Migrating isy to eisy with PLM serial.
Hello,
I just got my hands in the new eisy, I stuck, wondering how I go about migrating my existing (and working) serial PLM from isy to the eisy.
I got the USB to serial adapter and the serial to RJ45 adapter, my next step (I think) is connect the serial PLM to the eisy but I am concerned I might lose all the information in it before I am ready to actually perform the migration.
Any suggestion?
I'm guessing you are running a 994?  Make sure you make a current backup, that's how you're going to migrate to eisy, right?  You can always restore the PLM on the 994 if eisy fails and you have to move back to the 994.
Hello,
Yes isy994i.
Correct, the idea is to Backup ISY (994) and then Restore ISY in the eisy...
I guess I can't be sure if the serial PLM setup will work in the eisy until the moment I actually go thought the migration, correct?
I had to reset my PLM before I could add devices to it in the eisy but I didn't do a migration.  I'd try it just plugging it in, you could always factory reset then restore the PLM from the backup you put in the eisy, and worst case you could always roll back to the 994 and restore the PLM from there...
