ISY offline in Google Home
Been using Google Home with ISY since it became available.  A few minor issues in the beginning, but stable for at least 4 years.
Today I had to replace an Insteon Switch that had failed.  No replacements available so I took a switch that was largely unused out of a 3 way light circuit and used it.  The switch that failed had a spoken in google home.  I deleted it and replaced it with a new spoken for this replacement switch.  When I uploaded to Google home it told me the old switch was deleted and I added this one when it appeared with no room association.
Now nothing works.  Google home says "Offline" to all my ISY devices.  Have tried rebooting the ISY, re-uploading the spokens and deleting this replacement switch in the spokens. No dice.
Help!  Please.
Paul
Help!  Please.
Paul
Well it turns out my changes to the switch were coincidental to another issue. Turns out my cottage, in Canada, is part of a nation wide internet outage on Rogers. This home also uses Google home and an ISY.  It was the first installation and @Michel Kohanimsuggested I try changing my preferred ISY to current location from it.  It worked! Nothing to do with the insteon device change.
Thanks @Michel Kohanim!
Yup cloud dependence is awesome and easy...
...until it isn't.
Roger's seems to be back up again.
