Unable to Upgrade Packages
I have initiated the upgrade packages, AC shuts down, Polisy left light remains on, Isy still controlling everything.
Pulled power after about 15 min, Polisy boots up, one beep, left light on and all devices controllable yet still on 5.4.5.
Thoughts on how to upgrade?
Solved by Geddy
The "pkg" updater that should have been included to update at the beginning of the script was forgotten. I guess they haven't fixed the script yet.
Run the updater and update pkg first then try your updater click option in admin console again
Thank you….of course I’m a neophyte and don’t know how to execute sudo or where to find the update package…
Do you know how to use SSH on a PC to connect with your polisy? Do you know your polisy's IP and port address?
Havent done it with ISY/Polisy but have used Putty previously.  I have both the ip and port for the Polisy.  When i open Putty and start session with 192.168.4.6 and 8080 i just have a green mark without any other characters....followed by 'remote side unexpectedly closed network connection'
Next step?
Edited by pjjameso
dont use 8080 for SSH   use the default (think its 23)
SSH is port 22, 23 is Telnet
Sent from my Pixel 6 Pro using Tapatalk
