RCS Z-Wave Thermostat parameters
Hello,
I have a couple  RCS  TZ45R thermostats and am trying to dig a bit deep into the automation of it's parameters within IOP.  I have searched all over the web and even contacted the company to get the list of the z-wave parameters.  No luck, does anyone know where the parameters can found?  opensmarthouse.org has the device listed but no parameter info
21 minutes ago, dpierre said:
Hello,
Are you certain that this device has parameters? If there are none found online and the mfg. cant provide any, then there may not be any available
The company doesn't return my calls... Honestly, I'm not that well versed in the protocol.  I thought all z-wave devices had parameters that the technology uses to define processes or settings.  I have zooz device that lists it's parameters for temperature, light, reset time, L.E.D. colors, etc.  Is this not the case related to z-wave?
No it is not. Parameters are not guaranteed. Each mfg. can choose to use them or not use them at all.
  • 2 months later...
