Option Request for ELK
Blackbird
Go to solution Solved by DennisC,
When customizing the ELK, I was wondering if you can add the status options of armed states and disarmed.  That way the  icon can be set to be green if disarmed and red if armed.  At a glance to see if the system is armed or disarmed.  Instead of just having active alarms as an option.
You can do this now in UD Mobile. From your favorites screen select the pencil in upper right corner, click ok on message, select the icon, then select configure colors/ values/icons.
Then select add and write the rule you would like to use. I have if area 1 armed status = disarmed set color to hec color code for green. The second rule sets color to red if armed.
Check the UD Mobile user guide for more details.
Can you send me a screen shot because I dont see the option for disarmed or armed status just the list I showed in my screenshots
Need to see how you have the favorite setup. Click on the pencil, ok, select your Elk icon, edit, and type should be default, icon can be any you would like, display status should be armed status.
This will give you armed or disarmed status. Is that what you are looking for?
I'm home now so I can add a few screenshots.
      378.5k
