Brand new eisy - cannot log in to PG3
I decided to start this controller with a clean slate.  I didn't restore any backups, or migrate anything.  Its all just fresh and clean.
So anyway, I got a few Insteon devices connected, then a few Zwave devices connected.  Everything was going just fine.
But when I tried to log into PG3, I couldn't.
I got to the login screen, typed my username and password, clicked login and nothing happened.
So, I tried the default user/pass.  That didn't work either.
So, I rebooted the eisy.  That didn't work.
I upgraded packages in the admin console (cause, why not?) That didn't do anything either.
I tried on several different devices - still nothing.
I caught these logs in the console that look suspect to a non-developer like me.  Does that give any clues that I should have caught onto?
The response indicates that something went really wrong trying to authenticate.    I've not been able to reproduce this specific case so I don't know what went wrong.
The PG3x log may have more information as it should be logging an error message.  However, the only way to check that is to ssh to the eisy and watch the log while attempting to log in.   The command line to watch the log would be:
tail -f /var/polyglot/pg3/logs/pg3-current.log
(may or may not need to prefix that with sudo).  To stop displaying the log, use CTRL-C.
Thanks for the quick response.
After getting it up in Putty, I tried to log in once at 12:58:52 then just sat and let the log collect.
Here it is:
[admin@eisy ~]$ tail -f /var/polyglot/pg3/logs/pg3-current.log
1/16/2023, 12:54:34 [pg3] error: No code in error response
1/16/2023, 12:54:34 [pg3] warn: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [4        01 - OK] :: 0.844769ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 12:54:34 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02        :61:30] :: [401 - OK] :: 0.691158ms - http://127.0.0.1:8080/rest/profiles/ns/0/c        onnection
1/16/2023, 12:54:34 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/        ns/0/connection Failed :: 401 - OK
1/16/2023, 12:54:34 [pg3] error: getExistingNodeServers :: Error: Received no re        sponse from the ISY. Check your ISY IP Address
    at Object.getExistingNodeServers (/var/polyglot/node_modules/@universaldevic        es/pg3x/lib/modules/isy/system.js:93:13)
    at async /var/polyglot/node_modules/@universaldevices/pg3x/lib/services/isy.        js:80:21
    at async Promise.allSettled (index 0)
1/16/2023, 12:54:34 [pg3] warn: verifyNodeServers (00:21:b9:02:61:30) :: ISY has        no node servers installed, skipping
1/16/2023, 12:58:52 [pg3] info: Making reqeust to socket for /rest/pg3.auth.ns
1/16/2023, 12:59:07 [pg3] info: Starting PG3 version 3.1.18
1/16/2023, 12:59:07 [pg3] info: Using Workdir /var/polyglot/pg3/
1/16/2023, 12:59:07 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
1/16/2023, 12:59:07 [pg3] info: Encryption key found ID: c988d8b4-31c6-44d6-9416-48a969d717ee. Database version 1
1/16/2023, 12:59:07 [pg3] info: Query IoX for platform  UUID.
1/16/2023, 12:59:07 [pg3] info: Loaded globalsettings successfully. Database version 1
1/16/2023, 12:59:07 [pg3] info: isy table: Loaded (1) successfully
1/16/2023, 12:59:07 [pg3] info: ISY: 00:21:b9:02:61:30 5.5.3 127.0.0.1 2b43b97d-a0ed-4235-b40a-a6488def4e87
1/16/2023, 12:59:07 [pg3] info: No node servers in database. Add one through the user interface to get started
1/16/2023, 12:59:07 [pg3] info: store is up-to-date
1/16/2023, 12:59:07 [pg3] info: Forcing custom certificates to off
1/16/2023, 12:59:07 [pg3] info: Updated configuration with overrides
1/16/2023, 12:59:07 [pg3] info: Reading certs from filesystem (UDX).
