:49,060 Thread-5   udi_interface      INFO     vue:deviceinfo: Manufacturer:D2135A090198CDACB02678
2022-09-01 20:26:49,061 Thread-5   udi_interface      INFO     vue:deviceinfo: Model:       VVDN01
2022-09-01 20:26:49,061 Thread-5   udi_interface      INFO     vue:deviceinfo: Firmware:    EVCharger-145
2022-09-01 20:26:49,062 Thread-5   udi_interface      INFO     vue:deviceinfo: Name:        Tesla
2022-09-01 20:26:49,063 Thread-5   udi_interface      INFO     vue:deviceinfo: Price/kwh:   13.0
2022-09-01 20:26:49,064 Thread-5   udi_interface      INFO     vue:deviceinfo: Found a charger:  True
2022-09-01 20:26:49,065 Thread-5   udi_interface      INFO     vue:deviceinfo: Charge rate:      14
2022-09-01 20:26:49,065 Thread-5   udi_interface      INFO     vue:deviceinfo: Max charge rate:  24
2022-09-01 20:26:49,066 Thread-5   udi_interface      INFO     vue:deviceinfo: --------------------------------------------
2022-09-01 20:26:49,067 Thread-5   udi_interface      INFO     vue:deviceinfo: Usage Info for scale=Hour:
2022-09-01 20:26:49,095 Thread-79  udi_interface      INFO     vue:query: Query: get device usage for 1s
2022-09-01 20:26:49,404 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 1,2,3 Home 1.01071102777693 1.0 kwh
2022-09-01 20:26:49,406 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 1 Solar -1.6114968193901915e-05 1.0 kwh
2022-09-01 20:26:49,407 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 2 Solar -0.0004135190751817491 1.0 kwh
2022-09-01 20:26:49,408 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 3 C OS Rec & Bathroom Rec 0.023141127416822647 1.0 kwh
2022-09-01 20:26:49,422 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 4 C Furnace 0.13632103180103833 1.0 kwh
2022-09-01 20:26:49,428 Thread-79  udi_interface      INFO     vue:query: Getting usage for
2022-09-01 20:26:49,429 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 5 C Refrigerator 0.04846293042712742 1.0 kwh
2022-09-01 20:26:49,432 Thread-79  udi_interface      INFO     vue:query: Getting usage for
2022-09-01 20:26:49,432 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 6 C Closet Equipment 0.009101372422642178 1.0 kwh
2022-09-01 20:26:49,435 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 7 Kitchen Receptacles 0.0 1.0 kwh
2022-09-01 20:26:49,436 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 8 B MW Land Rec & Lt 0.0002525518759091695 1.0 kwh
2022-09-01 20:26:49,437 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 9 C Clothes Washer/Dryer 0.0 1.0 kwh
2022-09-01 20:26:49,438 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 10 C Kitchen Receptacles 0.00013895911706818479 1.0 kwh
2022-09-01 20:26:49,438 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 11 B Living Room 0.15119837292141383 1.0 kwh
2022-09-01 20:26:49,439 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 12 B Master and Bedroom 2 0.006301597463289897 1.0 kwh
2022-09-01 20:26:49,440 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 13 B Kitchen and Outside Lt 0.0030821769567330685 1.0 kwh
2022-09-01 20:26:49,441 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 14 B Office and Bathroom Lt 0.01446575371583303 1.0 kwh
2022-09-01 20:26:49,442 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 15 Range 0.0 1.0 kwh
2022-09-01 20:26:49,443 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 16 Air Conditioner 0.6108070323944091 1.0 kwh
2022-09-01 20:26:49,444 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 TotalUsage TotalUsage 1.0111406618203056 1.0 kwh
2022-09-01 20:26:49,445 Thread-5   udi_interface      INFO     vue:print_recursive:  31548 Balance Balance 0.007867755308018753 1.0 kwh
2022-09-01 20:26:49,446 Thread-5   udi_interface      INFO     vue:print_recursive:  81882 1,2,3 Tesla 0.0 1.0 kwh
@TJF1960Looks like I have an error in the code that dumps the device info.  That doesn't really effect the operation but I'll need to fix that.  I see you have an outlet but the bug prevented it from dumping the info for that device.  It will be helpful to see what the outlet looks like.
