Adding Hue to Harmony Hub
I'm trying to configure the HueEmulator. I've installed the node server, set the configuration information in the NS settings and I can see the NS in the ISY admin console. Note, I have also tried the actual IP address instead of "localhost" in the NS settings with no change in outcome.
When I try and add the Hue Hub to the Harmony Hub, it asks me to press the center button on the Hue Hub. I have tried to set "Listen" from False to True to simulate the center button push but it won't recognize. Any troubleshooting suggestions?
Edited by endobiker
Solved by Jimbo.Automates
Jimbo,
I am seeing an error in the NS log (below):
 hueUpnp  ERROR  hueUpnp:run: hueUpnp: Responder Socket Error: [Errno 48] Address already in use