1/16/2023, 12:59:07 [pg3] info: UDX Services Starting
1/16/2023, 12:59:07 [pg3] info: Starting update check
1/16/2023, 12:59:07 [pg3] info: Started MQTT Client Service
1/16/2023, 12:59:07 [pg3] info: Creating ISY queues for 00:21:b9:02:61:30
1/16/2023, 12:59:07 [pg3] info: HTTP Queue response "Queue Created Successfully,"
1/16/2023, 12:59:07 [pg3] info: Starting event listeners
1/16/2023, 12:59:07 [pg3] info: Starting Store Poll Refresh timer
1/16/2023, 12:59:07 [pg3] info: Starting ISY verification.
1/16/2023, 12:59:07 [pg3] info: Query ISY description at http://127.0.0.1:8080/desc
1/16/2023, 12:59:07 [pg3] info: Query store database https://pg3store.isy.io/v2/list
1/16/2023, 12:59:07 [pg3] info: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
1/16/2023, 12:59:07 [pg3] info: Checking ISY's for installed node servers...
1/16/2023, 12:59:07 [pg3] error: No code in error response
1/16/2023, 12:59:07 [pg3] warn: ISY Response: [Try: 1] [00:21:b9:02:61:30] :: [401 - OK] :: 3.229393ms - http://127.0.0.1:8080/rest/        profiles/ns/0/connection
1/16/2023, 12:59:07 [pg3] warn: ISY Response: [Try: 2] [00:21:b9:02:61:30] :: [401 - OK] :: 1.480229ms - http://127.0.0.1:8080/rest/        profiles/ns/0/connection
1/16/2023, 12:59:07 [pg3] warn: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.183003ms - http://127.0.0.1:8080/rest/        profiles/ns/0/connection
1/16/2023, 12:59:07 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 1.307062ms - http://127.0.0        .1:8080/rest/profiles/ns/0/connection
1/16/2023, 12:59:07 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK
1/16/2023, 12:59:07 [pg3] error: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address
    at Object.getExistingNodeServers (/var/polyglot/node_modules/@universaldevices/pg3x/lib/modules/isy/system.js:93:13)
    at async /var/polyglot/node_modules/@universaldevices/pg3x/lib/services/isy.js:80:21
    at async Object.start (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/isy.js:26:5)
    at async start (/var/polyglot/node_modules/@universaldevices/pg3x/bin/pg3.js:112:5)
1/16/2023, 12:59:07 [pg3] warn: verifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipping
1/16/2023, 12:59:07 [pg3] info: Reinstall Services Starting
1/16/2023, 12:59:07 [pg3] info: Waiting for store (false) and isy (false) before starting node servers.
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/status/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/command/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/system/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/custom/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/isy/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/system/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/ns/# QoS 0
1/16/2023, 12:59:07 [pg3] info: MQTTC: Subscribed to udi/pg3/connections/ns/# QoS 0
1/16/2023, 12:59:08 [pg3] info: Making reqeust to socket for /rest/pg3.auth.ns
1/16/2023, 12:59:24 [pg3] info: Starting PG3 version 3.1.18
1/16/2023, 12:59:24 [pg3] info: Using Workdir /var/polyglot/pg3/
1/16/2023, 12:59:24 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
1/16/2023, 12:59:24 [pg3] info: Encryption key found ID: c988d8b4-31c6-44d6-9416-48a969d717ee. Database version 1
1/16/2023, 12:59:24 [pg3] info: Query IoX for platform  UUID.
1/16/2023, 12:59:24 [pg3] info: Loaded globalsettings successfully. Database version 1
1/16/2023, 12:59:24 [pg3] info: isy table: Loaded (1) successfully
1/16/2023, 12:59:24 [pg3] info: ISY: 00:21:b9:02:61:30 5.5.3 127.0.0.1 2b43b97d-a0ed-4235-b40a-a6488def4e87
1/16/2023, 12:59:24 [pg3] info: No node servers in database. Add one through the user interface to get started
1/16/2023, 12:59:24 [pg3] info: store is up-to-date
1/16/2023, 12:59:24 [pg3] info: Forcing custom certificates to off
1/16/2023, 12:59:24 [pg3] info: Updated configuration with overrides
1/16/2023, 12:59:24 [pg3] info: Reading certs from filesystem (UDX).
