How to interact with Harmony Hub?
Is there any documentation explaining how to interact with Harmony Hub on say Eisy through PG3? I'm seeing all my hubs etc and all looks configured correctly however how do I now actually use it? e.g. If a specific activity is run on a specific hub (which would be a condition), I want to run a program to dim the lights. Same in reverse, when I press the off button on the Harmony remote, I want lights to come back up. I can't intuitively see how this can be done.
Solved by gldixon
You would write a program. Choose the hub and activity that you want.
Like this:
FR-AVR-TV - [ID 0084][Parent 00B3]
        'Family Room / SHIELD TV Pro' is switched Start
     Or 'Family Room / FireTV 4K Max' is switched Start
     Or 'Family Room / Watch a Movie' is switched Start
        Wait  45 seconds
        Resource 'AVR-FR-Setup-TV'
On 1/15/2023 at 10:28 AM, JTsao said:
Like this:
        Wait  45 seconds
Thanks @JTsao that makes complete sense however I don't seem to see any of those options? For the Conditions I can select Status or Control.
For Status I only see the Harmony Hub Controller and it seems to be more testing for status such as number of hubs, if Node Server is connected etc.
For Control, I can see all the Harmony Hubs but all I can test for is 'On' or 'Power off'.
Is there something wrong with my setup?
Your drop downs don't give you other options such as choosing your activities?
maybe they  never followed the instructions and created Activities, those are user created.
In the program example that I provided, for example, "Watch a Movie" is an activity, not the hub.  Your examples above indicated what you can do with the hub itself, which is limited.  Hubs have the arrow pointing right.  Activities have an arrow pointing left.  You need to make sure you can see your activities in IoX, then you can trigger on when they start or end.
The hub below is called "Family Room" - devices and activities are child nodes, activities have the arrow pointing left.  Devices, and the hub itself point right.
49 minutes ago, carealtor said:
Can't help but wonder if there might be some better icons to use other than arrows.
@Jimbo.Automates
The icon selection for that usage truly s*cks.  When I worked on getting Pentair functional I learned the choices are pretty limited.  To change isn’t up to node server developers, they reside in firmware.
  • 1 month later...
Yeah I don't have anything below 'Family Room' and certainly I have activities defined on the Harmonies, after all, how do I use them as remotes if I didn't!
Thanks all for taking the times for these invaluable replies (sorry for the delay getting back to you). I think there must be something wrong with my node setup. I'll try removing and reconnecting etc.
