Simple program question
I have installed a motion sensor outside our front door and an Insteon on/off switch for the lights on our porch. I have a simple program that turns the lights on when motion is detected and it's between sunset of current day and sunrise of next day.  The lights come on. Then I have a WAIT 5 Minutes statement followed by a command to turn the lights off BUT they never go off.  See attached.  What am I missing?
2 hours ago, Kentinada said:
What am I missing?
You're using "Status is On" in the IF.  I think you want to use "is switched On".  So use "Control" instead of "Status".  They don't go off because while the program is in the WAIT 5 MINUTES, the status goes to OFF and the program switches to the ELSE.
Edited by kclenden
To keep it simple, I would use a second program for the reason stated above.
Program Front Door Lights
if
from sunset
to sunrise (next day)
and 'front door motion-sensor' status is on
then
set front porch lights on
run program front door lights off (THEN)
else (blank)
________________________________________________________
Program Front Door Lights Off
if (blank)
then
Wait 5 minutes
set front porch lights off
else (blank)