1/16/2023, 12:59:24 [pg3] info: UDX Services Starting
1/16/2023, 12:59:24 [pg3] info: Starting update check
1/16/2023, 12:59:24 [pg3] info: Started MQTT Client Service
1/16/2023, 12:59:24 [pg3] info: Creating ISY queues for 00:21:b9:02:61:30
1/16/2023, 12:59:24 [pg3] info: HTTP Queue response "Queue Created Successfully,"
1/16/2023, 12:59:24 [pg3] info: Starting event listeners
1/16/2023, 12:59:24 [pg3] info: Starting Store Poll Refresh timer
1/16/2023, 12:59:24 [pg3] info: Starting ISY verification.
1/16/2023, 12:59:24 [pg3] info: Query ISY description at http://127.0.0.1:8080/desc
1/16/2023, 12:59:24 [pg3] info: Query store database https://pg3store.isy.io/v2/list
1/16/2023, 12:59:24 [pg3] info: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
1/16/2023, 12:59:24 [pg3] info: Checking ISY's for installed node servers...
1/16/2023, 12:59:24 [pg3] error: No code in error response
1/16/2023, 12:59:24 [pg3] warn: ISY Response: [Try: 1] [00:21:b9:02:61:30] :: [401 - OK] :: 3.456504ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 12:59:24 [pg3] warn: ISY Response: [Try: 2] [00:21:b9:02:61:30] :: [401 - OK] :: 1.517649ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 12:59:24 [pg3] warn: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.232004ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 12:59:24 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 1.329812ms - http://127.0.0.1:8080/rest/profiles/ns/0/conne                                                            ction
1/16/2023, 12:59:24 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK
1/16/2023, 12:59:24 [pg3] error: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address
1/16/2023, 12:59:24 [pg3] warn: verifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipping
1/16/2023, 12:59:24 [pg3] info: Reinstall Services Starting
1/16/2023, 12:59:24 [pg3] info: Waiting for store (false) and isy (false) before starting node servers.
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/status/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/command/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/system/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/ns/custom/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/isy/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/system/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/frontend/ns/# QoS 0
1/16/2023, 12:59:24 [pg3] info: MQTTC: Subscribed to udi/pg3/connections/ns/# QoS 0
1/16/2023, 12:59:24 [pg3] info: *****************************************
1/16/2023, 12:59:24 [pg3] info: Latest PG3x version available is 3.1.18
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Airscape
1/16/2023, 12:59:24 [pg3] info: Checking for changes in HusqvarnaMower
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Timedata
1/16/2023, 12:59:24 [pg3] info: Checking for changes in YoLink
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Sun
1/16/2023, 12:59:24 [pg3] info: Checking for changes in PurpleAir
1/16/2023, 12:59:24 [pg3] info: Checking for changes in UnifiProtect
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WLED
1/16/2023, 12:59:24 [pg3] info: Checking for changes in AERISWeather
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Flair
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Airthings-C
1/16/2023, 12:59:24 [pg3] info: Checking for changes in August
1/16/2023, 12:59:24 [pg3] info: Checking for changes in HarmonyHub
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Roku
1/16/2023, 12:59:24 [pg3] info: Checking for changes in MiLight
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Sensibo
1/16/2023, 12:59:24 [pg3] info: Checking for changes in AVRemote
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WeatherBit
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Virtual
1/16/2023, 12:59:24 [pg3] info: Checking for changes in NanoLeaf
1/16/2023, 12:59:24 [pg3] info: Checking for changes in NOAA
1/16/2023, 12:59:24 [pg3] info: Checking for changes in OnkyoAVR
1/16/2023, 12:59:24 [pg3] info: Checking for changes in LiFX
1/16/2023, 12:59:24 [pg3] info: Checking for changes in VirtualButtons
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ST-Inventory
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ATest
1/16/2023, 12:59:24 [pg3] info: Checking for changes in AMINEM
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Roomba
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WeatherLink
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Russound
1/16/2023, 12:59:24 [pg3] info: Checking for changes in TeslaPW
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Rachio
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ST-Nuheat
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Hue
1/16/2023, 12:59:24 [pg3] info: Checking for changes in UnifiPresence
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Holidays
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Sonos
1/16/2023, 12:59:24 [pg3] info: Checking for changes in iAquaLink
