How to read Node Server Values
I posted a specific question in the Vue forum but have just a general question on node values.
Im able to write condition statements that test the value in of a node in a program and then act upon that value.  For the life of me Im unable to figure out how to use that value in a pushover message or to have it update a variable. My specific case is that I can see the value in polyglot and have tried the following but it just returns a blank value.
${sys.node.n001.141766_11.CPW}
Pushover response is: node[n001]
Thoughts?
Solved by bpwwer
It appears you added n001. when you shouldn't have.  Try just ${sys.node.141766_11.CPW}
I think the node server author should have included n001_ in the node name but didn't, meaning two different node servers could possibly generate this same node name.
I think you almost had it right.  Try ${sys.node.n001_141766_11.CPW}
The address created by the node server has the "n<slot>_" pre-pended to it when added to the ISY
