Schlage Locks not fully adding to Eisy
I just transitioned to Eisy(v5.5.3)with the USB: Z-Wave+ & Matter Module installed from  ISY994r PRO where i had all my Schlage Connect locks working. But now  I cannot get them to add fully to Eisy. I get 1 node called "entry control" and nothing else and no control. I also tried to get it to add to UD Mobile and it was the same. I have removed them factory reset and added again. I had one that i brought to Eisy to add, same results In the Mobile app I get an errorRestResponse succeeded false status 400. Anyone have an ideas, please?
Edited by n8ur9irl
Do you get DSK code prompt? Do you type in correct code? Or is this lock not S2. If you type incorrect code, it will silently fail. You can maybe look in Event log for messages.
yes i enter the dsk code and make sure it is correct, it has the S2 encryption
12 minutes ago, Geddy said:
@n8ur9irl see if you update to 5.5.4 (just released) and see if it works. Looks like one of the bug fixes is for adding Schlage locks.
That's good news! Because that is what I have for a lock on my main house and that was important to have when I issue a home lockdown verbally to Alexa. I was not aware of problems with that node server in eISY. I haven't gotten around to migrating that hardware over to eISY just yet but it was getting real close.
TRI0N
Spoke a little too soon. Updated to 5.5.4 and see no Schlage Lock Node. I also notice all the statues of my Kasa devices have gone blank and even if I query it not longer shows their information for ANYTHING. Ugh!
Maybe DO NOT UPDATE PACKAGES just yet?
TRI0N
I have 4 BE469ZP installed and added them multiple times with no issues. I cannot write user codes into 3 of them but that's a different story.
Not sure if you want to try but here's what you can:
ZWave -> Synchronize -> New and Deleted with Interview
I've had issues with Aeon sensors not having nodes created and the synchronize would bring them up after a few tries. I think in my case interview didn't work at first.
Thanks for the help. Ive opened up a ticket to check it
Hi folks,
Did anyone have any luck with this??  I've been trying to add my Schlage Connect Z-Wave locks to my brand new EISY with Z-Wave USB thingy.  This is basically my first time in a long time messing with setting things up again.  Luckily, I've got my old paperwork for the locks.
Things seem to keep "timing out" --
<Device 7> Waiting on interview complate (timeout in xx seconds)>
Eric
Here's what the logs show at the very end.  Note...I turned "off" Secure Connect....thinking I could revisit it later if needed.  Otherewise, same thing was happening when using "Secure".  And I DID Remove the lock before trying to add back in.
Elapsed 00:00:07.060 : Loading Variables
Elapsed 00:00:07.374 : Loading Node Definitions
Elapsed 00:00:07.724 : Loading Nodes
Elapsed 00:00:07.797 : Creating Widgets
Elapsed 00:00:09.001 : Creating Widgets Complete
Sun 01/29/2023 02:47:01 PM : Starting Subscription
Sun 01/29/2023 02:47:01 PM : Completing initialization
Sun 01/29/2023 02:47:01 PM : Refreshing Status
Sun 01/29/2023 02:47:01 PM : Refreshing Views
Sun 01/29/2023 02:49:00 PM : Z-Wave Listening for Z-Wave devices to remove from the network
Sun 01/29/2023 02:49:07 PM : Z-Wave Z-Wave device detected, start removing from network
Sun 01/29/2023 02:49:07 PM : Z-Wave Z-Wave device removed
Sun 01/29/2023 02:49:07 PM : Z-Wave Idle
Sun 01/29/2023 02:49:15 PM : ---- Start Adding Devices - S2 Standard ---
Sun 01/29/2023 02:49:15 PM : [ZWAVE-INCL-S2STD] Start Include non-secure
Sun 01/29/2023 02:49:15 PM : [ZWAVE-INCL-S2STD] Not using Secure Inclusion
Sun 01/29/2023 02:49:15 PM : Z-Wave Listening for Z-Wave devices to add to the network
Sun 01/29/2023 02:49:23 PM : Z-Wave Z-Wave device detected, start adding to network
Sun 01/29/2023 02:49:23 PM : Z-Wave Z-Wave device detected, retrieving info