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Climacell
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ST-Sonos
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Notification
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WirelessTag
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Volumio
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WeatherPoly
1/16/2023, 12:59:24 [pg3] info: Checking for changes in EnvisaLink-HW
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Bond
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BalboaSPA
1/16/2023, 12:59:24 [pg3] info: Checking for changes in HolidaysGoogle
1/16/2023, 12:59:24 [pg3] info: Checking for changes in OpenSprinkler
1/16/2023, 12:59:24 [pg3] info: Checking for changes in DavisWeather
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Twinkly
1/16/2023, 12:59:24 [pg3] info: Checking for changes in IFTTT-Webhooks
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Wemo
1/16/2023, 12:59:24 [pg3] info: Checking for changes in WeatherFlow
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Ping
1/16/2023, 12:59:24 [pg3] info: Checking for changes in TeslaEV
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BASIRRIGATION
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Backup
1/16/2023, 12:59:24 [pg3] info: Checking for changes in DysonPureCool
1/16/2023, 12:59:24 [pg3] info: Checking for changes in AVServer
1/16/2023, 12:59:24 [pg3] info: Checking for changes in EnvisaLink-DSC
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Govee
1/16/2023, 12:59:24 [pg3] info: Checking for changes in OpenWeatherMap
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BlueIris
1/16/2023, 12:59:24 [pg3] info: Checking for changes in MagicHome
1/16/2023, 12:59:24 [pg3] info: Checking for changes in RainMachine
1/16/2023, 12:59:24 [pg3] info: Checking for changes in MQTT
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BASPOOL
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Acurite
1/16/2023, 12:59:24 [pg3] info: Checking for changes in MyQ
1/16/2023, 12:59:24 [pg3] info: Checking for changes in VenstarCT
1/16/2023, 12:59:24 [pg3] info: Checking for changes in iTach-IR
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Plex-WebHook
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BASGARAGE
1/16/2023, 12:59:24 [pg3] info: Checking for changes in FlumeWater
1/16/2023, 12:59:24 [pg3] info: Checking for changes in VUE
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Caseta
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ShellyRGBW2
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ST-EcoWitt
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Blink
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Kasa
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Kaiterra
1/16/2023, 12:59:24 [pg3] info: Checking for changes in ELK
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Sense
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Somfy
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Netatmo-WS
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Ecobee
1/16/2023, 12:59:24 [pg3] info: Checking for changes in BASAO
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Wake-On-Lan
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Push
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Camect
1/16/2023, 12:59:24 [pg3] info: Checking for changes in SolarEdge
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Meteobridge
1/16/2023, 12:59:24 [pg3] info: Checking for changes in TotalConnect
1/16/2023, 12:59:24 [pg3] info: Checking for changes in MySmartBlinds
1/16/2023, 12:59:24 [pg3] info: Checking for changes in HueEmulator
1/16/2023, 12:59:24 [pg3] info: Checking for changes in Eagle-200
1/16/2023, 12:59:24 [pg3] info: Checking for changes in AmbientWeather
1/16/2023, 12:59:24 [pg3] info: Checking for changes in HoneywellHome
1/16/2023, 12:59:25 [pg3] info: Query store database https://pg3betastore.isy.io/v1/list
1/16/2023, 12:59:25 [pg3] info: Checking for changes in DSC-IT100
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Roku
1/16/2023, 12:59:25 [pg3] info: Checking for changes in PythonTemplate
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Example-1
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Tuya-Devices
1/16/2023, 12:59:25 [pg3] info: Checking for changes in ATest
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Roomba
1/16/2023, 12:59:25 [pg3] info: Checking for changes in TestTeslaEV
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Example-2
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Notification
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Example-4
1/16/2023, 12:59:25 [pg3] info: Checking for changes in OpenSprinkler
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Example-3
1/16/2023, 12:59:25 [pg3] info: Checking for changes in eISYIR
1/16/2023, 12:59:25 [pg3] info: Checking for changes in DysonPureCool
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Sensibo-Air
