EISY rebooting every 5+ minutes
I have had nothing but challenges trying to get all my zwave devices to be recognized.  Just so happened that I was seeing if the UD Mobile app would control a few of the devices that were recognized.  While trying to turn a couple of items on and off, UDM reported that the eisy was unreachable.  Went to the portal and yes, it was offline.
I have this in the same port as the previous ISY.  Then exchanged cables and moved ports on my router, and it is still happening.  Also noticed that the time and date stamps on the portal event and error logs are NaN.
Device           Control   Value     Time                 User
0                null                NaN/NaN/NaN NaN:NaN:NaN  System    1
ZY027_1          ST        100%      NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY009_1          ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY011_1          ST        0%        NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY010_1          ST        0%        NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY015_1          ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY016_1          ST        69%       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY020_1          ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY056_1          ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY020_001_1      ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY041_183        ST        0         NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY020_002_1      ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY010_183        ST        0         NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY041_1          ST        Off       NaN/NaN/NaN NaN:NaN:NaN  System    5
ZY043_183        ST        0         NaN/NaN/NaN NaN:NaN:NaN  System    5
Desktop app keeps disconnecting as determined by the graying of the icons and only the exit available on the file menu item.
So, wondering if anyone else has an issue like this?
Yes.
Rebooted from the desktop app. Checked for updates. And redownload the start applet.
What gets me is that the portal shows that it is down.
Has the Portal ever shown it connected?
Have you successfully gone through the steps of adding trial license and approval?
Yep. I have the portal transfered over to the new device. And yes it does show connected and then disconnected when I check it after the UD mobile mentions it or the AC is grayed out.
Edited by Mecheng70
Without the time/date stamp, can't figure out the duration, but here is the error log
NaN/NaN/NaN NaN:NaN:NaN  System    -5	Start
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/TMP
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/LOG
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/WEB
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CODE
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/D2D
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/MAIL
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/USER
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/USER/WEB
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/NET
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/SEP
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/OADR
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/BILLING
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/DEF
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/GLOBAL
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/GLOBAL/i1
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/GLOBAL/i1/nls
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/GLOBAL/i1/editor
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/GLOBAL/i1/nodedef
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1/i1
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1/i1/nls
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1/i1/editor
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1/i1/nodedef
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/DEF/f1/i1/emap
NaN/NaN/NaN NaN:NaN:NaN  System    -110026	./FILES/CONF/DEF/f10
NaN/NaN/NaN NaN:NaN:NaN  System    -110022	./FILES/CONF/UZWBK501.BIN
NaN/NaN/NaN NaN:NaN:NaN  System    -110012	./FILES/CONF/UZWBK501.BIN
NaN/NaN/NaN NaN:NaN:NaN  System    -110022	./FILES/CONF/INSTENG.OPT
NaN/NaN/NaN NaN:NaN:NaN  System    -110012	./FILES/CONF/INSTENG.OPT
NaN/NaN/NaN NaN:NaN:NaN  System    -7115	ID 0002 :err=0, tag='cmd', num=4, nest=4, offse
NaN/NaN/NaN NaN:NaN:NaN  System    -7058	ID 0000 :err=0, tag='cmd', num=4, nest=4, offse
NaN/NaN/NaN NaN:NaN:NaN  System    -7115	ID 0050 :err=0, tag='cmd', num=4, nest=4, offse
NaN/NaN/NaN NaN:NaN:NaN  System    -170001	<s:Envelope><s:Body><u:Subscribe xmlns:u="urn:udi-com:service:X_Insteon_Lighting_Service:1"><reportURL>https://sub.isy.io:443/0021b9026225</reportURL><duration>infinite</duration></u:Subscribe></s:Body></s:Envelope>
It keeps START and then ID XXXX and fails.
Have factory reset the zwave dongle, checked for OS updates, reinstalled from a backup.  And this keeps happening.  I am almost to the point of giving up.
1 hour ago, Javi said:
Try resetting networking by pressing the power button 4 times.
Nope.  that didn't work.  Here is what the AC does every time (see image).  The icons all gray out.  That is how I know that it has decided to not work.  Very frustrating!
There is factory reset, but will wipe everything, press 10 times.
I've also seen a few systems that were power cycled during update causing issues.  You could try update by pressing once and waiting 30 minutes. The system may be partially available during this time, but that doesn't indicate update has completed.  If system is not available after 30 minutes press 5 times to reboot.
Aside from those things I suggest opening a ticket so someone with better firmware knowledge can troubleshoot.
So far it is not rebooted (did the 4 button press network reset).  I have been able to get most of my GE/Jasco zwave switches and Aeotec bulbs to be recognized.
Remaining issues are Inovelli and battery devices (expect Kwikset locks).
Thanks.