@tazmanThanks!  Yes, seeing what the EV charger looks like does help.
Changing the node server to support more than just the main channel will be a bit of work, I've been thinking about how to do it and have some ideas and should have something to test in a couple of weeks.
  • Like 2
I just pushed out a new version of VueTest to the non-production store.
Version 1.0.8 re-writes the node server to support devices with multiple sensor channels.  With this version you should ge a primary node created for each device.  Each of those primary nodes will then have a child node created for each configured sensor channel supported by that device.
For me, with the single channel device that I have, I get one primary node just like I did before so I'm pretty sure that part is still working.
I haven't looked at how this will behave with outlets or EV chargers so for those that have them, I'm curious to know if it creates a primary node for them and if so, is what it reports at all meaningful.
** Yes, the extra hot holiday weekend has provided some time to work on stuff like this.
  • Like 1
Posted (edited)
Hi @bpwwer v1.0.8 installed as seen but the blue memo indicating an update is available still shows after reboot. Try rebooting NS and PG3.
It detected 2 out of four plugs but is not reporting data:
Here is one new node created:
The main node displays as before, no issues with it.
Here is the log from restart with update:
Log removed, Tim
Edited by TJF1960
@KevinI think I have that fixed and will push out a new version shortly.
I'm using the GID for the node address and since the GID is a number, it treats it as a number where the node address should be string.  In some cases it doesn't matter, but in others it does.  I think I have that all corrected now.
@TJF1960looks like the same issue is effecting you too.
Ok, I just pushed out version 1.0.9.
Use the "Refresh Store" button to get your local listing updated and then restart and see if that works.   It's possible that the change in the addressing will cause some issues when updating.  If you end up with multiple nodes for the same you may just want to delete the node server, clean up any nodes that it leaves behind in the AC and re-install.
This version should add more support for the EV charger.  You should see the charge rates and charge state on the node and controls to turn the charger on/off and set the rate.
  • Like 1
Posted (edited)
Hi @bpwwer, sorry still throwing operand error after discovering the 3rd device.
Also, both new nodes created in ISY stated disconnected, may be expected though.
Here is the log:
Log removed, Tim
Edited by TJF1960
Same problem, just with the child nodes (which I can't test since my device doesn't have any)
Should be fixed in 1.0.10.  See if we can get a bit farther.
9 minutes ago, Kevin said:
sounds good do your want a log of the 1.0.9 at all
I don't think so.  Try 1.0.10.  If something doesn't look right, then send the log for that.
@bpwwerMine is showing 13 of the 16 sub nodes but seems to stop at the charger. I also noticed all of the values are the same for all of the nodes created.
2022-09-04 16:15:59,569 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING notices
2022-09-04 16:15:59,570 Command    udi_interface.custom DEBUG    custom:load: CUSTOM: load {}
2022-09-04 16:15:59,608 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-09-04 16:15:59,648 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
2022-09-04 16:16:00,266 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2022-09-04 16:16:00,267 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2022-09-04 16:16:02,236 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2022-09-04 16:16:02,238 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2022-09-04 16:16:04,242 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2022-09-04 16:16:04,244 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2022-09-04 16:16:05,173 Thread-3   udi_interface      INFO     vue:discover: GID:               31548
2022-09-04 16:16:05,174 Thread-3   udi_interface      INFO     vue:discover: Manufacturer:      A2040A04B48CAAB5BA76FC
2022-09-04 16:16:05,175 Thread-3   udi_interface      INFO     vue:discover: Model:             VUE002
2022-09-04 16:16:05,176 Thread-3   udi_interface      INFO     vue:discover: Firmware:          Vue2-159
2022-09-04 16:16:05,176 Thread-3   udi_interface      INFO     vue:discover: Name:              Home
2022-09-04 16:16:05,177 Thread-3   udi_interface      INFO     vue:discover: Creating device node for Home (31548)
2022-09-04 16:16:05,179 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548 default CPW to 0 / 30
2022-09-04 16:16:05,180 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548 default GV1 to 0 / 33
2022-09-04 16:16:05,181 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548 default GV2 to 0 / 33
2022-09-04 16:16:05,181 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548 default GV3 to 0 / 33
2022-09-04 16:16:05,182 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548 default ST to 1 / 25
2022-09-04 16:16:05,183 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Home(31548) [None]
2022-09-04 16:16:05,184 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548', 'name': 'Home', 'nodeDefId': 'controller', 'primaryNode': '31548', 'drivers': [{'driver': 'ST', 'value': '1', 'uom': 25}, {'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,186 Thread-3   udi_interface.interface INFO     interface:setController: Using node "31548", driver "ST" for connection status.