1/16/2023, 12:59:25 [pg3] info: Checking for changes in VueTest
1/16/2023, 12:59:25 [pg3] info: Checking for changes in MagicHome
1/16/2023, 12:59:25 [pg3] info: Checking for changes in iTach-IR
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Kasa
1/16/2023, 12:59:25 [pg3] info: Checking for changes in ELK
1/16/2023, 12:59:25 [pg3] info: Checking for changes in Ecobee
1/16/2023, 13:04:24 [pg3] error: No code in error response
1/16/2023, 13:04:24 [pg3] warn: ISY Response: [Try: 1] [00:21:b9:02:61:30] :: [401 - OK] :: 3.032172ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:04:24 [pg3] warn: ISY Response: [Try: 2] [00:21:b9:02:61:30] :: [401 - OK] :: 1.284032ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:04:24 [pg3] warn: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.3138ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:04:24 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 1.227923ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:04:24 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK
1/16/2023, 13:04:24 [pg3] error: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address
1/16/2023, 13:04:24 [pg3] warn: verifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipping
1/16/2023, 13:09:24 [pg3] error: No code in error response
1/16/2023, 13:09:24 [pg3] warn: ISY Response: [Try: 1] [00:21:b9:02:61:30] :: [401 - OK] :: 1.48087ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:09:24 [pg3] warn: ISY Response: [Try: 2] [00:21:b9:02:61:30] :: [401 - OK] :: 1.43162ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:09:24 [pg3] warn: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.174782ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:09:24 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 1.217968ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
1/16/2023, 13:09:24 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK
1/16/2023, 13:09:24 [pg3] error: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address
1/16/2023, 13:09:24 [pg3] warn: verifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipping
Thanks!   That narrows it down a little but it didn't log enough to pin-point what went wrong.
I see it making the request to authenticate, but then PG3x restarts.  That does indicate that something crashed and it wasn't able to handle it.
If you can try again but instead monitor this log file:
sudo tail -f /var/log/messages
You don't need to let it continue monitoring after you attempt to log in.  It will log the crash info and then restart PG3x so the useful messages will be within 5-10 seconds of the login attempt.
FYI, the errors in the log you captured are normal at this point, It is trying to communicate with the IoX but you haven't yet logged in so it fails to authenticate and throws the errors.
Okay, here's what I got with that tail and trying to log in
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[31merror^[[39m:        No code in error response
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[33mwarn^[[39m: I        SY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.039307ms - http://1        27.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[31merror^[[39m:        ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 0.829009        ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[31merror^[[39m:        Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - O        K
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[31merror^[[39m:        getExistingNodeServers :: Error: Received no response from the ISY. Check your I        SY IP Address
Jan 16 14:37:25 eisy daemon[3009]:     at Object.getExistingNodeServers (/var/po        lyglot/node_modules/@universaldevices/pg3x/lib/modules/isy/system.js:93:13)
Jan 16 14:37:25 eisy daemon[3009]:     at async /var/polyglot/node_modules/@univ        ersaldevices/pg3x/lib/services/isy.js:80:21
Jan 16 14:37:25 eisy daemon[3009]:     at async Promise.allSettled (index 0)
Jan 16 14:37:25 eisy daemon[3009]: 1/16/2023, 14:37:25 [pg3] ^[[33mwarn^[[39m: v        erifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipp        ing
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: M        aking reqeust to socket for /rest/pg3.auth.ns
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[31merror^[[39m:        uncaughtException: connect ECONNREFUSED /tmp/udx2client261892
Jan 16 14:40:21 eisy kernel: sonewconn: pcb 0xfffff80008844100 (local:/tmp/udx2c        lient261892): Listen queue overflow: 76 already in queue awaiting acceptance (1        occurrences)
Jan 16 14:40:21 eisy daemon[3009]: Error: connect ECONNREFUSED /tmp/udx2client26        1892
Jan 16 14:40:21 eisy daemon[3009]:     at PipeConnectWrap.afterConnect [as oncom        plete] (node:net:1300:16)
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[31merror^[[39m:        uncaughtException REPORT THIS!: Error: connect ECONNREFUSED /tmp/udx2client26189        2
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: C        aught SIGTERM/SIGINT Shutting down.
