Support thread for: PG3x 3.1.23 & 3.1.24
Ran upgrade packages for PG3x 3.1.22 -> 3.1.23.  Left alone for several minutes.
Couldn't log into PG3x, IoX showed Reboot required.  Rebooted from Admin Console.
AC showed reboot required after doing the reboot.
Rebooted again, AC still showed reboot required.
Front panel 5x and 6x presses didn't respond, so cycled eisy power.
IoX 5.5.9 and PG3x 3.1.23 now working OK.
  • 3 weeks later...
After a recent reboot of eisy the NS AVRemote updated to version 2.0.5. After that it no longer connects to the iox and can't be deleted for a fresh install. Gets the following message: "Failed to remove node server AVRemote from slot (13). Can not read properties of null (reading 'filename')".
No log is produced. Would like the procedure to delete the NS through SSH. Hopefully a fresh install will fix the issue.
there's a thread about AVRemote 2.0.5
Upgrade PG3x to 3.1.24 and you will be able to delete node servers again.  It was a bug in version 3.1.23.
There isn't any way to delete node servers via ssh.
  • Thanks 1
      380k