2022-09-04 16:16:05,188 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'setController': {'node': '31548', 'driver': 'ST'}}
2022-09-04 16:16:05,190 Thread-3   udi_interface      INFO     vue:discover: Found channel: 1,2,3 - None
2022-09-04 16:16:05,488 Thread-3   udi_interface      INFO     vue:discover: GID:               31548
2022-09-04 16:16:05,489 Thread-3   udi_interface      INFO     vue:discover: Manufacturer:      SXA2040A04B48CAAB5BA76FC
2022-09-04 16:16:05,490 Thread-3   udi_interface      INFO     vue:discover: Model:             WAT001
2022-09-04 16:16:05,491 Thread-3   udi_interface      INFO     vue:discover: Firmware:          None
2022-09-04 16:16:05,492 Thread-3   udi_interface      INFO     vue:discover: Name:              Home
2022-09-04 16:16:05,492 Thread-3   udi_interface      INFO     vue:discover: Found channel: 1 - Solar
2022-09-04 16:16:05,494 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_1 default CPW to 0 / 30
2022-09-04 16:16:05,495 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_1 default GV1 to 0 / 33
2022-09-04 16:16:05,496 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_1 default GV2 to 0 / 33
2022-09-04 16:16:05,497 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_1 default GV3 to 0 / 33
2022-09-04 16:16:05,497 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Solar(31548_1) [None]
2022-09-04 16:16:05,498 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_1', 'name': 'Solar', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,500 Thread-3   udi_interface      INFO     vue:discover: Found channel: 2 - Solar
2022-09-04 16:16:05,502 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_2 default CPW to 0 / 30
2022-09-04 16:16:05,503 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_2 default GV1 to 0 / 33
2022-09-04 16:16:05,504 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_2 default GV2 to 0 / 33
2022-09-04 16:16:05,505 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_2 default GV3 to 0 / 33
2022-09-04 16:16:05,505 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Solar(31548_2) [None]
2022-09-04 16:16:05,506 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_2', 'name': 'Solar', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,508 Thread-3   udi_interface      INFO     vue:discover: Found channel: 3 - C OS Rec & Bathroom Rec
2022-09-04 16:16:05,510 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_3 default CPW to 0 / 30
2022-09-04 16:16:05,511 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_3 default GV1 to 0 / 33
2022-09-04 16:16:05,512 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_3 default GV2 to 0 / 33
2022-09-04 16:16:05,512 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_3 default GV3 to 0 / 33
2022-09-04 16:16:05,513 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C OS Rec & Bathroom Rec(31548_3) [None]
2022-09-04 16:16:05,514 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_3', 'name': 'C OS Rec & Bathroom Rec', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,516 Thread-3   udi_interface      INFO     vue:discover: Found channel: 4 - C Furnace
2022-09-04 16:16:05,518 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_4 default CPW to 0 / 30
2022-09-04 16:16:05,518 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_4 default GV1 to 0 / 33
2022-09-04 16:16:05,519 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_4 default GV2 to 0 / 33
2022-09-04 16:16:05,520 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_4 default GV3 to 0 / 33
2022-09-04 16:16:05,521 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C Furnace(31548_4) [None]
2022-09-04 16:16:05,522 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_4', 'name': 'C Furnace', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,524 Thread-3   udi_interface      INFO     vue:discover: Found channel: 5 - C Refrigerator
2022-09-04 16:16:05,526 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_5 default CPW to 0 / 30
2022-09-04 16:16:05,527 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_5 default GV1 to 0 / 33
2022-09-04 16:16:05,527 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_5 default GV2 to 0 / 33
2022-09-04 16:16:05,528 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_5 default GV3 to 0 / 33
2022-09-04 16:16:05,529 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C Refrigerator(31548_5) [None]
2022-09-04 16:16:05,530 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_5', 'name': 'C Refrigerator', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,532 Thread-3   udi_interface      INFO     vue:discover: Found channel: 6 - C Closet Equipment
2022-09-04 16:16:05,534 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_6 default CPW to 0 / 30
2022-09-04 16:16:05,534 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_6 default GV1 to 0 / 33
2022-09-04 16:16:05,535 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_6 default GV2 to 0 / 33
2022-09-04 16:16:05,536 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_6 default GV3 to 0 / 33