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: S        topping running node servers...
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: S        tore Stopping Gracefully
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: R        emoving ISY queues for 00:21:b9:02:61:30
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: K        oa HTTP Service: Stopping
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: M        QTT Client Services Stopping Gracefully.
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: U        DX Services Stopping Gracefully
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: D        B Stopping Gracefully
Jan 16 14:40:21 eisy daemon[3009]: 1/16/2023, 14:40:21 [pg3] ^[[32minfo^[[39m: P        G3 shutdown complete with code: 0
Jan 16 14:40:36 eisy daemon[3009]: 1/16/2023, 14:40:36 [pg3] ^[[32minfo^[[39m: Starting PG3 version 3.1.18
Jan 16 14:40:36 eisy daemon[3009]: 1/16/2023, 14:40:36 [pg3] ^[[32minfo^[[39m: Using Workdir /var/polyglot/pg3/
Jan 16 14:40:36 eisy daemon[3009]: 1/16/2023, 14:40:36 [pg3] ^[[32minfo^[[39m: Starting sqlite database at /var/polyglot/pg3/pg3.db
Jan 16 14:40:36 eisy daemon[3009]: 1/16/2023, 14:40:36 [pg3] ^[[32minfo^[[39m: Encryption key found ID: c988d8b4-31c6-44d6-9416-48a969d717ee. Database version 1
Jan 16 14:40:36 eisy daemon[3009]: 1/16/2023, 14:40:36 [pg3] ^[[32minfo^[[39m: Query IoX for platform  UUID.
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Loaded globalsettings successfully. Database version 1
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: isy table: Loaded (1) successfully
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: ISY: 00:21:b9:02:61:30 5.5.3 127.0.0.1 2b43b97d-a0ed-4235-b40a-a6488def4e87
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: No node servers in database. Add one through the user interface to get started
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: store is up-to-date
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Forcing custom certificates to off
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Updated configuration with overrides
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Reading certs from filesystem (UDX).
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: UDX Services Starting
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Starting update check
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Started MQTT Client Service
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Creating ISY queues for 00:21:b9:02:61:30
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: HTTP Queue response "Queue Created Successfully,"
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Starting event listeners
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Starting Store Poll Refresh timer
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Starting ISY verification.
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Query ISY description at http://127.0.0.1:8080/desc
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Query store database https://pg3store.isy.io/v2/list
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking ISY's for installed node servers...
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[31merror^[[39m: No code in error response
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[33mwarn^[[39m: ISY Response: [Try: 1] [00:21:b9:02:61:30] :: [401 - OK] :: 3.133993ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[33mwarn^[[39m: ISY Response: [Try: 2] [00:21:b9:02:61:30] :: [401 - OK] :: 1.440466ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[33mwarn^[[39m: ISY Response: [Try: 3] [00:21:b9:02:61:30] :: [401 - OK] :: 1.216839ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[31merror^[[39m: ISY Response: [MAX TRIES EXCEEDED] [00:21:b9:02:61:30] :: [401 - OK] :: 1.281375ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[31merror^[[39m: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[31merror^[[39m: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address
Jan 16 14:40:37 eisy daemon[3009]:     at Object.getExistingNodeServers (/var/polyglot/node_modules/@universaldevices/pg3x/lib/modules/isy/system.js:93:13)
Jan 16 14:40:37 eisy daemon[3009]:     at async /var/polyglot/node_modules/@universaldevices/pg3x/lib/services/isy.js:80:21
Jan 16 14:40:37 eisy daemon[3009]:     at async Promise.allSettled (index 0)
Jan 16 14:40:37 eisy daemon[3009]:     at async Object.start (/var/polyglot/node_modules/@universaldevices/pg3x/lib/services/isy.js:26:5)
Jan 16 14:40:37 eisy daemon[3009]:     at async start (/var/polyglot/node_modules/@universaldevices/pg3x/bin/pg3.js:112:5)
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[33mwarn^[[39m: verifyNodeServers (00:21:b9:02:61:30) :: ISY has no node servers installed, skipping
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Reinstall Services Starting
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Waiting for store (false) and isy (false) before starting node servers.