Sun 01/29/2023 02:49:23 PM : [ZW-INTERVIEW-37 ] Add interview running entry for 7
Sun 01/29/2023 02:49:24 PM : Z-Wave Z-Wave device added
Sun 01/29/2023 02:49:24 PM : Z-Wave Idle
Sun 01/29/2023 02:49:28 PM : [Device 7] Waiting on interview complete (timeout in 816)
Sun 01/29/2023 02:49:30 PM : [Device 7] Waiting on interview complete (timeout in 776)
Sun 01/29/2023 02:49:32 PM : [Device 7] Waiting on interview complete (timeout in 735)
Sun 01/29/2023 02:49:34 PM : [Device 7] Waiting on interview complete (timeout in 695)
Sun 01/29/2023 02:49:36 PM : [Device 7] Waiting on interview complete (timeout in 655)
Sun 01/29/2023 02:49:38 PM : [Device 7] Waiting on interview complete (timeout in 615)
Sun 01/29/2023 02:49:40 PM : [Device 7] Waiting on interview complete (timeout in 575)
Sun 01/29/2023 02:49:42 PM : [Device 7] Waiting on interview complete (timeout in 535)
Sun 01/29/2023 02:49:44 PM : [Device 7] Waiting on interview complete (timeout in 493)
Sun 01/29/2023 02:49:46 PM : [Device 7] Waiting on interview complete (timeout in 453)
Sun 01/29/2023 02:49:48 PM : [Device 7] Waiting on interview complete (timeout in 412)
Sun 01/29/2023 02:49:50 PM : [Device 7] Waiting on interview complete (timeout in 372)
Sun 01/29/2023 02:49:52 PM : [Device 7] Waiting on interview complete (timeout in 329)
Sun 01/29/2023 02:49:54 PM : [Device 7] Waiting on interview complete (timeout in 289)
Sun 01/29/2023 02:49:56 PM : [Device 7] Waiting on interview complete (timeout in 248)
Sun 01/29/2023 02:49:58 PM : [Device 7] Waiting on interview complete (timeout in 861)
Sun 01/29/2023 02:50:00 PM : [Device 7] Waiting on interview complete (timeout in 821)
Sun 01/29/2023 02:50:02 PM : [Device 7] Waiting on interview complete (timeout in 779)
Sun 01/29/2023 02:50:04 PM : [Device 7] Waiting on interview complete (timeout in 739)
Sun 01/29/2023 02:50:06 PM : [Device 7] Waiting on interview complete (timeout in 698)
Sun 01/29/2023 02:50:08 PM : [Device 7] Waiting on interview complete (timeout in 658)
Sun 01/29/2023 02:50:10 PM : [Device 7] Waiting on interview complete (timeout in 617)
Sun 01/29/2023 02:50:12 PM : [Device 7] Waiting on interview complete (timeout in 576)
Sun 01/29/2023 02:50:14 PM : [Device 7] Waiting on interview complete (timeout in 536)
Sun 01/29/2023 02:50:16 PM : [Device 7] Waiting on interview complete (timeout in 495)
Sun 01/29/2023 02:50:18 PM : [Device 7] Waiting on interview complete (timeout in 455)
Sun 01/29/2023 02:50:20 PM : [Device 7] Waiting on interview complete (timeout in 415)
Sun 01/29/2023 02:50:22 PM : [Device 7] Waiting on interview complete (timeout in 374)
Sun 01/29/2023 02:50:24 PM : [Device 7] Waiting on interview complete (timeout in 334)
Sun 01/29/2023 02:50:26 PM : [Device 7] Waiting on interview complete (timeout in 294)
Sun 01/29/2023 02:50:28 PM : [Device 7] Waiting on interview complete (timeout in 253)
Sun 01/29/2023 02:50:30 PM : [Device 7] Waiting on interview complete (timeout in 213)
Sun 01/29/2023 02:50:32 PM : [Device 7] Waiting on interview complete (timeout in 173)
Sun 01/29/2023 02:50:34 PM : [Device 7] Waiting on interview complete (timeout in 133)
Sun 01/29/2023 02:50:36 PM : [Device 7] Waiting on interview complete (timeout in 92)
Sun 01/29/2023 02:50:38 PM : [Device 7] Waiting on interview complete (timeout in 52)
Sun 01/29/2023 02:50:40 PM : [Device 7] Waiting on interview complete (timeout in 12)
Sun 01/29/2023 02:50:42 PM : [Device 7] Waiting on interview complete (timeout in 0)
Sun 01/29/2023 02:50:42 PM : [ZW-INTERVIEW-37 ] Device   7 : Interview Done with some non-conforming features : total=6 successful=4 attempted=6
Sun 01/29/2023 02:50:42 PM : ZWAVE-WORKQ-34   Queue sync device 7
Sun 01/29/2023 02:50:42 PM : ZWAVE-WORKQ-34   Start sync device 7
Sun 01/29/2023 02:50:42 PM : [ZWAVE-SYNC   7] Rebuilding all existing ISY files/objects for Z-Wave device
