Error starting August Node server (No such file: token.txt)
I'm getting the same error:
Quote
2022-11-09 12:51:54,330 Thread-1 udi_interface ERROR august_poly:parameterHandler: Error starting August Node server: [Errno 2] No such file or directory: '/var/polyglot/node servers/AugustLock/token.txt'
any suggestions?
  • 2 months later...
Hi @automationgeek,  I just migrated the August NS from PG3 on polisy to PG3x on eisy.  I now see this same error as reported above by @someguy.  When I check /var/polyglot/node servers/AugustLock/token.txt, from ssh, the path does not exist.
Should I create the path and file manually or has it moved to a new location in PG3x?.
Thank you.
The path for the token.txt file is something you configure in the node server.  There's a configuration parameter with the key "tokenFilePath" used to define that.  "/var/polyglot/node_servers/AugustLock" looks like it might have worked for PG2 but it won't work for PG3 or PG3x.
For PG3(x), the node server is installed in /var/polyglot/pg3/ns/<uuid>_<slot> so it depends on the IoX UUID and the slot number where the node server is installed.
If you look at the ISY or IoX configuration, you can get the UUID.  For example: 00:21:b9:02:61:ab  and if you installed the node server in slot 3, the path would look like: /var/polyglot/pg3/ns/0021b90261ab_3
Thanks @bpwwer, I changed the path to the location of my NS, /var/polyglot/pg3/ns/0021b9026044_10/token.txt but it still creating errors on restart, different errors this time.  I wonder if its a permission issue on that folder, when I used ssh to look for the token.txt file I got permission denied.  Log attached.
Update: I deleted the NS and reinstalled and this time it started up with no issue,  thanks Bob
August_1-11-2023_11412-PM.zip
Edited by tmorse305
Did you include token.txt on the path?
if so, then don't...
Yes I included it.  per the NS configuration instructions:
tokenFilePath - Path and Filename were the tokenFile should be generated ( /var/polyglot/node servers/AugustLock/token.txt ) The directory must exist and the user running polyglot must have read/write access.
All is well once I deleted the NS it and reinstalled  it.
I should have included the disclaimer that I was just comparing text in messages on the forum and don't actually have the node server.🙃  glad you got it working tho...
