Trying to install Flume Node Server
Hey, just got my eISY and experimenting while waiting for the zmatter bridge.
I'm trying to install the Node Server for flume, but I get an error, Node Server install of Undefined failed with message status is not defined
from the log:
12/29/2022, 09:58:33 [pg3] info: [00:21:b9:02:61:12_3] Set nsdata
12/29/2022, 09:58:33 [pg3] info: [00:21:b9:02:61:12_3] Set oauth
12/29/2022, 09:58:34 [pg3] info: checkLicense:: Updaing FlumeWater subscription expiration to 2023-01-29T16:16:17.000Z
12/29/2022, 09:58:34 [pg3] error: createNS: ReferenceError: status is not defined
    at checkLicense (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:710:95)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async Object.createNs (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/node servers.js:433:5)
also from the log several times:
12/29/2022, 09:59:15 [pg3] warn: [00:21:b9:02:61:12_3] ISY does not have this Node Server. Removing from PG3.
any thoughts on where I could look to figure out further what's going on?
Solved by Jimbo.Automates
FWIW - I'm seeing the very same error when I attempt to install a trial version of the ST-Sonos node server.  Following to see if someone comes up with a fix.
10-4 depending on weather it looks like my bridge should be here soon, I'll try to fire the eISY back up and see about updating that... thought I had updated anything i could find on it...
Woot! I got the update done and it seems all of the modules are working.
Now I just need to figure out how to change the IP address, and find a USB to serial adapter to attempt the migration...
Yeah I just read that whole post... yikes... just got it back up and running after getting it reserved on my homelab DHCP server. the USB adapter is on order, but I have several that are usually tied into other projects, borrowing one to attempt it in the meantime.