2022-09-04 16:16:05,537 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C Closet Equipment(31548_6) [None]
2022-09-04 16:16:05,538 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_6', 'name': 'C Closet Equipment', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,540 Thread-3   udi_interface      INFO     vue:discover: Found channel: 7 - Kitchen Receptacles
2022-09-04 16:16:05,541 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_7 default CPW to 0 / 30
2022-09-04 16:16:05,543 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_7 default GV1 to 0 / 33
2022-09-04 16:16:05,543 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_7 default GV2 to 0 / 33
2022-09-04 16:16:05,544 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_7 default GV3 to 0 / 33
2022-09-04 16:16:05,545 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Kitchen Receptacles(31548_7) [None]
2022-09-04 16:16:05,546 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_7', 'name': 'Kitchen Receptacles', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,548 Thread-3   udi_interface      INFO     vue:discover: Found channel: 8 - B MW Land Rec & Lt
2022-09-04 16:16:05,549 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_8 default CPW to 0 / 30
2022-09-04 16:16:05,550 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_8 default GV1 to 0 / 33
2022-09-04 16:16:05,551 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_8 default GV2 to 0 / 33
2022-09-04 16:16:05,552 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_8 default GV3 to 0 / 33
2022-09-04 16:16:05,553 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node B MW Land Rec & Lt(31548_8) [None]
2022-09-04 16:16:05,554 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_8', 'name': 'B MW Land Rec & Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,556 Thread-3   udi_interface      INFO     vue:discover: Found channel: 9 - C Clothes Washer/Dryer
2022-09-04 16:16:05,558 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_9 default CPW to 0 / 30
2022-09-04 16:16:05,558 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_9 default GV1 to 0 / 33
2022-09-04 16:16:05,559 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_9 default GV2 to 0 / 33
2022-09-04 16:16:05,560 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_9 default GV3 to 0 / 33
2022-09-04 16:16:05,561 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C Clothes Washer/Dryer(31548_9) [None]
2022-09-04 16:16:05,562 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_9', 'name': 'C Clothes Washer/Dryer', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,564 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message setController
2022-09-04 16:16:05,566 Thread-3   udi_interface      INFO     vue:discover: Found channel: 10 - C Kitchen Receptacles
2022-09-04 16:16:05,567 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING setController
2022-09-04 16:16:05,570 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_10 default CPW to 0 / 30
2022-09-04 16:16:05,571 Command    udi_interface.interface DEBUG    interface:_handleInput: connection status node/driver update
2022-09-04 16:16:05,572 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_10 default GV1 to 0 / 33
2022-09-04 16:16:05,574 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_10 default GV2 to 0 / 33
2022-09-04 16:16:05,575 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_10 default GV3 to 0 / 33
2022-09-04 16:16:05,575 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node C Kitchen Receptacles(31548_10) [None]
2022-09-04 16:16:05,576 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_10', 'name': 'C Kitchen Receptacles', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,579 Thread-3   udi_interface      INFO     vue:discover: Found channel: 11 - B Living Room
2022-09-04 16:16:05,580 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_11 default CPW to 0 / 30
2022-09-04 16:16:05,581 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_11 default GV1 to 0 / 33
2022-09-04 16:16:05,582 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_11 default GV2 to 0 / 33
2022-09-04 16:16:05,583 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_11 default GV3 to 0 / 33
2022-09-04 16:16:05,584 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node B Living Room(31548_11) [None]
2022-09-04 16:16:05,585 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_11', 'name': 'B Living Room', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,587 Thread-3   udi_interface      INFO     vue:discover: Found channel: 12 - B Master and Bedroom 2
2022-09-04 16:16:05,588 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_12 default CPW to 0 / 30
2022-09-04 16:16:05,589 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_12 default GV1 to 0 / 33
2022-09-04 16:16:05,590 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_12 default GV2 to 0 / 33
2022-09-04 16:16:05,591 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_12 default GV3 to 0 / 33