Sun 01/29/2023 02:50:42 PM : [SYNC-DEVICE 7.0] Set commands will now be accepted by the controller
Sun 01/29/2023 02:50:42 PM : [ZWAVE-SYNC   7] Not multichannel
Sun 01/29/2023 02:50:42 PM : ZWAVE-WORKQ-34   Finished sync device 7
Sun 01/29/2023 02:50:58 PM : ZWAVE-WORKQ-36   Queue interview & sync new & deleted
Sun 01/29/2023 02:50:58 PM : ZWAVE-WORKQ-36   Start interview & sync new & deleted
Sun 01/29/2023 02:50:58 PM : ZWAVE-WORKQ-36   Finished interview & sync new & deleted
Sun 01/29/2023 02:51:14 PM : ZWAVE-WORKQ-36   Queue interview & sync new & deleted
Sun 01/29/2023 02:51:14 PM : ZWAVE-WORKQ-36   Start interview & sync new & deleted
Sun 01/29/2023 02:51:14 PM : ZWAVE-WORKQ-36   Finished interview & sync new & deleted
Sun 01/29/2023 02:51:32 PM : ZWAVE-WORKQ-34   Queue write device updates for node 7, force=true
Sun 01/29/2023 02:51:32 PM : ZWAVE-WORKQ-34   Start write device updates for node 7, force=true
Sun 01/29/2023 02:51:32 PM : ZWAVE-WORKQ-34   Finished write device updates for node 7, force=true
Sun 01/29/2023 02:52:09 PM : [ZW-INTERVIEW-37 ] Add interview request for 7
Sun 01/29/2023 02:52:09 PM : [ZW-INTERVIEW-37 ] Interview started for 7
Sun 01/29/2023 02:52:11 PM : [Device 7] Waiting on interview complete (timeout in 859)
Sun 01/29/2023 02:52:13 PM : [Device 7] Waiting on interview complete (timeout in 818)
Sun 01/29/2023 02:52:15 PM : [Device 7] Waiting on interview complete (timeout in 778)
Sun 01/29/2023 02:52:17 PM : [Device 7] Waiting on interview complete (timeout in 737)
Sun 01/29/2023 02:52:19 PM : [Device 7] Waiting on interview complete (timeout in 697)
Sun 01/29/2023 02:52:21 PM : [Device 7] Waiting on interview complete (timeout in 657)
Sun 01/29/2023 02:52:23 PM : [Device 7] Waiting on interview complete (timeout in 615)
Sun 01/29/2023 02:52:25 PM : [Device 7] Waiting on interview complete (timeout in 575)
Sun 01/29/2023 02:52:27 PM : [Device 7] Waiting on interview complete (timeout in 534)
Sun 01/29/2023 02:52:29 PM : [Device 7] Waiting on interview complete (timeout in 493)
Sun 01/29/2023 02:52:31 PM : [Device 7] Waiting on interview complete (timeout in 453)
Sun 01/29/2023 02:52:33 PM : [Device 7] Waiting on interview complete (timeout in 413)
Sun 01/29/2023 02:52:35 PM : [Device 7] Waiting on interview complete (timeout in 371)
Sun 01/29/2023 02:52:37 PM : [Device 7] Waiting on interview complete (timeout in 330)
Sun 01/29/2023 02:52:39 PM : [Device 7] Waiting on interview complete (timeout in 290)
Sun 01/29/2023 02:52:41 PM : [Device 7] Waiting on interview complete (timeout in 249)
Sun 01/29/2023 02:52:43 PM : [Device 7] Waiting on interview complete (timeout in 209)
Sun 01/29/2023 02:52:45 PM : [Device 7] Waiting on interview complete (timeout in 167)
Sun 01/29/2023 02:52:47 PM : [Device 7] Waiting on interview complete (timeout in 127)
Sun 01/29/2023 02:52:49 PM : [Device 7] Waiting on interview complete (timeout in 86)
Sun 01/29/2023 02:52:51 PM : [Device 7] Waiting on interview complete (timeout in 46)
Sun 01/29/2023 02:52:53 PM : [Device 7] Waiting on interview complete (timeout in 5)
Sun 01/29/2023 02:52:55 PM : [Device 7] Waiting on interview complete (timeout in 0)
Sun 01/29/2023 02:52:55 PM : [ZW-INTERVIEW-37 ] Device   7 : Interview Done with some non-conforming features : total=6 successful=4 attempted=6
Sun 01/29/2023 02:52:55 PM : ZWAVE-WORKQ-34   Queue sync device 7
Sun 01/29/2023 02:52:55 PM : ZWAVE-WORKQ-34   Start sync device 7
Sun 01/29/2023 02:52:55 PM : [ZWAVE-SYNC   7] Manufacturer Specific Data Not available, sync with ISY not performed
Sun 01/29/2023 02:52:55 PM : ZWAVE-WORKQ-34   Failed sync device 7
Sun 01/29/2023 02:54:20 PM : ZWAVE-WORKQ-34   Queue sync device 7
Sun 01/29/2023 02:54:20 PM : ZWAVE-WORKQ-34   Start sync device 7
