Insteon devices not working
I've migrated to EISY from 994i and none of my Insteon device are working. They all show up in the portal as "RED". If you try to turn on a light etc. nothing happens.
If I go back to the 994i it works fine. Did I miss a step in the migration process?
Solved by tlightne
That will be hard for us to tell you without you listing the steps you used.
Did you follow the directions here:
https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#Migration
I think I understand what the problem was, but I haven’t been able to fix it.  I had the PLM still plugged into the 994i and the EISY plugged in to network. I now have the Wi-Fi setup on the EISY and the PLM plugged into the EISY Ethernet port. I can get into the portal from a desktop and the UD Mobile App, but the results are the same.
This is your current issue. The PLM must plug into a USB port. The PLM is not a network device. It might have the Network type cable connected to it, but it is a serial setup. (and @tlightne answered while I was typing)
You need this kit from UDI:  https://www.universal-devices.com/product/serial-plm-kit/
eisy only works with a USB PLM, or a serial PLM with a USB conversion wire. In either case, you can not plug the PLM in to an ethernet port on eisy. If you need a conversion cable, UD has them in the store.
Also, running eisy on wifi has been known to cause some difficulties with certain things.
Got it. I just ordered a serial to USB cable. Thanks for your help. I have a serial PLM that I wasn’t using.