2022-09-04 16:16:05,591 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node B Master and Bedroom 2(31548_12) [None]
2022-09-04 16:16:05,592 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_12', 'name': 'B Master and Bedroom 2', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,594 Thread-3   udi_interface      INFO     vue:discover: Found channel: 13 - B Kitchen and Outside Lt
2022-09-04 16:16:05,596 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_13 default CPW to 0 / 30
2022-09-04 16:16:05,597 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_13 default GV1 to 0 / 33
2022-09-04 16:16:05,598 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_13 default GV2 to 0 / 33
2022-09-04 16:16:05,599 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_13 default GV3 to 0 / 33
2022-09-04 16:16:05,599 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node B Kitchen and Outside Lt(31548_13) [None]
2022-09-04 16:16:05,600 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_13', 'name': 'B Kitchen and Outside Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,602 Thread-3   udi_interface      INFO     vue:discover: Found channel: 14 - B Office and Bathroom Lt
2022-09-04 16:16:05,604 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_14 default CPW to 0 / 30
2022-09-04 16:16:05,605 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_14 default GV1 to 0 / 33
2022-09-04 16:16:05,606 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_14 default GV2 to 0 / 33
2022-09-04 16:16:05,607 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_14 default GV3 to 0 / 33
2022-09-04 16:16:05,608 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node B Office and Bathroom Lt(31548_14) [None]
2022-09-04 16:16:05,609 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_14', 'name': 'B Office and Bathroom Lt', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,611 Thread-3   udi_interface      INFO     vue:discover: Found channel: 15 - Range
2022-09-04 16:16:05,613 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_15 default CPW to 0 / 30
2022-09-04 16:16:05,613 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_15 default GV1 to 0 / 33
2022-09-04 16:16:05,614 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_15 default GV2 to 0 / 33
2022-09-04 16:16:05,615 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_15 default GV3 to 0 / 33
2022-09-04 16:16:05,616 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Range(31548_15) [None]
2022-09-04 16:16:05,617 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_15', 'name': 'Range', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,619 Thread-3   udi_interface      INFO     vue:discover: Found channel: 16 - Air Conditioner
2022-09-04 16:16:05,621 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_16 default CPW to 0 / 30
2022-09-04 16:16:05,621 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_16 default GV1 to 0 / 33
2022-09-04 16:16:05,622 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_16 default GV2 to 0 / 33
2022-09-04 16:16:05,623 Thread-3   udi_interface.node DEBUG    node:_updateDrivers: Update 31548_16 default GV3 to 0 / 33
2022-09-04 16:16:05,624 Thread-3   udi_interface.interface INFO     interface:addNode: Adding node Air Conditioner(31548_16) [None]
2022-09-04 16:16:05,625 Thread-3   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': '31548_16', 'name': 'Air Conditioner', 'nodeDefId': 'channel', 'primaryNode': '31548', 'drivers': [{'driver': 'CPW', 'value': 0, 'uom': 30}, {'driver': 'GV1', 'value': 0, 'uom': 33}, {'driver': 'GV2', 'value': 0, 'uom': 33}, {'driver': 'GV3', 'value': 0, 'uom': 33}], 'hint': [0, 0, 0, 0], 'private': None}]}
2022-09-04 16:16:05,977 Thread-3   udi_interface      INFO     vue:discover: GID:               81882
2022-09-04 16:16:05,978 Thread-3   udi_interface      INFO     vue:discover: Manufacturer:      D2135A090198CDACB02678
2022-09-04 16:16:05,979 Thread-3   udi_interface      INFO     vue:discover: Model:             VVDN01
2022-09-04 16:16:05,980 Thread-3   udi_interface      INFO     vue:discover: Firmware:          EVCharger-145
2022-09-04 16:16:05,981 Thread-3   udi_interface      INFO     vue:discover: Name:              Tesla
2022-09-04 16:16:05,981 Thread-3   udi_interface      INFO     vue:discover: Charge rate:       14
2022-09-04 16:16:05,982 Thread-3   udi_interface      INFO     vue:discover: Max charge rate:   24
2022-09-04 16:16:05,983 Thread-3   udi_interface      INFO     vue:discover: Creating device node for Tesla (81882)
2022-09-04 16:16:05,983 Thread-3   udi_interface      ERROR    vue:parameterHandler: Discovery failed: super(type, obj): obj must be an instance or subtype of type
2022-09-04 16:16:06,241 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2022-09-04 16:16:06,243 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
All the logs are showing the same issue.  I had an error in the code when creating the outlet and charger nodes so as soon as it tried to create one of those, it crashed.
