Blink Camera Control
Uploaded a beta version of a Amazon Blink camera control node server
Primary function is to control arming and disarming of cameras, but it also allows taking pictures and videos
Might be a few bugs left - still ironing them out
I added the Node server but I only see Blink Setup, no nodes underneath it. Do I need to provide AUTH_KEY, and if so, where do I find it? Are SYNC_UNITS the individual cameras or the Sync Module, and it looks like specifying that is optional?
It should report if the auth key is missing - I think it is only needed first time you log in with the credentials   I remember adding it once (get it from the app) - but I have never seen it again so I really do not remember what I did - sorry
SYNC_UNIT is the sync unit (module name) - the cameras registered on that unit will show as sub-nodes - it is a separate node in ISY - not under the controller .
You can specify NONE for the sync_unit - it will list all the cameras you have under a syncunit namesd NONE  - it is not optional - I either need a list of sync_unit names or NONE
Send a log file and I can see what is happening
Edited by Panda88
I have 2FA enabled, but the only effect of that is that it is required to make changes within the app. I tried requesting a code from within the app and then entering that for AUTH KEY without success.
