Node server if failed state
I found the Node server in a failed state this morning.  Here's the error:
2022-05-18 02:06:53 error: NS: uncaughtException REPORT THIS!: TypeError: Cannot read properties of undefined (reading 'baseUrl')
    at NotificationListener.topologyChange (/var/polyglot/pg3/ns/00:0d:b9:53:3f:34_9/node_modules/sonos-discovery/lib/SonosSystem.js:109:30)
    at NotificationListener.emit (node:events:390:28)
    at /var/polyglot/pg3/ns/00:0d:b9:53:3f:34_9/node_modules/sonos-discovery/lib/NotificationListener.js:117:17
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
2022-05-18 02:06:53 error: POLY: uncaughtException: Cannot read properties of undefined (reading 'baseUrl')
2022-05-18 02:06:53 error: NS: uncaughtException: Cannot read properties of undefined (reading 'baseUrl')
2022-05-18 02:06:53 error: NS: undefined
  • 4 months later...
I have run into this issue 4-5 times since node server installed not long ago. Any updates or fixes?  Thank you.
Here is my log:
2022-10-03 08:16:08 error: NS: uncaughtException REPORT THIS!: TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:525:35) at /var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 2022-10-03 08:16:08 error: POLY: uncaughtException: Cannot read properties of undefined (reading 'members') TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:525:35) at /var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 2022-10-03 08:16:08 error: NS: uncaughtException: Cannot read properties of undefined (reading 'members') TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:525:35) at /var/polyglot/pg3/ns/000db9593a98_5/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
Thank you for the suggestion @Michel Kohanim.  I have submitted it.  It has continued to happen every day.  Let's see if they have any ideas.  I am re-starting Polisy as suggested in different and unrelated node server thread.
Hey all.  This NS has become totally non functional for me.  As with some others, I was finding it in a failed state several times a week and having to manually restart.  However, now it's just not working at all.  It says 'connected' after restart but it is clear not connected in the admin console.
Bumping this.  There was already an "Issue" listed on github.  But as far as I can tell, this isn't being addressed.  What's the the proper channell to get support for a Node server that's broken?  It would be nice to get up and running again.
It's running okay for me, but it's possible that the developer isn't getting notified when there's activity in this forum.  The developer is @simplextech, and you might consider sending him a DM.
I have connected with Simplex Tech through direct message. I also created an issue in GitHub. They are asking for PG3 version which I’ll get when I get home. But overall they have not found anything specific leading to this failed state. In a sense I wish could send a restart message everyday to the node server. Thank you.
Sorry but life and work has been very busy.  I only get notified via e-mail from direct messages so I do not see everything in the forum all of the time.
      38.2k
      380.7k