Version 1.0.11 should fix that problem.   Let's see what the next on is.
@TJF1960I have a separate car charger that connects to the account and that is the last item showed in my log. If that is the problem I can delete it and move one of my solar ct's to the car charger and control it from the car.
Sorry Bob I found the main panel I forgot I just called it panel. it dose have all 16 channels also but again it shows up as a switch with on and off not watts.
Posted (edited)
Hi @bpwwer, Wow, a lot closer this time. 21 nodes created in ISY, but they all look like this:
Log file has a bunch of repetitive errors so I cut it short:
Log removed, Tim
Edited by TJF1960
@KevinTry deleting the node from PG3 and reinstalling it that got my nodes showing with values again. @bpwwerI still only get 13 of the ct's but I do have a node for the charger now but they still show the same value for all of them. I also don't have the main imporia VUE node in the AC.
2022-09-04 17:59:31,540 Thread-41  udi_interface      INFO     vue:query: 1,2,3 -- 0.347559517554707
2022-09-04 17:59:31,549 Thread-41  udi_interface.node DEBUG    node:setDriver: 31548:Home Reporting set GV1 to 0.3476 to Polyglot
2022-09-04 17:59:31,556 Thread-45  udi_interface      INFO     vue:query: 1,2,3 -- 9.084364997016059e-05
2022-09-04 17:59:31,559 Thread-45  udi_interface.node DEBUG    node:setDriver: 31548:Home Reporting set CPW to 0.327 to Polyglot
2022-09-04 17:59:31,561 Thread-45  udi_interface.node DEBUG    node:reportDriver: Updating value to 0.327
2022-09-04 17:59:31,562 Thread-45  udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'address': '31548', 'driver': 'CPW', 'value': '0.327', 'uom': 30}]}
2022-09-04 17:59:31,565 Thread-45  udi_interface      INFO     vue:query: 1 -- -4.067331102159288e-05
2022-09-04 17:59:31,568 Thread-45  udi_interface      ERROR    udi_interface:write: Exception in thread
2022-09-04 17:59:31,570 Thread-45  udi_interface      ERROR    udi_interface:write: Thread-45
2022-09-04 17:59:31,571 Thread-45  udi_interface      ERROR    udi_interface:write: :
2022-09-04 17:59:31,572 Thread-45  udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-09-04 17:59:31,573 Thread-45  udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2022-09-04 17:59:31,557 Thread-41  udi_interface.node DEBUG    node:reportDriver: Updating value to 0.3476
2022-09-04 17:59:31,580 Thread-41  udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'address': '31548', 'driver': 'GV1', 'value': '0.3476', 'uom': 33}]}
2022-09-04 17:59:31,582 Thread-45  udi_interface      ERROR    udi_interface:write: self.run()
2022-09-04 17:59:31,583 Thread-41  udi_interface      INFO     vue:query: 1 -- -0.9594595123587715
2022-09-04 17:59:31,584 Thread-45  udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2022-09-04 17:59:31,585 Thread-41  udi_interface      ERROR    vue:parameterHandler: Discovery failed: unsupported operand type(s) for +: 'int' and 'str'
2022-09-04 17:59:31,590 Thread-45  udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-09-04 17:59:31,592 Thread-45  udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_10/./vue.py", line 25, in poll
2022-09-04 17:59:31,593 Thread-45  udi_interface      ERROR    udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True)
2022-09-04 17:59:31,594 Thread-45  udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_10/./vue.py", line 50, in query
2022-09-04 17:59:31,596 Thread-45  udi_interface      ERROR    udi_interface:write: address = gid + '_' + channel.channel_num
2022-09-04 17:59:31,596 Thread-45  udi_interface      ERROR    udi_interface:write: TypeError
2022-09-04 17:59:31,597 Thread-45  udi_interface      ERROR    udi_interface:write: :
2022-09-04 17:59:31,598 Thread-45  udi_interface      ERROR    udi_interface:write: unsupported operand type(s) for +: 'int' and 'str'
