Old responder in scene
jkraus
Hi Michel
Have an unusual issue that I would like your suggestion on how to resolve.
For simplicity, I had a scene with KPL B as a controller to Responderes R1, R2, R3 and R4. I deleted that scene and created a new one and now have KPL B as a controller to a differet Responder R5. However, when activating KPL B, the old Responder R1 still responds also (along with the new R5 of course).
I tried to add R1 and then Delete if from the scene to get rid of it, no luck.
I tried a resore device on the KPL, no luck.
any suggestions?
Hi jkraus,
That's quite odd. Would you be kind enough to check the ISY table for R1 and see if there are any references to the KPL? If not, and if Compare is identical, then I must assume that the problem is R1. If possible, please do a factory reset on it and then a restore.
      38.2k
      381.2k