Sun 01/29/2023 02:54:20 PM : [ZWAVE-SYNC   7] Manufacturer Specific Data Not available, sync with ISY not performed
Sun 01/29/2023 02:54:20 PM : ZWAVE-WORKQ-34   Failed sync device 7
Sun 01/29/2023 02:54:34 PM : [ZW-INTERVIEW-37 ] Add interview request for 7
Sun 01/29/2023 02:54:34 PM : [ZW-INTERVIEW-37 ] Interview started for 7
Sun 01/29/2023 02:54:36 PM : [Device 7] Waiting on interview complete (timeout in 858)
Sun 01/29/2023 02:54:38 PM : [Device 7] Waiting on interview complete (timeout in 818)
Sun 01/29/2023 02:54:40 PM : [Device 7] Waiting on interview complete (timeout in 775)
Sun 01/29/2023 02:54:42 PM : [Device 7] Waiting on interview complete (timeout in 733)
Sun 01/29/2023 02:54:44 PM : [Device 7] Waiting on interview complete (timeout in 693)
Sun 01/29/2023 02:54:46 PM : [Device 7] Waiting on interview complete (timeout in 651)
Sun 01/29/2023 02:54:48 PM : [Device 7] Waiting on interview complete (timeout in 611)
Sun 01/29/2023 02:54:50 PM : [Device 7] Waiting on interview complete (timeout in 571)
Sun 01/29/2023 02:54:52 PM : [Device 7] Waiting on interview complete (timeout in 530)
Sun 01/29/2023 02:54:54 PM : [Device 7] Waiting on interview complete (timeout in 489)
Sun 01/29/2023 02:54:56 PM : [Device 7] Waiting on interview complete (timeout in 449)
Sun 01/29/2023 02:54:59 PM : [Device 7] Waiting on interview complete (timeout in 408)
Sun 01/29/2023 02:55:01 PM : [Device 7] Waiting on interview complete (timeout in 368)
Sun 01/29/2023 02:55:03 PM : [Device 7] Waiting on interview complete (timeout in 327)
Sun 01/29/2023 02:55:05 PM : [Device 7] Waiting on interview complete (timeout in 286)
Sun 01/29/2023 02:55:07 PM : [Device 7] Waiting on interview complete (timeout in 245)
Sun 01/29/2023 02:55:09 PM : [Device 7] Waiting on interview complete (timeout in 205)
Sun 01/29/2023 02:55:11 PM : [Device 7] Waiting on interview complete (timeout in 164)
Sun 01/29/2023 02:55:13 PM : [Device 7] Waiting on interview complete (timeout in 124)
Sun 01/29/2023 02:55:15 PM : [Device 7] Waiting on interview complete (timeout in 83)
Sun 01/29/2023 02:55:17 PM : [Device 7] Waiting on interview complete (timeout in 43)
Sun 01/29/2023 02:55:19 PM : [Device 7] Waiting on interview complete (timeout in 3)
Sun 01/29/2023 02:55:21 PM : [Device 7] Waiting on interview complete (timeout in 0)
Sun 01/29/2023 02:55:21 PM : [ZW-INTERVIEW-37 ] Device   7 : Interview Done with some non-conforming features : total=6 successful=4 attempted=6
Sun 01/29/2023 02:55:21 PM : ZWAVE-WORKQ-34   Queue sync device 7
Sun 01/29/2023 02:55:21 PM : ZWAVE-WORKQ-34   Start sync device 7
Sun 01/29/2023 02:55:21 PM : [ZWAVE-SYNC   7] Manufacturer Specific Data Not available, sync with ISY not performed
Sun 01/29/2023 02:55:21 PM : ZWAVE-WORKQ-34   Failed sync device 7
I'm having the same problem with Polisy 5.5.5 with Z Matter board.  My Bladwin lock (Z-wave Plus 500 series) adds fine but my older Schlage (Z wave 300 series doesn't add.  Was thinking that the 700 series Z Matter cannot communicate with the series 300, but then before installing Z matter, I had a Zooz (700 series) on the Polisy and the Schlage added just fine.
Note that the Baldwin lock is a Kwikset 916 internally, not Schlage - even though they use a Schlage-compatible keyway.
Yes, but the schlage still added to the network under the Zooz stick, but not with Z matter.
I would suggest opening a support ticket with UD with the device information that you are having issues with. That way you are sure they know the device that is having issues and they can work on a fix.
I said that but that's related to lock updating status as well as ability to write user codes. I don't believe that it would affect lock not creating nodes. I don't have that issue. A couple of times enrolled devices wouldn't create nodes. I had to run z-wave -> synchronize and it was created after that usually.