2022-09-04 17:59:31,696 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message addnode
2022-09-04 17:59:31,697 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING addnode
2022-09-04 17:59:31,699 Command    udi_interface.interface DEBUG    interface:_handleResult: add node response: {'id': '2e9f1a71-2eac-4a6b-9f0e-0a92ba360383', 'uuid': '00:0d:b9:53:d3:9c', 'profileNum': 10, 'address': '31548', 'name': 'Home', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '31548', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1662339571280, 'timeModified': 1662339571280, 'dbVersion': 1}
2022-09-04 17:59:33,483 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2022-09-04 17:59:33,485 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2022-09-04 17:59:33,616 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message addnode
2022-09-04 17:59:33,618 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING addnode
2022-09-04 17:59:33,620 Command    udi_interface.interface DEBUG    interface:_handleResult: add node response: {'id': '2e4c3ead-5cf2-4b38-ac22-5e66e2500323', 'uuid': '00:0d:b9:53:d3:9c', 'profileNum': 10, 'address': '31548_1', 'name': 'Solar', 'nodeDefId': 'channel', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '31548', 'private': None, 'isPrimary': 0, 'enabled': 1, 'timeAdded': 1662339572321, 'timeModified': 1662339572321, 'dbVersion': 1}
2022-09-04 17:59:33,824 Thread-47  udi_interface      INFO     vue:query: 1,2,3 -- 8.893212212456598e-05
2022-09-04 17:59:33,825 Thread-47  udi_interface.node DEBUG    node:setDriver: 31548:Home Reporting set CPW to 0.3202 to Polyglot
2022-09-04 17:59:33,826 Thread-47  udi_interface.node DEBUG    node:reportDriver: Updating value to 0.3202
2022-09-04 17:59:33,827 Thread-47  udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'address': '31548', 'driver': 'CPW', 'value': '0.3202', 'uom': 30}]}
2022-09-04 17:59:33,829 Thread-47  udi_interface      INFO     vue:query: 1 -- -4.050372017754449e-05
2022-09-04 17:59:33,829 Thread-47  udi_interface      ERROR    udi_interface:write: Exception in thread
2022-09-04 17:59:33,830 Thread-47  udi_interface      ERROR    udi_interface:write: Thread-47
2022-09-04 17:59:33,831 Thread-47  udi_interface      ERROR    udi_interface:write: :
2022-09-04 17:59:33,831 Thread-47  udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-09-04 17:59:33,832 Thread-47  udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2022-09-04 17:59:33,835 Thread-47  udi_interface      ERROR    udi_interface:write: self.run()
2022-09-04 17:59:33,837 Thread-47  udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2022-09-04 17:59:33,840 Thread-47  udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-09-04 17:59:33,841 Thread-47  udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_10/./vue.py", line 25, in poll
2022-09-04 17:59:33,842 Thread-47  udi_interface      ERROR    udi_interface:write: query(pyemvue.enums.Scale.SECOND.value, extra=True)
2022-09-04 17:59:33,843 Thread-47  udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d3:9c_10/./vue.py", line 50, in query
2022-09-04 17:59:33,844 Thread-47  udi_interface      ERROR    udi_interface:write: address = gid + '_' + channel.channel_num
2022-09-04 17:59:33,845 Thread-47  udi_interface      ERROR    udi_interface:write: TypeError
2022-09-04 17:59:33,846 Thread-47  udi_interface      ERROR    udi_interface:write: :
2022-09-04 17:59:33,846 Thread-47  udi_interface      ERROR    udi_interface:write: unsupported operand type(s) for +: 'int' and 'str'
Hi @tazman, no joy but thank you for the suggestion. It still loaded the 16 sensor but main node plug the 4 switches but no data visible in ISY or in the node server.
That's weird I wonder what made mine change then??