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/ns/status/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/ns/command/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/ns/system/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/ns/custom/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/frontend/isy/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/frontend/system/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/frontend/ns/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: MQTTC: Subscribed to udi/pg3/connections/ns/# QoS 0
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Airscape
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in HusqvarnaMower
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Timedata
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in YoLink
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Sun
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in PurpleAir
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in UnifiProtect
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WLED
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in AERISWeather
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Flair
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Airthings-C
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in August
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in HarmonyHub
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Roku
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in MiLight
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Sensibo
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in AVRemote
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WeatherBit
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Virtual
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in NanoLeaf
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in NOAA
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in OnkyoAVR
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in LiFX
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in VirtualButtons
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ST-Inventory
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ATest
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in AMINEM
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Roomba
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WeatherLink
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Russound
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in TeslaPW
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Rachio
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ST-Nuheat
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Hue
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in UnifiPresence
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Holidays
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Sonos
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in iAquaLink
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Climacell
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ST-Sonos
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Notification
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WirelessTag
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Volumio
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WeatherPoly
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in EnvisaLink-HW
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Bond
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BalboaSPA
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in HolidaysGoogle
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in OpenSprinkler
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in DavisWeather
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Twinkly
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in IFTTT-Webhooks
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Wemo
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in WeatherFlow
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Ping
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in TeslaEV
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BASIRRIGATION
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Backup
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in DysonPureCool
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in AVServer
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in EnvisaLink-DSC
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Govee
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in OpenWeatherMap
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BlueIris
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in MagicHome
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in RainMachine
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in MQTT
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BASPOOL
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Acurite
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in MyQ
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in VenstarCT
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in iTach-IR
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Plex-WebHook
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BASGARAGE
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in FlumeWater
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in VUE
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Caseta
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ShellyRGBW2
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ST-EcoWitt
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Blink
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Kasa
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Kaiterra
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in ELK
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Sense
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Somfy
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Netatmo-WS
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Ecobee
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in BASAO
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Wake-On-Lan
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Push
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Camect
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in SolarEdge
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Meteobridge
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in TotalConnect
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in MySmartBlinds
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in HueEmulator
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in Eagle-200
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in AmbientWeather
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Checking for changes in HoneywellHome
Jan 16 14:40:37 eisy daemon[3009]: 1/16/2023, 14:40:37 [pg3] ^[[32minfo^[[39m: Query store database https://pg3betastore.isy.io/v1/list
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: *****************************************
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Latest PG3x version available is 3.1.19
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in DSC-IT100
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Roku
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in PythonTemplate
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Example-1
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Tuya-Devices
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in ATest
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Roomba
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in TestTeslaEV
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Example-2
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Notification
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Example-4
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in OpenSprinkler
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Example-3
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in eISYIR
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in DysonPureCool
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Sensibo-Air
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in VueTest
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in MagicHome
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in iTach-IR
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Kasa
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in ELK
Jan 16 14:40:38 eisy daemon[3009]: 1/16/2023, 14:40:38 [pg3] ^[[32minfo^[[39m: Checking for changes in Ecobee
1 hour ago, bpwwer said:
Thanks!  That's what I needed to see.
It looks like the service PG3x uses to authenticate is hung.  Have you tried rebooting the eisy?  If not, try that.
Yes, three or four times.
I just rebooted now and tried again - same problem.
15 hours ago, bpwwer said:
OK.  You'll have to submit a support ticket so someone can remote in and figure out what's wrong.
reference: "PG3x login failure (UDX socket)" in the ticket
I just had the same problem but power cycling the eisy solved it for me
I have this issue too.  EISY has been power cycled a few times, but this is still an issue.
I'm having the same issue, too.
Tried power cycle and soft reboot several times. Still no luck.
My new Etsy just updated from 5.4.5 to 5.5.4 and it solved the problem of logging onto PG3x.
