SCE HAN Gateway device
The SCE HAN gateway requires Zigbee, you'll probably have to wait until UD implements Zigbee on the Zmatter card.
@TechmanThanks.  That what I guessed.  Does anyone know of a Zigbee to BACnet, LON, Modbus, 802.11, anything that would work.  I could bring it into a Tridium JACE.  I got a Zigbee bacNET/IP gateway I use to talk to some Viconics stats but I believe those are just built for the stats and I couldn't discover / customize the points plus I don't know if SCE would even open me up.
UDI used to sell (or maybe still does) an ISY994iZ that had zigbee. This was used primarily for Energy monitoring and not for general Zigbee use. That link you posted is probably that version.
Also there was this...
https://www.universal-devices.com/product/smart-meter-module-sep-1-1/
You would have to contact UDI to see if they plan to support this with EISY.
Edited by brians
i have modbus protocal in in VB and raspi linux  if that would help you get started with a server..     Modbus is very common and open source
mark
Purchase the product and install it per the instructions that come with it.  In my case, I had to contact the power company to get it setup with my meter.
Install the Vue node server and configure it to communicate with the Vue device.
Oh man, I missed Michael's post in May about the Vue device.  That's a cute little device.  I bought a device awhile back from Rainforest Automation that is working well, it's become my first Python project, I'm talking to it and logging the consumption to a text file but now I just gotta find the time to write a pg3 or Java Niagara integration.  One thing I do like about the Rainforest device is it's got a 568 port on it so it can be connected with copper.
Edited by GJ Software Products
I like the Rainforest device a bit better than the Vue.  I think it's more expensive, but they are bit more open with their API.
Have you tried the Eagle 200 node server with it?  The Eagle 200 is a Rainforest Automation device.
@bpwwer Haven't tried the Eagle 200 node server, It'll probably work as the Eagle 3 I have just seems to be an extension of the Eagle 200 and uses the same WSDL.  I got a little Python script talking to it right now.  Yes, seems pretty open and so far so good, no problems with it.
